09-24-2011, 14:36 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: egypt Age: 54
Member: 11101 Status: Offline Sonork: 100.1641000 Thanks Meter: 1,783 | (attention) Before use service Nokia sl3 local Brute force Server FonecOnlineServices(F.O.S) News FonecOnlineServices | (F.O.S) History service Nokia SL3 Brute Force |
The Following User Says Thank You to fonec For This Useful Post: |
09-24-2011, 14:53 | #2 (permalink) |
Member: 11101 Status: Offline Sonork: 100.1641000 Thanks Meter: 1,783 | this is log from one phone code notwork and also client not get refunded so all take care it code calculator and you received 1-it will not work 2-you will not get refunded money Reading Phone Info.... Connected phone - Nokia X3-02 Software ver : V 05.65 26-11-10 RM-639 (c) Nokia IMEI : 353764043993728 Ape Ver : APE Var : APE ADSP: DSP Ver : 92_MP2.2_5.63j APE Test: PPM : V 05.65 26-11-10 RM-639 (c) Nokia B CNT : Content: b_0598279 V 05.65 26-11-10 RM-639 (c) Nokia Product SN : CSH563714 Product code : 059G4H1 Base Prd.code: 0593642 Module code : 0204600 Long Prod.SN : 0 Hardware info======= HWID : 1004 Retu : 51 Tahvo : 00 Batery: 4123 mV Camera: CMT BT: 4217-v529 APE BT: APE HW: LCDVer: TPO RF ic : Lock info =========== IMEI : 353764043993728 IMEI spNet : 3A 35 67 04 34 99 73 02 IMEI svNet : 33 35 67 04 34 99 73 22 F7 Conf key : B000000000000000 Provider key : 3340201549764300 Provider : NEW TELCEL;Mexico Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= CRT308 Backup Created User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
09-24-2011, 15:02 | #3 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | But Brother I m already unlock 1 mobile 5530 TELCEL Mexico just flash set to orignal frimware and enter code set unlock without any problem |
09-24-2011, 15:13 | #5 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Not need to flash for enter nck codes... All sl3 from Telcel/Mexico con confKey or ProfileKey: B*************** are not supported... All the rest are 100% supported. Always before send any Telcel to BF check ConfKey detail. br elcapitel |
The Following User Says Thank You to elcapitel For This Useful Post: |
09-24-2011, 15:26 | #6 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Romania
Member: 72330 Status: Offline Sonork: 100.1604259 Thanks Meter: 35 | yes,not get refoundet but this informations and other must be posted before making any order on your server just to inform your clients |
The Following User Says Thank You to dualsimcect For This Useful Post: |
09-24-2011, 17:55 | #8 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: SRI LANKA
Member: 746449 Status: Offline Sonork: 100.1603972 Thanks Meter: 171 | Quote:
so above example log is x3-02 its impossible to brute force bcause that 20 digit nck that is the problem | |
09-24-2011, 17:59 | #9 (permalink) | |
The Following User Says Thank You to MOBILECHANNEL For This Useful Post: |
09-24-2011, 18:10 | #11 (permalink) |
Member: 746449 Status: Offline Sonork: 100.1603972 Thanks Meter: 171 | Nokia X3-02 Unlock no possible... :-( -------------------------------------------------------------------------------- I'll try reading log from Nokia x3-02 Fenix Reader SW version: 0.0.2 Connection interface is set to USB now. Checking connection... Reading phone info Product type: RM-639 MCU SW Version: V 05.60 06-10-10 RM-639 (c) Nokia PPM Version: V 05.60 06-10-10 RM-639 (c) Nokia B Content Pack Version: Content: T-mobile HU sl v2 V 05.60 06-10-10 RM-639 (c) Nokia Imei: 356255041062XXX Product code: 059F457 Simlock status: Profile bits: 8000000000000000 Config key: 2163000000000000 Fbus codes typed: 0 Key codes typed: 0 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 21 63 0F Looking for flash files Flash files found for selected product Job's finished successfully! SL3 Unlocking started (via USB) Powering off the phone PLEASE PRESS PHONE`S POWER BUTTON CMT Hash : 916F75217F32081248B15C38DFC8E81B CMT Hw ID: 600C192102031104 CMT Boot ROM CRC: E693EF0D CMT Secure ROM CRC: AC22615B CMT Public Id: 07F000187DD403445629E04AD7350205F364A9C2 Preparing bootstrap to use USB BootMedia Sending RAW 2ND Initializing... Trying to set test mode automatically... Please disconnect phone from computer, remove the battery, put it back, switch the phone on and connect it to the computer. Disconnected from the device Waiting for phone... Connected to the device Setting test mode Reading phone data WARNING: THIS IS A 20 - DIGITS SIMLOCK PHONE. BRUTEFORCE IS IMOPSSIBLE. Uploading this log file to any server will give no result. Setting normal mode Job's finished successfully! http://forum.gsmhosting.com/vbb/f644...force-1352535/ |
