Dragon Box Chinese Phone Tool |
10-11-2013, 04:53 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: tangub
Member: 823842 Status: Offline Thanks Meter: 33 | d15tv mtk 625A supported or not....Solved when i try to read info logs even I use old and latest version.. Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=8 TXD=5 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:625A, HardwareVer:CA01, SoftwareVer:0001 Failed to set Uart_AUTOBAUDSAMPLE, REG=0x80130038 |
10-11-2013, 07:00 | #2 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Pakistan & UAE (Dubai) Age: 33
Member: 1526738 Status: Offline Sonork: 100.1607644 Thanks Meter: 6,688 | use Dragon 3.33 ver with usb slect if not seccus then post here screen shot |
The Following User Says Thank You to Gsm.Universal For This Useful Post: |
10-11-2013, 11:16 | #3 (permalink) |
No Life Poster Join Date: Jul 2007 Location: tr
Member: 539148 Status: Offline Thanks Meter: 2,175 | HI, Check here, http://forum.gsmhosting.com/vbb/f646...0/#post9657833 and use the lasted 3.33 version. BR, Dicle_Gsm |
10-15-2013, 05:58 | #4 (permalink) |
Member: 823842 Status: Offline Thanks Meter: 33 | here is logs using latest version >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM28 Mobile Connection Success... CPU_ID:MT625A Hardware Version:CA01 Software Version:0001 >>> Downloading First Boot... Verifying First Boot... >>> Downloading Second Boot... >>> Authenticating BOOT... BOOT Validation Success... ================NOR Flash Info================= Flash Size:0x00400000 -> 4M Flash ID:0x00EF004000160000 Flash Name:SF_W25Q32BV ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWNUNKNOWN All Done... |
The Following User Says Thank You to jecams For This Useful Post: |
