05-27-2013, 11:22 | #1 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | World First Nokia 105/Rm-908 Read Info/Factory Reset Done with Best Pinouts Under Battery -Use UFC cable Code: Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 02.70 22-02-13 RM-908 (c) Nokia IMEI : 355202050292138xxxxxx PPM : V 02.70 22-02-13 RM-908 (c) Nokia IJ PCode : 059R449 BPCode : 059Q858 HWID : 1000 LCDVer : CMI:BEIHAIv01 ILI9163C IMEI : 35520205xxxxxx Sl Conf : 001-01-00000000000 Sl Prof : 000000000004000-2 Sl Aux : 000B0000 Hw Sig : 6A89752EA381C21D Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:13 |
The Following 14 Users Say Thank You to syed tuqeer For This Useful Post: |
06-14-2013, 06:36 | #9 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Iassy Age: 59
Member: 19723 Status: Offline Thanks Meter: 359 | try to read full from one and have error: Infineon checking... Booting phone now.... Sync Ok, A2 CPU ID: XGOLD, A200341100 PBL: Static Boot ok, 01AB SBL: Static Algo Ok, 01 SBL mode ok SBL: Default_RAM_Bootloader EPP CFG [Bering]... Error Get Flash Info! Boot failed! [0200410040001400] - > Error booting phone... |
