Dragon Box Chinese Phone Tool |
01-03-2014, 14:30 | #1 (permalink) |
Freak Poster Join Date: Jun 2011 Location: Bangladesh
Member: 1606143 Status: Offline Sonork: 100.1602681 Thanks Meter: 164 | Cellular Smile A103 read flash set dead Gpgdragon team plz help me Cellular Smile A103 read flash set dead. I need working pac file. read info flash id : 00002CB flash size : 20000000>512M flash name : Nand_samsungMT29C4G48MAZAPAKD Cpu name : 6820/8810 any have this file plz share here I need CELLULAR Smile A103 Pac file |
01-07-2014, 03:56 | #5 (permalink) |
No Life Poster Join Date: May 2011
Member: 1576733 Status: Offline Thanks Meter: 622 | You did not mentioned the problem before you read file? Why you read file? If the pattern or security, you have solution of ADB or Fast Boot in the dragon software. Diosa |
01-11-2014, 14:57 | #6 (permalink) |
Member: 1606143 Status: Offline Sonork: 100.1602681 Thanks Meter: 164 | sir my set cellular smile a103 (spd 6820/8810 gpgdragon) pattern lock. i try gpgdragon read info done. again read flash run start did not run and set dead. plz help me. thanks advanced. anower_08 |
02-12-2014, 11:05 | #7 (permalink) | |
Freak Poster Join Date: Dec 2012
Member: 1851477 Status: Offline Sonork: 100.1641475 Thanks Meter: 101 | Quote:
here is logs...... Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM56 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 >>> Reading Flash... | |
02-12-2014, 11:07 | #8 (permalink) |
Member: 1851477 Status: Offline Sonork: 100.1641475 Thanks Meter: 101 | i need file............ Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM56 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 >>> Reading Flash... |
02-12-2014, 11:44 | #9 (permalink) |
Freak Poster Join Date: May 2011 Location: Himachal Pradesh,Kangra,India
Member: 1587904 Status: Offline Thanks Meter: 59 | Bro since gpg dragon does not support read and write fuctions for all spd 6820/8810 it is risky........? and in your case it is easy to remove pattern lock by just format only user data i advice to just use format user data and post result |
02-13-2014, 13:13 | #11 (permalink) |
Member: 1576733 Status: Offline Thanks Meter: 622 | In my experience, no any device kills the Device.. But, you tell...........hardly believe...............still Now, search working flash file and wake up the model. DiOsA |
