01-16-2013, 14:07 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: I-N-D-I-A Age: 33
Member: 1119248 Status: Offline Sonork: 000000000000000000000000 Thanks Meter: 139 | x6 problem ? logs ........................ ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-559_40.0.002_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x0B71FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:01 Write : Processing RM-559_40.0.002_prd.core.C00 Total 508 [508/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:38 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-559_40.0.002_prd.rofs2.V21 Found 1 areas to erase Erasing area 0x07920000 - 0x0A2FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_40.0.002_prd.rofs2.V21 Total 54 [54/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:04 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-559_40.0.002.404.01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x0A300000 - 0x0B71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_40.0.002.404.01_prd.rofs3.fpsx Total 27 [27/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:01 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-559_40.0.002_001_000_U001.uda.fpsx Found 1 areas to erase Erasing area 0x0B720000 - 0x1EF7FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_40.0.002_001_000_U001.uda.fpsx Total 32 [32/0/0] blocks to write, writing... TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:48 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X6-00 Software Info: V ICPR72_11w16.1 28-07-11 RM-559 (c) Nokia IMEI: 353422048509995 Ape Version: V 40.0.002 Product code: 059C4R2 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:09 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Initializing Tests... IMEI : 353422048509995 , Phone : RM-559 Nokia X6-00 Get keys... PASSED | ST_TAHVOINT_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_IO_CTRL_LOOP_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_PWR_KEY_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_BACKUP_BATT_TEST PASSED | ST_RADIO_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_MBUS_RX_TX_LOOP_TEST PASSED | ST_AMB_LIGHT_SENSOR_TEST PASSED | ST_IIC_TEST PASSED | ST_DIGIMIC_TEST PASSED | ST_EXT_DEVICE_TEST PASSED | ST_CDSP_SLEEPCLK_FREQ_TEST PASSED | ST_CDSP_SLEEPCLOCK_FREQ_TEST PASSED | ST_CDSP_RF_BB_IF_TEST PASSED | ST_CDSP_RF_SUPPLY_TEST PASSED | ST_CDSP_TX_IQ_TEST PASSED | ST_CDSP_TXC_DATA_TEST PASSED | ST_CDSP_RX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_TX_PLL_PHASE_LOCK_TEST NOT RUN | ST_CDSP_WCDMA_TX_POWER_TEST NOT RUN | ST_CDSP_RX_IQ_LOOP_BACK_TEST NOT RUN | ST_CDSP_GSM_TX_POWER_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_CAMERA_ACCELERATOR_TEST PASSED | ST_SEC_CAMERA_IF_TEST PASSED | ST_LED_FLASH_TEST PASSED | ST_CAMERA_AUTOFOCUS_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_MAIN_LCD_IF_TEST PASSED | ST_TOUCH_STUCK_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_WLAN_TEST PASSED | ST_BT_WLAN_COEXISTENCE_TEST ->ERROR | ST_TOUCH_IF_TEST PASSED | ST_ACCEL_IF_TEST PASSED | ST_LCD_CONTROLLER_TEST PASSED | ST_VIBRA_TEST NOT RUN | ST_USB_LOOP_TEST PASSED | ST_RADIO_TEST PASSED | ST_TVOUT_IF_TEST PASSED | ST_IO_EXPANDER_IF_TEST SelfTests end Done! Elapsed: 00:03:32 expert what ido ? |
