02-03-2013, 14:06 | #1 (permalink) |
Major Poster Join Date: Feb 2010 Location: West bengal
Member: 1235642 Status: Offline Thanks Meter: 0 | x2-05 only vibrate light then off hare is log.......... Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 357406045119xxx PCcode : 059H132 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... ===Flashing [MCU]=== File : rm772__08.60a.mcusw Image : rm772__08.60a.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x018C0000 Erasing, wait ... Erase done, time : 00:02:22 Write , Start : 0x40280000 , Len : 0x01840000 Flashing , wait ... Region flash done, time : 00:00:33 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : rm772__08.60a.ppm_d Image : package_d.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41B40000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:31 Write , Start : 0x41B40000 , Len : 0x0055527C Flashing , wait ... Region flash done, time : 00:00:06 ===Flashing [CNT]=== File : rm772__08.60a_001.image_d_tele2_hr_9n8g1 Image : /build/rm772_sw_settings/temp/059N8G1/CONTENT_CONFIG/package_ Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42240000 , Len : 0x01BE0000 Erasing, wait ... Erase done, time : 00:01:30 Write , Start : 0x42240000 , Len : 0x00D20000 Flashing , wait ... Region flash done, time : 00:00:16 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip Flashing done! Total flash time : 00:05:38 Reboot phone now... - > AfterFlash Failed! Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... |
