Dragon Box Chinese Phone Tool |
10-25-2013, 12:07 | #1 (permalink) |
Major Poster Join Date: Jun 2010 Location: saudi
Member: 1317527 Status: Offline Sonork: kokoroko.. :P Thanks Meter: 4 | cherry mobile Snap,google patern only,know is dead after read backup..please help..? i write also the backup but got this error.. |
10-25-2013, 14:25 | #3 (permalink) |
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | we need a version that can back-up in ADB for PAC format convertion.... a must have tool for SC8810/6820 CPU... so we can find same model to make PAC file.. thanks br. FFC |
10-25-2013, 14:46 | #4 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Pakistan & UAE (Dubai) Age: 34
Member: 1526738 Status: Offline Sonork: 100.1607644 Thanks Meter: 6,688 | use Dragon Latest Version with Factory Flash File (Pac Format). And, At the time of Flashing, do not connect other box and do not touch the computer |
The Following User Says Thank You to Gsm.Universal For This Useful Post: |
10-25-2013, 14:55 | #5 (permalink) |
Member: 159757 Status: Offline Thanks Meter: 461 | we do not have PAC file for this unit but we do have lot's of this unit to make back-up file BUT as you can see READING flash file with dragon, Do more HARM than good. that's the reason why such FUNCTION added on DRAGON will make easy for US...reading dump file via ADB(rooted) so we can Convert it to PAC file and flash it on your "latest version". br. FFC |
10-25-2013, 15:07 | #6 (permalink) | |
No Life Poster Join Date: May 2011
Member: 1576733 Status: Offline Thanks Meter: 622 | Quote:
Bro, you must have both box Volcano and dragon. Volcano has all these feature that you have mentioned here. If you have both box then you no need other box which is in the market. I have both box so I am enjoying with them. Diosa | |
10-25-2013, 15:16 | #7 (permalink) | |
Member: 159757 Status: Offline Thanks Meter: 461 | Quote:
i know that other box have it BUT i just LOVE to see DRAGON adding this FUNCTION, my Favorite BOX for China. | |
07-07-2014, 04:00 | #11 (permalink) |
Freak Poster Join Date: Jul 2011 Location: 7100 island Philippines
Member: 1625066 Status: Offline Sonork: [email protected] Thanks Meter: 47 | google pattern for this model is safe to remove , many times i succesful to remove this problem *just connect the phone directly to via pc usb port without battery *set dragon box to spreadtrum boot 6820/8810 uncheck scanpinout and set to usb *tick format uncheck all except format userdata then press start *load the battery to phone while holding volume down in 5 sec *driver install must be usbserial not diagcomport and phone must not power on * after format the phone is fully restore to factory default if you need pacfile search in phillippine forum theres a lot of tested firmware there ps. cherry mobile andriod is phillipine made |
