Dragon Box Chinese Phone Tool |
09-06-2014, 12:43 | #1 (permalink) |
No Life Poster Join Date: Sep 2009
Member: 1128573 Status: Offline Thanks Meter: 242 | all phone can't read flash file, pls reply suddenly my problem is rising that no phone flash file read (backup). i try one by one phone mtk, spd all are same can't read file. log >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM58 Driver Name->>>SPRD U2S Diag >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 CPU Name:6531 Can't Get Mobile Flash IC Info,Please Manual Select Flash Size... Waiting For Your Confirmation... Flash Size:0x01000000 Baud Rate is Switched To:921600 >>> Reading Flash... Error:Receive Data 0x7E Error... Error:Receive Data 0x7E Error... Error:Receive Data 0x7E Error... Error:Receive Data 0x7E Error... what's problem pls reply. thanks with best regards mahir ashab |
The Following User Says Thank You to mahir ashab For This Useful Post: |
09-06-2014, 15:02 | #2 (permalink) |
Member: 1128573 Status: Offline Thanks Meter: 242 | now i've one phone WINMAX W705. problem- phone lock CPU- SPD6531A phone readinfo ok. but read flash not done. any master here, who give me solution ? pls. reply, i appreciated if reply. thanks br |
09-06-2014, 18:13 | #3 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Wazirabad Delhi
Member: 1660122 Status: Offline Thanks Meter: 95 | Its drivers problem 10000% Here is solution 100000% Follow this.... http://forum.gsmhosting.com/vbb/f646...pital-1701380/ |
The Following User Says Thank You to sweetsonu984 For This Useful Post: |
09-11-2014, 06:14 | #4 (permalink) | |
Freak Poster Join Date: Jul 2011
Member: 1626204 Status: Offline Thanks Meter: 48 | Quote:
bro its drivers problem spd u2s diag not a spd driver uninstall and instal spd serial port diver | |
