Dragon Box Chinese Phone Tool |
06-25-2011, 08:54 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: india Age: 39
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | bassoon f800 ded.....{SOLVED} spd cpu bassoonF-800 Initializing... DA_LIB_VER_3.3.4.1 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM14 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000405A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Unknow Manufacturer ID, Flash does not exist or failed to initialize H/W. CPU: 66100000 Flash: NOR_UNKNOWN .................................................. ............................. expert mode ................ help me |
06-25-2011, 14:24 | #5 (permalink) |
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | Initializing... DA_LIB_VER_3.3.4.1 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM14 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Unknow Manufacturer ID, Flash does not exist or failed to initialize H/W. CPU: 66100000 Flash: NOR_UNKNOWN setting the Flash Parameters... Settings have been completed! CPU: 66100000 Flash: User-defined setting the Flash Parameters... Settings have been completed! CPU: 66100000 Flash: User-defined setting the Flash Parameters... Settings have been completed! CPU: 66100000 Flash: User-defined setting the Flash Parameters... Settings have been completed! CPU: 66100000 Flash: User-defined setting the Flash Parameters... Settings have been completed! CPU: 66100000 Flash: User-defined setting the Flash Parameters... Settings have been completed! CPU: 66100000 Flash: User-defined setting the Flash Parameters... Settings have been completed! CPU: 66100000 Flash: User-defined setting the Flash Parameters... Settings have been completed! CPU: 66100000 Flash: User-defined setting the Flash Parameters... Settings have been completed! CPU: 66100000 Flash: User-defined setting the Flash Parameters... Settings have been completed! CPU: 66100000 Flash: User-defined setting the Flash Parameters... Settings have been completed! CPU: 66100000 Flash: User-defined setting the Flash Parameters... Settings have been completed! CPU: 66100000 Flash: User-defined setting the Flash Parameters... Settings have been completed! CPU: 66100000 Flash: User-defined setting the Flash Parameters... Settings have been completed! CPU: 66100000 Flash: User-defined Reading FileSystem info... Failed to read FS info. |
06-25-2011, 14:25 | #6 (permalink) |
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | Start=0x00000000, Size=0x00000100, Running NV=0x00007D00 Error: Unsaft EFS Address, Please input the right format address and try again. Failed to auto format. |
06-25-2011, 14:51 | #7 (permalink) |
Cheater -Don't Deal with him- Join Date: Jun 2009 Location: PAKISTAN/UAE
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks Meter: 4,174 | Brother you need full flash your phone ( http://forum.gsmhosting.com/vbb/7465702-post4.html ) |
06-25-2011, 15:31 | #8 (permalink) |
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM14 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000525A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Unknow Manufacturer ID, Flash does not exist or failed to initialize H/W. CPU: 66100000 Flash: NOR_UNKNOWN Reading Flash... Saved file to: F:\GPG Dragon\flach file\bassoon f800 Retry=00000001 All Done. Reading Project Version... Error: Unsupport FileSystem. .................................................. ....................... flash right ,error pls help me |
06-25-2011, 16:09 | #9 (permalink) | |
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks Meter: 4,174 | Quote:
Help solve an argument !! | zeaster | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-10-2001 13:11 |
how do you solve no signal - 5110? | philipal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 09-29-2001 03:27 |
SOLVED THE FREEZE PROBLEM IN 8850!!!!! Please post below your observations.. | jsp_m | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-14-2001 19:52 |
3210 atmel solved | bone | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 03-18-2001 12:11 |
PROBLEM SOLVED (Flasher error tx=0 tx=1...) | lanzar | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-30-2000 15:47 |
