10-14-2016, 18:07 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: 9ja
Member: 1110430 Status: Offline Thanks Meter: 104 | X2 RM1013 dead after attempt to flash [Verify Ok] : RM-1013_059W0W0_4eb2360bef9967c68b692bff68d021d4.nvi All done, all files were downloaded! Core : v2.23 , NXP FlashEngine : v5.2 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : rm1013_2.1.0.11_059W0W0_001_rawprogram_unsparse_ui .xml Ok, Set : rm1013_2.1.0.11_user_prog_emmc_firehose_8x10.mbn Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Get Phone Initial Info Product : MSM8610 Version : 0.5 Serial : 2A1D23D [FireHose_Error] : Error while init RAW mode (NO RAW ACK)! Try flash again in DEAD mode Flash Error Break flashing! Connect phone on selected interface... Core : v2.23 , NXP FlashEngine : v5.2 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : rm1013_2.1.0.11_059W0W0_001_rawprogram_unsparse_ui .xml Ok, Set : rm1013_2.1.0.11_user_prog_emmc_firehose_8x10.mbn Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected [FireHose_Error] : Phone not detected in any supported mode. Check Drivers, Cable, Battery Flash Error Break flashing! Connect phone on selected interface... The phone was showing NOKIA before and now not even connecting for flashing again.Pls how to revive this phone ? |
