03-04-2015, 14:48 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: RMS- CLUB
Member: 723410 Status: Offline Sonork: 📱 100.1592732 Thanks Meter: 3,374 | Xl rm-1030 how to full flash! registered to: Haji rahim Connect phone on selected interface... Core : v2.03 , NXP FlashEngine : v4.6 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.2.3.21_059W170_IMEA_PK_V2_variant.img Ok, Set : RM1030_V2_1.2.3.21_boot.img Ok, Set : RM1030_V2_1.2.3.21_cache.img Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboot.mbn Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboothd.mbn Ok, Set : RM1030_V2_1.2.3.21_fat.bin Ok, Set : RM1030_V2_1.2.3.21_oemsbl.mbn Ok, Set : RM1030_V2_1.2.3.21_oemsblhd.mbn Ok, Set : RM1030_V2_1.2.3.21_persist.img Ok, Set : RM1030_V2_1.2.3.21_preload.img Ok, Set : RM1030_V2_1.2.3.21_qcsbl.mbn Ok, Set : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn Ok, Set : RM1030_V2_1.2.3.21_recovery.img Ok, Set : RM1030_V2_1.2.3.21_system.img Ok, Set : RM1030_V2_1.2.3.21_udisk.bin Ok, Set : RM1030_V2_1.2.3.21_userdata.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : F29ADA68 Processing : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing [ERROR_dFlIm] : FAILflash write failure Partition Flash Error , something went wrong Flash Error Break flashing! NOTE: I HAVE CAREFULLY CHECKED FROM BACKE SIDE OF PHONE PRODUCT CODE DRIVERS INSTALLED CORRECTLY!! Last edited by haji rahim; 03-04-2015 at 14:55. |
03-05-2015, 06:22 | #3 (permalink) |
Member: 723410 Status: Offline Sonork: 📱 100.1592732 Thanks Meter: 3,374 | yes bro same Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : F29ADA68 Processing : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing [ERROR_dFlIm] : FAILflash write failure Partition Flash Error , something went wrong Flash Error Break flashing! |
03-06-2015, 05:22 | #5 (permalink) |
Member: 723410 Status: Offline Sonork: 📱 100.1592732 Thanks Meter: 3,374 | registered to: haji rahim Connect phone on selected interface... Core : v2.03 , NXP FlashEngine : v4.6 Flash Mode : Wipe (Reset/Erase UserData and Settings) Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.2.3.21_cache.img Ok, Set : RM1030_V2_1.2.3.21_persist.img Ok, Set : RM1030_V2_1.2.3.21_userdata.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Device boot not done Check Drivers Try again Core : v2.03 , NXP FlashEngine : v4.6 Flash Mode : Wipe (Reset/Erase UserData and Settings) Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.2.3.21_cache.img Ok, Set : RM1030_V2_1.2.3.21_persist.img Ok, Set : RM1030_V2_1.2.3.21_userdata.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : F29ADA68 Processing : RM1030_V2_1.2.3.21_persist.img Init Ok, send data ... Data sent, start flashing [ERROR_dFlIm] : FAILflash write failure Partition Flash Error , something went wrong Flash Error Break flashing! Core : v2.03 , NXP FlashEngine : v4.6 Flash Mode : System Update : Not Touch UserData Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.2.3.21_059W170_IMEA_PK_V2_variant.img Ok, Set : RM1030_V2_1.2.3.21_boot.img Ok, Set : RM1030_V2_1.2.3.21_cache.img Ok, Set : RM1030_V2_1.2.3.21_fat.bin Ok, Set : RM1030_V2_1.2.3.21_persist.img Ok, Set : RM1030_V2_1.2.3.21_preload.img Ok, Set : RM1030_V2_1.2.3.21_recovery.img Ok, Set : RM1030_V2_1.2.3.21_system.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : F29ADA68 Processing : RM1030_V2_1.2.3.21_boot.img Init Ok, send data ... Data sent, start flashing [ERROR_dFlIm] : FAILflash write failure Partition Flash Error , something went wrong Flash Error Break flashing! If you havge time: cantcat me via sonork or skype |
