06-15-2014, 10:31 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: IR
Member: 1189402 Status: Offline Sonork: 10000.00 Thanks Meter: 18 | XL_RM_1030 after flash with best dead Code: Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.1.2.20_059W178_IMEA_QA_V2_variant.img Ok, Set : RM1030_V2_1.1.2.20_boot.img Ok, Set : RM1030_V2_1.1.2.20_cache.img Ok, Set : RM1030_V2_1.1.2.20_emmc_appsboot.mbn Ok, Set : RM1030_V2_1.1.2.20_emmc_appsboothd.mbn Ok, Set : RM1030_V2_1.1.2.20_fat.bin Ok, Set : RM1030_V2_1.1.2.20_oemsbl.mbn Ok, Set : RM1030_V2_1.1.2.20_oemsblhd.mbn Ok, Set : RM1030_V2_1.1.2.20_persist.img Ok, Set : RM1030_V2_1.1.2.20_preload.img Ok, Set : RM1030_V2_1.1.2.20_qcsbl.mbn Ok, Set : RM1030_V2_1.1.2.20_qcsblhd_cfgdata.mbn Ok, Set : RM1030_V2_1.1.2.20_recovery.img Ok, Set : RM1030_V2_1.1.2.20_system.img Ok, Set : RM1030_V2_1.1.2.20_udisk.bin Ok, Set : RM1030_V2_1.1.2.20_userdata.img Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 243AC0CB Processing : RM1030_V2_1.1.2.20_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_V2_1.1.2.20_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_V2_1.1.2.20_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.1.2.20_059W178_IMEA_QA_V2_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:03:57 Reboot phone Ok system find zeus usb driver |
06-15-2014, 10:45 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | I can say " Congrats " only. For why you flash V2 files inside it? Because "latest" version? For why on back sticker located ProductCode? I last few days explore that things and seems as due different HW for V2 phones they die after updater. So, at now seems as only JTAG can help. If some results will be in near days - I let you know. |
The Following User Says Thank You to Dzirt For This Useful Post: |
06-15-2014, 11:03 | #5 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Probably - they shouls support it. Check in their section. Next time, please, don't flash firmwares from 1.1.2.20 list , if phone not have ProductCode with V2. I add checking inside BEST and inside NaviManager for that too. |
06-15-2014, 12:52 | #6 (permalink) |
Freak Poster Join Date: Aug 2012 Location: LC
Member: 1793281 Status: Offline Thanks Meter: 167 | Hello, I also have a problem. Yesterday my coworker flashed Nokia X RM-980. Customer forgot user code. PC from back sticker it's the same like flash files. For now phone not vibrate and is not detected by computer. Is there another solution than JTAG? Code: card found: S/N 3F9C:0118 registered to: [email protected] Connect phone on selected interface... Core : v1.89 , NXP FlashEngine : v1.2 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM980_V2_1.1.3.20_059W128_EURO_PL_V2_variant.img Ok, Set : RM980_V2_1.1.3.20_boot.img Ok, Set : RM980_V2_1.1.3.20_cache.img Ok, Set : RM980_V2_1.1.3.20_emmc_appsboot.mbn Ok, Set : RM980_V2_1.1.3.20_emmc_appsboothd.mbn Ok, Set : RM980_V2_1.1.3.20_fat.bin Ok, Set : RM980_V2_1.1.3.20_oemsbl.mbn Ok, Set : RM980_V2_1.1.3.20_oemsblhd.mbn Ok, Set : RM980_V2_1.1.3.20_persist.img Ok, Set : RM980_V2_1.1.3.20_preload.img Ok, Set : RM980_V2_1.1.3.20_qcsbl.mbn Ok, Set : RM980_V2_1.1.3.20_qcsblhd_cfgdata.mbn Ok, Set : RM980_V2_1.1.3.20_recovery.img Ok, Set : RM980_V2_1.1.3.20_system.img Ok, Set : RM980_V2_1.1.3.20_udisk.bin Ok, Set : RM980_V2_1.1.3.20_userdata.img Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Device boot not done Check Drivers Try again Core : v1.89 , NXP FlashEngine : v1.2 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM980_V2_1.1.3.20_059W128_EURO_PL_V2_variant.img Ok, Set : RM980_V2_1.1.3.20_boot.img Ok, Set : RM980_V2_1.1.3.20_cache.img Ok, Set : RM980_V2_1.1.3.20_emmc_appsboot.mbn Ok, Set : RM980_V2_1.1.3.20_emmc_appsboothd.mbn Ok, Set : RM980_V2_1.1.3.20_fat.bin Ok, Set : RM980_V2_1.1.3.20_oemsbl.mbn Ok, Set : RM980_V2_1.1.3.20_oemsblhd.mbn Ok, Set : RM980_V2_1.1.3.20_persist.img Ok, Set : RM980_V2_1.1.3.20_preload.img Ok, Set : RM980_V2_1.1.3.20_qcsbl.mbn Ok, Set : RM980_V2_1.1.3.20_qcsblhd_cfgdata.mbn Ok, Set : RM980_V2_1.1.3.20_recovery.img Ok, Set : RM980_V2_1.1.3.20_system.img Ok, Set : RM980_V2_1.1.3.20_udisk.bin Ok, Set : RM980_V2_1.1.3.20_userdata.img Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : A528D637 Processing : RM980_V2_1.1.3.20_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.1.3.20_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.1.3.20_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.1.3.20_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_V2_1.1.3.20_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.1.3.20_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_V2_1.1.3.20_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.1.3.20_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.1.3.20_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.1.3.20_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.1.3.20_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.1.3.20_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.1.3.20_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.1.3.20_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.1.3.20_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_V2_1.1.3.20_059W128_EURO_PL_V2_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:03:19 Reboot phone Ok Connect phone on selected interface... |
06-15-2014, 14:05 | #9 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Yes, it is not V2 and that is reason. Will add all thing for that today-tomorrow and make update. About repair - not sure, but will try play with it. |
08-13-2014, 03:42 | #11 (permalink) | |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
By the way repair is possible with BEST now, but require some kind of HW device, which will be available in some near time. | |
