Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Dragon Box
Dragon Box Chinese Phone Tool
Old 08-25-2012, 05:15   #1 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,357
How to work with MSTAR CPU (8533 e.t.c.)
With New Version
http://www.youtube.com/watch?v=O-mlbAXPimw
With Old Version[/B]
http://www.youtube.com/watch?v=Bdn1356RLCc
Thanks to Dulu Bhai
http://forum.gsmhosting.com/vbb/member.php?u=1736341
DIPENDRA PATHAK
The Following 2 Users Say Thank You to Dipendra Pathak For This Useful Post:
Old 08-25-2012, 05:33   #2 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,357
GPG Dragon Pin Finder with RX and TX
GPG DRAGON Pin Finder with RX and TX
http://www.youtube.com/watch?v=ZMXSZbJMQZM
Thanks to Faisal Compuer
Dipendra Pathak
The Following User Says Thank You to Dipendra Pathak For This Useful Post:
Old 08-25-2012, 05:41   #3 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,357
GPG Dragon Read File 6225
Dragon Read File MTK 6225
http://www.youtube.com/watch?v=UDzYlKU2wDY
DIPENDRA PATHAK
Old 08-25-2012, 05:53   #4 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,357
Making Dragon as USB Pin Finder for Origional Nokia C-5
Making Dragon as USB Pin Finder for Origional Nokia (Here Nokia C-5)
http://www.youtube.com/watch?v=RcPNfLDbpNc
Dipendra Pathak
Old 08-25-2012, 06:07   #5 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,357
How to change 2 IMEI Using GPG Dragon
How to Change 2 IMEI using GPG Dragon
http://www.youtube.com/watch?v=D9JIkg8DZ9w
Dipendra Pathak
Old 08-25-2012, 06:27   #6 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,357
How to set Manually pinout for Coolsand (an Example) with GPG Dragon
How to Set Manually Pinout for Coolsand (Just an Example)
http://www.youtube.com/watch?v=naZbXoYHync
Dipendra Pathak
Old 08-25-2012, 06:39   #7 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,357
GPG Dragon SPD Tutorial
GPG DRAGON SPD Tutorial
http://www.youtube.com/watch?v=nxBmLHGQ5Go
Dipendra Pathak
Old 08-25-2012, 06:48   #8 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,357
Read-Write 6252 CPU by Dragon Old Version - 2.08
READ - Write 6252 CPU by DRAGON Old Version - 2.08
http://www.youtube.com/watch?v=dD6vNKtaQyg
Dipendra Pathak
Old 08-25-2012, 07:07   #9 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,357
How to Use GPG Freeware Software with SPD
http://www.youtube.com/watch?v=drZyvSQANMU
Thanks to Faheem Anjum
Dipendra Pathak
Old 08-25-2012, 07:13   #10 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,357
How to upgrade Dragon Box Firmware
[YOUTUBE]3RwTOPmpPxk[/YOUTUB[B]E]
Dipendra Pathak
Old 07-19-2013, 07:47   #11 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,357
24 hours Ambulance services for mobiles in DRAGON MOBILE HOSPITAL
Receive Data 0x7E Error... - Android CPU Solution
We want to provide the solution through some hints/tips because this is not software problem but this is driver problem.
we are starting this thread, so that the we also could be confirm by our valuable customer. So, try to connect our supporter
if you are stuck in any point
Check this post
android spd cpu and need help
Also if you find the problem like this:
In such a case, open the "DEVICE MANAGER"
we can see the driver name as "SPRD U2S Diag"
"SPRD U2S Diag" driver not for SPD chip Device. So, when you try each and every time, it shows error.
we need uninstall it and instll to sci (spd flash driver).
open the c:\windows\system32
And search all "sprd" and "spd" name files
Delete all
after del,you need use dragon software pinfind again
after pinfind,in the driver manager will tell you install the new driver
install the driver <7-Select SCI Driver>
after install the driver, we can read flash file. Now, dragon successfully reads.
Good Luck Dragon Users
Dipendra Pathak
The Following 14 Users Say Thank You to Dipendra Pathak For This Useful Post:
Old 07-28-2013, 23:47   #12 (permalink)
Member: 1873116
Thanks Meter: 5
After replacing the driver read flash success
The Following User Says Thank You to Gorunon2013 For This Useful Post:
Old 08-08-2013, 05:17   #13 (permalink)
GPGDragon Help's Avatar
Member: 1428349
Sonork: 100.1597111
Thanks Meter: 13,138
how to Made the MTK driver support your MTK Phone
en..at this time,I face some problem for the MTK stuep the driver
I sure the Mobile is MTK CPU,and in the driver install I has select the MTK Driver
but still error,and can't install it
how to solve??? read this!!!!
sample with windows XP(x86) system
first,we open the mtk driver inf file"usb2ser_2kXP.inf"
The device manager show you the driver name!
now we can add the new driver info support the mtk phone hardware
add the driver pid and vid to the info file
after save the inf file,and install the driver again,finish
The Following 2 Users Say Thank You to GPGDragon Help For This Useful Post:
Old 08-08-2013, 05:19   #14 (permalink)
Member: 1428349
Sonork: 100.1597111
also for the mtk imei driver you can edit it and support your phone
The Following 3 Users Say Thank You to GPGDragon Help For This Useful Post:
Old 08-15-2013, 11:00   #15 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,357
How to change SPD 6820 / 8810 Andorid 4 IMEI Without Root and few Click (Mobile PHone N9300)
Read Info
Format User Data
How to change SPD 6820/8810 Andorid 4 IMEI Without Root and few Clicks
1. Open SPD Tab.
2. Connect the mobile with Dragon Main Cable and + and - power cable with it (No Battery)
3. Tick "Scan Pinout"
4.Choose "Write IMEI"
5. Choose "6820 Android" Boot
6. Choose "USB"
7.Start
8. Wait Yellow line when it becomes 100% and IMEI Box becomes Green and opens for IMEI write
9. Fill the Correct IMEI that is printed on the Mobile Housing
10. Click On "Write IMEI" and Wait
11. Wait for message "Write (IMEI) to Mobile Done"
12. Restart Your mobile and check the IMEI using keys *#06#
13. Done
We do not believe in Faith, Miracle etc, We believe in Work and we believe in GPG Dragon
Dipendra Pathak
The Following 19 Users Say Thank You to Dipendra Pathak For This Useful Post:
Page generated in 0.50387 seconds with 8 queries
