Dragon Box Chinese Phone Tool |
02-25-2013, 14:43 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: kolkata, india
Member: 553420 Status: Offline Sonork: 100.1624012 Thanks Meter: 129 | dragon done rokea r3850 dead plz help PROBLEM> set working normal but some time restart ACTIVITIES> READ FULL FLASH AND WRITE THE READED BACKUP (WITH EXPERT MODE AND TICKED WITH ERASE OPTION) NOW>> SET DEAD INFO> >>> Getting Mobile Connection Info... VCC Pin: GND Pin:1, Signal Pin:2, 4, 7, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:2 D-:7 >>> Scanning Mobile USB Port... Detecting Mobile USB Port :COM6 Mobile Connection Success... >>> Downloading First "boot1.bin" Success... Reading the First Boots: Spreadtrum Boot Block version 1.1 >>> Downloading Second "boot2.bin" Success... >>> Mobile Info CPU Name:6800H Flash ID:0000ADA1 Flash Size:08000000->128M Flash Name:H8BCS0PG0MBP Factory Flash:NAND_HYNIX All Done... |
02-25-2013, 15:06 | #2 (permalink) |
Member: 553420 Status: Offline Sonork: 100.1624012 Thanks Meter: 129 | writing>> >>> Getting Mobile Connection Info... VCC Pin: GND Pin:1, Signal Pin:2, 4, 7, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:2 D-:7 >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM6 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:115200 >>> Mobile Info CPU Name:6800H Flash ID:0000ADA1 Flash Size:08000000->128M Flash Name:NAND_HYNIXH8BCS0PG0MBP >>> -Analyzing Flash File... Get Flash Format: User Read Full Flash... >>> -Analyzing Flash File... Flash Size:0X08400000->132M Detecting Flash File Format : Full Flash File... Document processing success... c:\temp.bin >>> Decompressing file... NV_ADD :0x01380000 SIZE: 0x00010000 BOOT_ADD :0x00008000 SIZE: 0x00018000 KERNEL_ADD :0x00060000 SIZE: 0x001FE7D0 USER_ADD :0x002E0000 SIZE: 0x00F3A6D0 MMIRES_ADD :0x013C0000 SIZE: 0x011642D0 UDISK_IMG_ADD:0x039C0800 SIZE: 0x00000000 PRELOAD_ADD :0x00000000 SIZE: 0x00000000 Waiting For Your Confirmation... >>> Writing Flash File... Write_NV... Write_BOOT... Write_KERNEL... Write_USER... Write_MMIRES... All Done... but set dead................ |
02-26-2013, 14:01 | #8 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | you can use search button for that to search flash files , @..::MOBILEPARK::.. both flashing same address so nothing change , dragon box Can repair too |
02-26-2013, 14:18 | #9 (permalink) | |
Member: 553420 Status: Offline Sonork: 100.1624012 Thanks Meter: 129 | Quote:
HERE IS SOMETHING THAT I THINK THE PROBLEM>>>> 1. I SELECT 6800H > READ FULL FLASH( IT READED BUT WITHOUT UDISK IMG AND PRELOADING)> I THINK THAT IS SOME BUG WHICH DID NOT READED FULL 2. WRITE FULL READED FLASH FILE (WITH EXPERT MODE AND TICKED WITH ERASE OPTION) > THAT WHERE I MADE MISTAKE , BECAUSE WITH FULL ERASE SET NEED FULL FILE , BUT THE READED FILE IS WITHOUT UDISK IMG AND PRELOADING 3. NOW WHEN I AM TRYING TO FIND ANOTHER FLASH FILE ALL FLASH FILES ARE WITH DIFFERENT FLASH IDS, WHERE AS MINE CPU IS SPD6800H1 AND FLASH IS NAND_HYNIXH8BCS0PG0MBP. | |
02-28-2013, 05:40 | #11 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Bro, Rokia 3850 has already done by Dragon. May be the problem is backing up file. Please write working file, I am sure that 100 % works for you. Check this thread http://forum.gsmhosting.com/vbb/8731891-post2.html BR Dipendra Pathak |
02-28-2013, 06:00 | #12 (permalink) | |
sir i am agree with you, but i can not find rokea (any model) flash file with cpu> 6800h1 and flash> NAND_HYNIXH8BCS0PG0MBP.........all other flash file downloaded not work for me | |
02-28-2013, 07:56 | #13 (permalink) |
Member: 553420 Status: Offline Sonork: 100.1624012 Thanks Meter: 129 | sir i download flash file from the given link and showing write preload error >>> Getting Mobile Connection Info... VCC Pin: GND Pin: Signal Pin:4, 5, 9, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:9 D-:5 >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM6 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 >>> Mobile Info CPU Name:6800H Flash ID:0000ADA1 Flash Size:08000000->128M Flash Name:NAND_HYNIXH8BCS0PG0MBP >>> -Analyzing Flash File... Get Flash Format: User Read Full Flash... >>> -Analyzing Flash File... Flash Size:0X04200000->66M Detecting Flash File Format : Full Flash File... Document processing success... c:\temp.bin >>> Decompressing file... NV_ADD :0x01348000 SIZE: 0x00010000 BOOT_ADD :0x00008000 SIZE: 0x00018000 KERNEL_ADD :0x00060000 SIZE: 0x00201410 USER_ADD :0x002E0000 SIZE: 0x00FBDED0 MMIRES_ADD :0x01388000 SIZE: 0x010BE490 UDISK_IMG_ADD:0x029A8400 SIZE: 0x00E27E00 PRELOAD_ADD :0x037D0200 SIZE: 0x006E4C50 Waiting For Your Confirmation... >>> Writing Flash File... Write_NV... Write_BOOT... Write_KERNEL... Write_USER... Write_MMIRES... Write_UDISK_IMG... Write_PRELOAD... >>> Return DATA Error!!! Terminated... |
02-28-2013, 13:24 | #14 (permalink) |
Member: 553420 Status: Offline Sonork: 100.1624012 Thanks Meter: 129 | I have solved my rokea R3850 dead problem and I want to share my experience>>>>>>>> ** GPG DRAGON DON'T HAVE ANY BUGS (SPD 6800H READ AND WRITE)** ** ROKEA R3850 WAS DEAD BECAUSE OF MY SPD DRIVER PROBLEM OF MY PC ** 1> FIRST WHEN I CONNECTED THE HANDSET ROKEA R3850(CPU>SPD 6800H1) WITH DRAGON IT DOES NOT DETECTED THROUGH NORMAL USB(V3 LIKE) PORT. SO I CONNECTED THE HANDSET VIA DP, DM, RXD, TXD. RESULT>> SET BOOT OK, SET READ AND WRITE OK, BUT SET MADE DEAD. 2> AFTER REPAIR XP, UNINSTALLING SPD DRIVER FROM CONTROL PANEL RESULT>> SET DETECTED WITH NORMAL USB PORT(V3 TYPE), FLASHED WITH SAME BACKUP FILE, SET ALIVE.. |
02-28-2013, 13:45 | #15 (permalink) |
Member: 553420 Status: Offline Sonork: 100.1624012 Thanks Meter: 129 | 3> NO MATTER WHAT IS THE FLASH ID OF HANDSET ([Hyundai] HY27UF081G2AM, HYNIXH8BCS0PG0MBP, H8BCS0CG0MBR ETC.) OR WHAT IS THE MODEL NAME (R3850, R5830, R212 ETC.) MATTER IS FLASH FILE SIZE 66MB OR 132MB AND TESTED OK OR NOT... |
