Dragon Box Chinese Phone Tool |
10-04-2012, 11:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: jammu
Member: 750118 Status: Offline Sonork: [email protected] Thanks Meter: 51 | China samsung i9300 imei repair error DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000180000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... ProjectID Not Found. |
10-04-2012, 11:00 | #2 (permalink) |
Member: 750118 Status: Offline Sonork: [email protected] Thanks Meter: 51 | AT MODE ERROR Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Connecting, Please turn on the phone... Connected! Checking IMEI... Failed to rebulid the IMEI 1. Failed to rebulid the IMEI 2. |
10-04-2012, 11:01 | #3 (permalink) |
Member: 750118 Status: Offline Sonork: [email protected] Thanks Meter: 51 | META MODE ERROR Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Unable to locate LID, Force write... |
10-04-2012, 11:05 | #4 (permalink) |
Member: 750118 Status: Offline Sonork: [email protected] Thanks Meter: 51 | I9300 d910c_pcb01_gprs_mt6252_s01.m_szkx_d910cm01_0126_v 10_0604.bin full readed file with volcano |
10-04-2012, 11:20 | #5 (permalink) |
Member: 750118 Status: Offline Sonork: [email protected] Thanks Meter: 51 | Thanks to vignesh bro ................ |
10-04-2012, 18:39 | #7 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
ProjectID Not Found 1.read-flash same working phone write faulty phone 2.change the boot and baudrate do the job 3.it's finally may be it's hardware fault BR. Arsalan gsm2000. | |
