Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 05-26-2013, 18:24   #1 (permalink)
Frenzy_2020's Avatar
Member: 789089
Sonork: 100.1617***
Thanks Meter: 267
Red face X7-00 dead after C drive format
Hi BEST team,
Got this X7-00 for flashing as it was hanging. I took backup of rpl and Full PM after the phone got formatted It showed the dotted line before startup for few mins and then the phone went off and never came On.
LOGS:
Reading Phone Info....
Connected phone -    Nokia X7-00
Software ver : V 79_sr1_12w18.5 27-07-12 RM-707 (c) Nokia
IMEI    :      356257040******
XappVer :      00000668
Ape Ver :      111.040.1511
APE Var :      111.040.1511111.040.1511.24.01111.040.1511.00.01
APE ADSP:      256
DSP Ver :      92_12w18
APE Test:      0.003
PPM     :
CNT     :
Product SN   :     MDN009071
Product code :     059G534
Base Prd.code:     059F8C6
Module code  :     0204661
Long Prod.SN :     0
Hardware info=======
HWID  : 1000
Retu  : 35
Tahvo : 00
Batery: 3880 mV
APE BT: HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 3392.
APE HW: 256
Lock info ===========
IMEI spNet : 3A 65 52 07 04 34 75 09
IMEI svNet : 33 65 52 07 04 34 75 49 F5
Conf key     : 0000000000000000
Provider key : 2440700000000000
Country      : Finland
Operator     : NOKIA (Open)
Counters     : Key 0  [3] , Fbus 0  [10]
Blocks       : 7
LOCK STATUS :
BLK : 1
 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS :  All Open
CRT308 Backup Created
SDD key status : Ok
CMLA Key status : Ok
SimLock status : Ok
Security status : Ok
PA_SimLock Version :
PA_SL3 phone ,  SP_CODE_LEN : 15
User code : Crypted
UserDataExLevel : Low [Gallery] , FullFlash method
Done!
Backup Certificates now...
Backup CRT308 data...
SLx Simlock Data read ... Ok
SL3 Simlock Sign read ... Ok
WMDRM read ... Ok
Check communication with phone....
Reboot....
Connection opened successfully
Waiting for communication response...
BootRom : 1st boot ok
ASIC ID:       000000030000022600010007600C192102031104
CPU ID :       RAPU v11 , Features : Dead-Test , USBRPL , FullUSB
EM0 ID:        00000C35
EM1 ID:        00000C30
PUBLIC ID:     1EC002152AE9584086075CB815968318A12CE9DA
ASIC MODE ID:  00
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID:        E693EF0DAC22615B
Use RAPUv11_2nd.fg  ,  Rev : 3.0  Ver : 12.14.0
Processing RAWLOADER...
FLIC : 006000EC
Req : XSR 1.6
Use RAPUv11_XSR17_alg.fg  ,  Rev : 3.0  Ver : 12.14.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done! :)
TIME : Boot time : 00:00:02
Reopening the connection...
Waiting for response: 30
Waiting for response: 29
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : A777258432D3E9101D6160DBAC2702FCC602E752
ADL: Reading certificates...
Reading NPC certificate...
IMEI : 35625704********
Reading CCC certificate...
Reading HWC certificate...
Reading R&D certificate...
Reading VARIANT certificate...
Reading PARTNERC certificate...
Reading MDM_KEYS certificate...
ADL: Reading certificates done! :)
ADL: Close_Session
Content: 000300000000000000000000000000
ADL: Reboot
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
Swap data collected to 059G534.pc
RPL saved : c:\InfinityBox\BEST\Backup\Cert\356257040******.rpl
All done, Disconnecting
Elapsed: 00:00:42
Connect phone on selected interface...
Phone found!
Series 60 Device detected!
read info...  - Ok
Operating mode is OK, no need change...
Reading PM from field 0 to 400
Field [1]    31 Record(s)
   Record 0: 10 byte(s) readed - Ok
   Record 1: 94 byte(s) readed - Ok
   Record 2: 110 byte(s) readed - Ok
   Record 4: 10 byte(s) readed - Ok
   Record 6: 110 byte(s) readed - Ok
   Record 7: 450 byte(s) readed - Ok
   Record 8: 10 byte(s) readed - Ok
   Record 13: 110 byte(s) readed - Ok
   Record 15: 30 byte(s) readed - Ok
   Record 16: 30 byte(s) readed - Ok
   Record 17: 30 byte(s) readed - Ok
   Record 18: 30 byte(s) readed - Ok
   Record 19: 30 byte(s) readed - Ok
   Record 22: 24 byte(s) readed - Ok
   Record 26: 10 byte(s) readed - Ok
   Record 27: 36 byte(s) readed - Ok
   Record 28: 110 byte(s) readed - Ok
   Record 29: 10 byte(s) readed - Ok
   Record 30: 36 byte(s) readed - Ok
   Record 31: 24 byte(s) readed - Ok
   Record 32: 216 byte(s) readed - Ok
   Record 33: 36 byte(s) readed - Ok
   Record 35: 24 byte(s) readed - Ok
   Record 36: 24 byte(s) readed - Ok
   Record 38: 216 byte(s) readed - Ok
   Record 39: 36 byte(s) readed - Ok
   Record 40: 24 byte(s) readed - Ok
   Record 41: 216 byte(s) readed - Ok
   Record 43: 36 byte(s) readed - Ok
   Record 44: 216 byte(s) readed - Ok
   Record 45: 216 byte(s) readed - Ok
Field [2]    1 Record(s)
   Record 0: 2808 byte(s) readed - Ok
Field [4]    7 Record(s)
   Record 1: 200 byte(s) readed - Ok
   Record 3: 10 byte(s) readed - Ok
   Record 4: 8 byte(s) readed - Ok
   Record 5: 8 byte(s) readed - Ok
   Record 6: 8 byte(s) readed - Ok
   Record 9: 5 byte(s) readed - Ok
   Record 28: 2 byte(s) readed - Ok
Field [6]    1 Record(s)
   Record 0: 96 byte(s) readed - Ok
Field [8]    11 Record(s)
   Record 0: 2 byte(s) readed - Ok
   Record 1: 16 byte(s) readed - Ok
   Record 2: 16 byte(s) readed - Ok
   Record 3: 128 byte(s) readed - Ok
   Record 4: 128 byte(s) readed - Ok
   Record 8: 8 byte(s) readed - Ok
   Record 9: 8 byte(s) readed - Ok
   Record 10: 32 byte(s) readed - Ok
   Record 11: 4 byte(s) readed - Ok
   Record 12: 4 byte(s) readed - Ok
Field [11]    5 Record(s)
   Record 0: 4 byte(s) readed - Ok
   Record 1: 4 byte(s) readed - Ok
   Record 2: 4 byte(s) readed - Ok
   Record 3: 4 byte(s) readed - Ok
   Record 4: 1059 byte(s) readed - Ok
Field [12]    1 Record(s)
   Record 0: 8 byte(s) readed - Ok
Field [26]    2 Record(s)
   Record 0: 16 byte(s) readed - Ok
   Record 1: 68 byte(s) readed - Ok
Field [31]    1 Record(s)
Field [44]    1 Record(s)
   Record 0: 1 byte(s) readed - Ok
Field [50]    1 Record(s)
Field [54]    2 Record(s)
   Record 2: 24 byte(s) readed - Ok
Field [96]    2 Record(s)
   Record 1: 20 byte(s) readed - Ok
Field [117]    11 Record(s)
   Record 1: 3 byte(s) readed - Ok
   Record 2: 6 byte(s) readed - Ok
   Record 3: 1 byte(s) readed - Ok
   Record 4: 9 byte(s) readed - Ok
   Record 5: 10 byte(s) readed - Ok
   Record 8: 42 byte(s) readed - Ok
   Record 13: 3 byte(s) readed - Ok
   Record 14: 3 byte(s) readed - Ok
   Record 16: 40 byte(s) readed - Ok
Field [120]    4 Record(s)
   Record 0: 944 byte(s) readed - Ok
   Record 1: 160 byte(s) readed - Ok
   Record 2: 130 byte(s) readed - Ok
   Record 3: 112 byte(s) readed - Ok
Field [153]    6 Record(s)
   Record 0: 68 byte(s) readed - Ok
   Record 2: 68 byte(s) readed - Ok
   Record 3: 68 byte(s) readed - Ok
   Record 4: 68 byte(s) readed - Ok
   Record 5: 68 byte(s) readed - Ok
Field [193]    4 Record(s)
   Record 2: 8 byte(s) readed - Ok
   Record 3: 32 byte(s) readed - Ok
   Record 4: 32 byte(s) readed - Ok
   Record 9: 64 byte(s) readed - Ok
Field [217]    1 Record(s)
   Record 0: 32 byte(s) readed - Ok
Field [239]    4 Record(s)
   Record 1: 3817 byte(s) readed - Ok
   Record 2: 3817 byte(s) readed - Ok
   Record 6: 218 byte(s) readed - Ok
Field [291]    1 Record(s)
   Record 0: 92 byte(s) readed - Ok
Field [308]    7 Record(s)
   Record 1: 8192 byte(s) readed - Ok
   Record 4: 1 byte(s) readed - Ok
   Record 6: 1 byte(s) readed - Ok
   Record 7: 1 byte(s) readed - Ok
   Record 9: 40 byte(s) readed - Ok
Field [309]    7 Record(s)
   Record 1: 2 byte(s) readed - Ok
   Record 2: 12 byte(s) readed - Ok
   Record 3: 36 byte(s) readed - Ok
   Record 4: 12 byte(s) readed - Ok
   Record 7: 12 byte(s) readed - Ok
   Record 17: 12 byte(s) readed - Ok
Field [313]    1 Record(s)
   Record 0: 800 byte(s) readed - Ok
Field [322]    1 Record(s)
Field [329]    1 Record(s)
   Record 0: 8392 byte(s) readed - Ok
Field [334]    1 Record(s)
Field [341]    3 Record(s)
   Record 4: 4386 byte(s) readed - Ok
Field [354]    1 Record(s)
Field [356]    1 Record(s)
Field [360]    2 Record(s)
Field [369]    1 Record(s)
   Record 0: 40 byte(s) readed - Ok
Field [382]    2 Record(s)
   Record 0: 64 byte(s) readed - Ok
Field [388]    1 Record(s)
Field [395]    1 Record(s)
Saved as C:\InfinityBox\BEST\Backup\RM-707 Nokia X7-00_356257040******_0_400.pm
Done!
Elapsed: 00:00:01
Format File System...
Scanning FS parametres...
Checking Data...
Detected : 3 drive(s)...
Start formating....
Using Series 60 format algorithm...
Formating drive : C now...
Plz advice how to revive this phone
Thanks in advance
Frenzy
Old 05-26-2013, 18:44   #2 (permalink)
Patrick_Carter's Avatar
Member: 672242
Sonork: 100.1640826
Thanks Meter: 23
Just reinstall phones bro,.
flash with firmware 111.040.1511 like the begining.
hopefully helpful..
B.R
Patrick
Old 05-26-2013, 18:50   #3 (permalink)
Member: 789089
Sonork: 100.1617***
Thanks Meter: 267
hopefully helpful..
B.R
Patrick
Phone is not getting detected also when i Press the camera button phone vibrates slightly. how so i erase and restore phone back can u provide step by step guide.
thanks again for ur prompt reply
frenzy
Old 05-26-2013, 19:17   #4 (permalink)
Member: 592636
Thanks Meter: 674
if u have problem with usb cable only use fbuse cable:
diassable phone then connect ur phone with fbuse cable with anothere tool,
and checking this solution:
http://forum.gsmhosting.com/vbb/f641...tware-1604594/
Old 05-26-2013, 19:24   #5 (permalink)
Member: 789089
Sonork: 100.1617***
Thanks Meter: 267
Is there no chance via usb, I am not sure if I have the Fbus cable, Plz but are u sure this is a problem with CMLA Key as The phone came on showed the Spotted lines that its abt to starp and went off and never came On.
frenzy
Old 05-27-2013, 15:22   #6 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
For why erase it? Why not charge battery first and reflash???
The Following User Says Thank You to Dzirt For This Useful Post:
Old 05-27-2013, 15:54   #7 (permalink)
Member: 789089
Sonork: 100.1617***
Thanks Meter: 267
Thanks Dzirt, Did that already its was actually low battery I put the phone for charge for nearly 40 min only then did the phone come ON.But why did the battery drain totally as I had seen the charge before Format it was more then 50%.
thanks a lot
frenzy
Old 05-27-2013, 18:05   #8 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Maybe something wrong with battery or with phone sw. In any case - better make simple steps before go deep.
Old 06-01-2013, 13:04   #9 (permalink)
SRASHED's Avatar
Member: 1024699
Sonork: 100.1622959
Thanks Meter: 599
Full charged your Battery and flash again another computer..Hope ur problem solved..
Old 06-01-2013, 13:43   #10 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
http://forum.gsmhosting.com/vbb/9456322-post7.html
When you, people, start learn reading????
Old 06-01-2013, 13:59   #11 (permalink)
Member: 1877063
Thanks Meter: 18
restart your computer sir, then do full flashing with latest version... restore back-up
Page generated in 0.20802 seconds with 8 queries
