Dragon Box Chinese Phone Tool |
03-17-2014, 06:48 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: The Land Of Promise
Member: 857401 Status: Offline Sonork: 1596086 Thanks Meter: 129 | cant detect only spreadtrum my box >>> Getting Mobile Connection Info... VCC Pin: GND Pin:11, Signal Pin: >>> Scanning Mobile PinOut... >>> Please Hold the Power key... about mtk no problem im using latest firwmware trying to downgrade still problem the same any suggestion? |
The Following User Says Thank You to dabing For This Useful Post: |
03-17-2014, 07:01 | #3 (permalink) |
Insane Poster Join Date: Feb 2014 Location: India Age: 36
Member: 2133188 Status: Offline Thanks Meter: 79 | [QUOTE=dabing;10171005]only this >>> Getting Mobile Connection Info... VCC Pin: GND Pin:11, Signal Pin: >>> Scanning Mobile PinOut... >>> Please Hold the Power. it means your mobile not connect properly. there are no signal you just try with the RX TX i hope your problem will be solve Regards Naved |
03-17-2014, 08:10 | #4 (permalink) | |
Member: 857401 Status: Offline Sonork: 1596086 Thanks Meter: 129 | [QUOTE=Mohammad Naved;10171020] Quote:
ill tried to other tool | |
03-17-2014, 08:39 | #5 (permalink) |
No Life Poster Join Date: Oct 2010 Location: china Age: 35
Member: 1428349 Status: Offline Sonork: 100.1597111 Thanks Meter: 13,139 | if is not connected damage,so is box vcc no give the power to mobile cause is signal pin is empty and the vcc pin is empty |
The Following User Says Thank You to GPGDragon Help For This Useful Post: |
03-17-2014, 08:39 | #6 (permalink) |
03-18-2014, 01:19 | #8 (permalink) |
Member: 857401 Status: Offline Sonork: 1596086 Thanks Meter: 129 | volcano readed Detection initiated, connect the phone and power on it... Vcc: null Gnd: 2 4 RX: 7, TX: 9 Waiting for phone's response, press the Power on the phone. Internal version: Spreadtrum Boot Block version 2.0 Boot downloaded. Start boot please wait a moment.... BOOT Ver: Spreadtrum Boot Block version 1.2 CPU TYPE:SC6610/20 [66100000] dragon latest firmware and software >>> Getting Mobile Connection Info... VCC Pin: GND Pin:2, 4, Signal Pin:1, 3, 5, 6, 7, 8, 9, 10, 12, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... The program is stopped by the user! trying to downgrade firmware to 1.62 Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... User abort, The process stopped. i dont think my box is dead because can detect mtk back to 1.63 >>> Firmware file : 35840 Byte >>> Port poen ok...... >>> Conjunction box...... >>> Conjunction box...ok...... >>> File: 140 page. >>> Write Box...... >>> Box UpGrade successful... detect again >>> Getting Mobile Connection Info... VCC Pin: GND Pin:2, 4, Signal Pin:1, 3, 5, 6, 7, 8, 9, 10, 12, 14, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... The program is stopped by the user! nothing happen fix the problem next update |
03-18-2014, 02:57 | #9 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | @dabing, It seems that your box damage. Contact to your reseller. Thank you for your understand. BR Dipendra Pathak |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
03-18-2014, 09:01 | #10 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Wazirabad Delhi
Member: 1660122 Status: Offline Thanks Meter: 95 | Hmm i think spreadtrum tab......try select usb......not com May be your problem solve Select usb........... as per above thread already select com. |
03-21-2014, 03:18 | #14 (permalink) |
Major Poster Join Date: Mar 2012
Member: 1737595 Status: Offline Sonork: [email protected] Thanks Meter: 15 | |
