Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Dragon Box
Dragon Box Chinese Phone Tool
Old 08-17-2013, 03:34   #16 (permalink)
GPGDragon Help's Avatar
Member: 1428349
Sonork: 100.1597111
Thanks Meter: 13,137
Windwos 7 / 8 Box Driver, Box firmware and Device (Mobile) Drivers
This Is Last Driver Update;more stable support your Box(all with Pl2303 IC Driver)
Click Download Pl2303 V1.8.0 Driver in 4shared
The Following 15 Users Say Thank You to GPGDragon Help For This Useful Post:
Old 08-17-2013, 05:47   #17 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,233
ok sir got it. thank you very much.....
and here is another fast link
http://www.mediafire.com/?1j4qldt13y61ap9
The Following 6 Users Say Thank You to Nasir Mobiles For This Useful Post:
Old 08-17-2013, 08:10   #18 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,355
How to change 625a CPU IMEI with USB Cable with Dragon box?
1.Select "MTK"
2.Select "Write IMEI"
3.Mobile option "COM" switch to "USB"
4.Click "Start"
5. Now, Insert Battery to the mobile and Connect USB Cable to the Computer
6. Now, software shows you Original IMEI
7. Write any valid IMEI to the software's IMEI Box
8.Click "write imei"
9. Done
The Following 11 Users Say Thank You to Dipendra Pathak For This Useful Post:
Old 08-17-2013, 08:13   #19 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,355
How to remove Password from Mstar CPU (Phone) ?
This function makes the flash file passwordless. This means when you use this option, then, Dragon removes the password and saves new passwordless file to the computer. Now, you have to write this file to the mobile again.
1. Open the Dragon software
2. Click on "CheckBox"
3. Now, go to "Mstar" Tab
4. Choose option as "Read Password"
5. After this, you will see a box called "Clear_code". Tick the "Clear_Code"
6. Now, Choose the file name you want to save.
7. Click "Start"
8. Wait until the flash file is fully read by Dragon Box
9. Now, you need Write this Flash File File to the Device
10. Wait until the flash file written.
11. Done. Now, your device is passwordless
The Following 13 Users Say Thank You to Dipendra Pathak For This Useful Post:
Old 08-23-2013, 16:21   #20 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,355
How to Spice M5460 MT6250/20 Touch Pad Calibration With the help of Dragon Box
1. Open Dragon Old Version Software 2.13
2. Connect Box
3. Choose "Tracker" Choose "Boot Version" and Click "Start"
4. Press and Hold Power button until software tells you to release.
5. Now, Choose "Restore Settings"
6. Click on "Restore"
7. Now, Choose Calibration Data "6253.cci" and Click on "Open"
8. Software shows you error but don't worry, it works.
9. Again Click on "Restore"
10. Choose Calibration Data "calibration titan.cci" and Click on "Open"
11. software shows you an error but doesn't matter, it works.
12. Again Click on "Restore"
13. Once more time, Choose Calibration Data "MTK6225.cci"
14. software shows you an error but doesn't matter, it works.
15. Again Click on "Restore"
16. Finally, Choose Calibration Data "MTK 6223.cci" and Click on "Open"
17. software shows you an error but doesn't matter, it works.
18. Done.
Video Tuterial + Touch CCI file Download Link:
http://www.4shared.com/rar/x97Bc_w3/...th_Dragon.html
NOTE: No need to do all the data at the same time because touch data can hang the mobile and not function the touch even you calibrate it. I did it because Customer wants to see the functional Screen or needs new mobile from my site. Because it was happened when I reset the mobile and could not calibrate from any other devices.
The Following 2 Users Say Thank You to Dipendra Pathak For This Useful Post:
Old 08-28-2013, 11:26   #21 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,355
HOW TO WRITE IMEI of MTK ANDROID MOBILE 6575 etc.
1. Power ON the device (Mobile)
2. Tick "Development" Option.
3. Now, Switch the mobile Off
4. Take out the battery and re-install the battery to the device.
6. Now, Open Dragon Software
7. Choose Dragon Box Port
8. CheckBox (Box Connects in Specif port)
9. Un-tick "Scan Pinout" If you are doing with USB cable + Battery
10. Choose "Write IMEI" in MTK tab
11. Choose "USB" (not COM)
12. Tick "Android IMEI"
13. Click "Start"
14. Wait and let the mobile install necessary drivers.
15. Now, you can see, yellow lines running in the button. Wait until it finish 100%
16. Now, IMEI Box Opens in Blue colour.
17. Write the IMEI that is written in the mobile housing.
18. Click "Write"
19. Now, Connect the USB cable to the Computer
20. Waits until you see "Successfully Done"
21. Done
The Following 4 Users Say Thank You to Dipendra Pathak For This Useful Post:
Old 08-28-2013, 14:33   #22 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,355
HOW TO Remove Pattern Lock of SPD Android Mobiles ie SPD 6820/8810.
BATTERY + USB Cable Way
1. Switch the mobile Off
2. Take out the battery and re-install the battery to the device.
3. Now, Open Dragon Software
4. Choose Dragon Box Port
5. CheckBox (Box Connects in Specif port)
6. Go to "SPD" Tab
7. Un-tick "Scan Pinout" If you are doing with USB cable + Battery
8. Choose "Format"
9. Choose Mobile Option "6820_Android"
10. Choose Use Option as "Format"
11. Tick "Format_UserData" (DO NOT Select Format_RuntimeNV, Format_Cache, Format_Misc)
12. Choose "USB" (not COM)
13. Click "Start"
14. Now, Press the Boot Key and Connect the mobile to the computer with the help of USB Data Cable.
Note: Boot Key might be Volume Down or Home Butten etc.
15. Wait and let the mobile install necessary drivers.
16. Waits until you see "All Done"
17. Done
MAIN CABLE and +/- of Main Cable Way (No Battery)
2. Connect the Mobile with the help of Dragon MAIN CABLE + DRAGON +/- wire (Not from Battery)
6. Go to "SPD" Tab
7. Tick "Scan Pinout" If you are doing with USB cable + Battery
8. Choose "Format"
13. Now, Press the Boot Key and Click on "Start".
14. Waits until you see "All Done"
15. Done
The Following 5 Users Say Thank You to Dipendra Pathak For This Useful Post:
Old 08-28-2013, 14:53   #23 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,355
HOW TO Remove Pattern Lock of MTK Android Mobiles ie MTK 6575 etc.
6. Go to "MTK" Tab
8. Choose "Format"
9. Tick "Auto Format" if you don't know the Manual Format Address
10. Choose "USB" (not COM)
11. Click "Start"
12. Now, Press the Boot Key and Connect the mobile to the computer with the help of USB Data Cable.
Note: Boot Key might be Volume Down or Home Button etc.
13. Wait and let the mobile install necessary drivers.
15. Done
1. Device must be ticked "Development" Option.
2. Connect Mobile with GPG Dragon Main Cable and +/- Cable from Main Cable (for power supply)
6. Go to "MTK" Tab
7. Tick "Scan Pinout" If you are doing with Main Cable + Dragon Cable Power Supply (NO Battery)
8. Choose "Format"
11. Now, Press the Boot Key and Click on "Start"
12. Wait and let the mobile install necessary drivers.
13. Waits until you see "All Done"
14. Done
Old 09-19-2013, 11:29   #24 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,355
How to Repair MTK IMEI With USB Method
WIth the help of Dragon Main Cable + Main cable Power supply (Do not use Battery )
1. Open the Dragon Software
2. Choose "MTK" tab
3. Tick "Scan Pinout"
4. Choose "USB" (NOT COM Port)
5. Now, Connect the Device With Dragon MAIN CABLE and its power cable (NOT Battery and USB cable)
6. Click on "Start"
7. Wait until the Yellow mark goes to 100% and turn Green
8. Write Valid IMEI
9. Click on "Write IMEI"
10. Wait until IMEI Written.
Done
WIth the help of USB Cable and Battery (Do not use Dragon Main Cable and Power supply)
2. Choose "MTK" tab
3. Untick "Scan Pinout"
5. Click on "Start"
6. Insert Battery + USB Cable and now connect to the computer
7. Wait until the driver installed
8. Now you will see Yellow mark goes upto 100% and it turns Green
9. Write Valid IMEI
10. Click on "Write IMEI"
11. Wait until IMEI Written.
Done
NOTE: Sometimes you must ON Device, and choose Device Diagnostics Port to repair IMEI.
STILL IMEI NOT CHANGING WHAT IS THE PROBLEM?
Sometimes You changed the IMEI of 6252 (MTK) using Dragon Box, Still IMEI not changing, in such a case, follow the methods:
1. Backup the flash file of the mobile
2. Save it to the hard disk or portable device
3. Write it back to the Device (Mobile)
4. Check the IMEI
5. Done
Please USE only USB Method. COM method not supported yet.
Old 09-25-2013, 13:36   #25 (permalink)
Gsm.Universal's Avatar
Member: 1526738
Sonork: 100.1607644
Thanks Meter: 3,561
Dragon Triple three {333} BOX drivers . MTK USB SPD USB ANDRIOD SPD USB COOLSAND
MTK USB
SPD USB
ANDRIOD SPD USB
COOLSAND USB
Download
The Following 7 Users Say Thank You to Gsm.Universal For This Useful Post:
Old 09-26-2013, 04:49   #26 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,355
Dragon Old Version
Version 26
http://www.4shared.com/rar/qSvmZtua/...agon_v326.html
Version 3.33
http://www.4shared.com/rar/fkjEaa9f/gpg_dragon_333.html
Box Firmware
http://www.mediafire.com/download/vj...mware+1.65.rar
How to Upgrade Box Firmware
Click to View - How to upgrade Dragon Firmware
How to solve the Problem of Updating the Box firmware
GPGDragon Firmware Update Guide
Dipendra Pathak
The Following 8 Users Say Thank You to Dipendra Pathak For This Useful Post:
Old 11-22-2013, 13:54   #27 (permalink)
dicle_gsm's Avatar
Member: 539148
Thanks Meter: 2,149
MTK Android Return Data Eroor !!! solution Here..
MTK Android ""Return Data Error !!!"" Solution Here..
If you receive this error message
Used GPGDragon Main Cable D+ D- (pinfind)
1- Run GPGDragon Exe
2- Checkbox
3- Tick Scan pinout
4- Choise USB
5- Click Start
And Enjoy The GPGDragon Box
BR,
Dicle_Gsm
The Following 4 Users Say Thank You to dicle_gsm For This Useful Post:
Old 12-16-2013, 08:26   #28 (permalink)
Member: 1428349
Sonork: 100.1597111
How to Remove Pattern Lock of Android MTK device without USB Dubbing and losing data
How to Remove Pattern Lock of Android MTK device (NOT ANDROID SPD) without USB Debugging and without Loosing User Data with Battery and Normal Cable
If your device not connected in ADB Mode, that mean your device "USB DEBUTTING" is OFF. So, you can not connect your device in ADB Mode. For this you have some idea or trick.
1. Connect your Switch OFF Android Device (Mobile) with Normal USB Cable and Battery (Do Not USE Modified Cable)
Now, If you see in the "Device manager" You can see like above picture because the DEVICE "USB DEBUGGINE" is OFF.
2. Now, Open Dragon Software in MTK Tab
3. Now, choose "Write IMEI"
4. Tick "Android IMEI"
5. Choose "USB" (Not Com port)
6. Now, Click on "Start"
7. Wait.....Now, you can see the IMEI of the Device on the Dragon Main Screen / Output Screen.
8. This means, Device is connected in ATE Mode now. And now, device also connects in ADB interface.
(To confirm this, Check the "Device Manager" of you computer. You can see "Device Name ie Samsung Android Phone" in first row and "Android Composite ADB Interface" in the second row.)
9. Now, go to Dragon "Android" Tab (Do not disconnect device from the computer. Let it be connected.)
10. Choose "Clear Pattern Lock by ADB"
11. Click "Start"
12. Wait until you see "All Done" in the Dragon Software Main Screen.
13. Now, Device will Restart.
14. Now, you can draw any kind of Pattern you like. Your device will open.
15. Enjoy!!!
Note: This method only works "Android MTK Devices", Not for "Android SPD Devices". And this method only not for Chinese Devices but Also Original Devices that is available in the Market. )
The Following 47 Users Say Thank You to GPGDragon Help For This Useful Post:
Old 12-27-2013, 20:09   #29 (permalink)
Member: 1526738
Sonork: 100.1607644
Thanks Meter: 3,561
How To use 4 REGULAR jIG For MTK SPD RDA COOLSAND
For Daily Info About These jigs
This Is tooo old but Mostly Users Not know this
So Team Decide To Make Easy For Dragon Users
daily many users again and again
use wrong way of these jig
and post again and again
you can set these as manul pinout for coolsand rda
then your file readed ok and working 100%
P-05B
Every One Know This jig
But Not know how to use right way
of this ji
This jig is for MTK SPD MSTAR COOLSAND
AND Many Others Brands
also pinout same
this jig have 5 pin
USB
1:- VCC CH
2:- D- DM
3:- D+ DP
4:- EMPTY
5:- GND
RX TX
1:- VCC
2:- RX
3:- TX
4:- Empty
5:- GND
P-10C
this jig is
For MTK SPD MSTAR COOLSAND RDA
ZTE HUAWIE AND MANY OTHERS BRANDS
BUT WE POST ABOUT COOLSAND PINOUT
D-=8
D+=6
RX 7
TX 9
RXD 3
TXD 4
P-12C
IN THIS JIG
FOR RDA COOLSAND
RX 6
TX 7
For SPD
D+:9
D-:8
Universal JIG
NOT only for RX or TX
u can use Uni jig for
USB
as
D+ D-
DP DM
Gsm.Universal
Old 03-29-2014, 03:42   #30 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,355
Android / Non Android IMEI Writing Methods
MTK 6572/6577 Android
MT6572 I9190 One Click İMEİ Repair By ADB Mode!!! IN the 5 Sec " First in The World"
8810/6820
24 hours Ambulance services for mobiles in DRAGON MOBILE HOSPITAL
MTK 6575 Android
MTK 625A CPU (Nun-Android)
MTK Other CPU (Nun-Android)
Dipendra Pathak
Page generated in 0.47631 seconds with 8 queries
