Dragon Box Chinese Phone Tool |
09-17-2013, 12:04 | #17 (permalink) |
No Life Poster Join Date: Oct 2011 Location: searching................
Member: 1674153 Status: Offline Sonork: 100.1607823 Thanks Meter: 179 | gpg dragon team colsend cpu read flash success please next update add write flash & format option coolsand cpu dragon team colsend cpu read flash success but long time read flash read flash (CT8853A)cpu read code (CT8853A)cpu Br .::GSM-SHOHAG::. |
The Following 3 Users Say Thank You to .::GSM-SHOHAG::. For This Useful Post: |
09-23-2013, 22:03 | #18 (permalink) |
No Life Poster Join Date: Jul 2005
Member: 161646 Status: Offline Thanks Meter: 111 | More x2-02 read firmware failed can"t read MORE X2-02 FLASH FILE >>> Please Hold the Power key... tip:Before the 1.62 Firmware Unsupport Coolsand Pinfind... Please Set pinout!!!... >>> Connecting Mobile... Mobile Connection Success... >>> Reading Mobile information... >>> CPU_ID=0x880A7000 CPU Name:>>>UNKNOWN Flash ID:0xC8401600 Flash Name:SF_GD25Q32 Flash Size:0x00400000--->4M Ram SizeŁ؛0x00200000 Unknow CPU Type;You can get the help form support.... >>> Return DATA Error!!! |
09-24-2013, 04:32 | #19 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: china Age: 35
Member: 1428349 Status: Offline Sonork: 100.1597111 Thanks Meter: 13,139 | Quote:
Please use dragon last update V3.33 | |
09-24-2013, 11:48 | #20 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Coolsand pinout set methode COOLSAND PINOUT SET METHODE UNTICK / SCAN PINOUT GO SET PINOUT TAB SET COM LIKE-GPG DRAGON BOX COMPORT CLICK-SET CONNECT PHONE JIG {1} PRESS - POWER KEY PHONE {2}CLICK - VOLTAGE {3}SELACT - MANUALY RX TX LIKE -MOSTLY COOLSAND PINOUT RXD - VOLT - 3.0 V TXD - VOLT - 0.8 V TRAI THIS HELPFUL PRESS THANX |
The Following 4 Users Say Thank You to .::THE ROCK::. For This Useful Post: |
09-24-2013, 13:16 | #21 (permalink) |
Member: 161646 Status: Offline Thanks Meter: 111 | try to read flash with version 3.33 same error >>> Please Hold the Power key... tip:Before the 1.62 Firmware Unsupport Coolsand Pinfind... Please Set pinout!!!... >>> Connecting Mobile... Mobile Connection Success... >>> Reading Mobile information... >>> CPU_ID=0x880A7000 CPU Name:>>>UNKNOWN Flash ID:0xC8401600 Flash Name:SF_GD25Q32 Flash Size:0x00400000--->4M All Done... >>> Please Hold the Power key... tip:Before the 1.62 Firmware Unsupport Coolsand Pinfind... Please Set pinout!!!... >>> Connecting Mobile... Mobile Connection Success... >>> Reading Mobile information... >>> CPU_ID=0x880A7000 CPU Name:>>>UNKNOWN Flash ID:0xC8401600 Flash Name:SF_GD25Q32 Flash Size:0x00400000--->4M Ram SizeŁ؛0x00200000 Unknow CPU Type;You can get the help form support.... >>> Return DATA Error!!! |
09-25-2013, 04:16 | #22 (permalink) | |
yahoo [email protected] | |
09-25-2013, 10:37 | #23 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Yestel m311 sf_gd25lq64 8mb READ FLASH & UNLOCK gpg dragon box YESTEL M311 SF_GD25LQ64 8MB READ SLASH & UNLOCK GPG DRAGON BOX SOLD RX TX PHONE LOCK PICK READ INFO + SET PINOUT READ FLASH UNLOCK PHONE UNLOCK PICK GPG DRAGON BOX |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
09-27-2013, 06:21 | #24 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Blutel bt 3000 read info/read flash with rx tx manualy guaide BLUTEL BT 3000 READ INFO/READ FLASH WITH RX TX MANUALY GUAIDE READ INFO READ FLASH GPG DRAGON BOX |
09-30-2013, 17:36 | #25 (permalink) |
Freak Poster Join Date: May 2011 Location: مصر
Member: 1573546 Status: Offline Thanks Meter: 21 | >>> Please Hold the Power key... Get Mobile PinOut: TXD:9 RXD:8 >>> Please Hold the Power key... tip:Before the 1.62 Firmware Unsupport Coolsand Pinfind... Please Set pinout!!!... >>> Connecting Mobile... |
09-30-2013, 19:09 | #26 (permalink) |
No Life Poster Join Date: Jan 2006 Location: algeria
Member: 217891 Status: Offline Thanks Meter: 237 | but we need add write flash plzzzzzzzzzzzzzzzzzzzzzzzzzzzz Last edited by moh_boulk17; 09-30-2013 at 19:16. |
The Following User Says Thank You to moh_boulk17 For This Useful Post: |
10-01-2013, 06:46 | #27 (permalink) |
10-21-2013, 05:55 | #30 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Aphone dt4 gd25q32 4 mb read flash & unlock by gpg dragon APHONE DT4 GD25Q32 4 MB READ FLASH & UNLOCK BY GPG DRAGON |
