Dragon Box Chinese Phone Tool |
06-12-2014, 06:46 | #47 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | dragon is a nice box but eish do something on formatting spred android. ..a lot hang on logo after format even old mhorse 9500 mini..u cant remove pattern via formatting |
06-12-2014, 07:52 | #48 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Somewhere In Africa
Member: 1503666 Status: Offline Thanks Meter: 30 | Can you read,unlock Alcatel Androids it will be cool to tell us the models which will be supported by latest version otherwise will kill phones,Thanks in advance you are a great team |
06-12-2014, 10:18 | #52 (permalink) |
No Life Poster Join Date: Dec 2012 Location: Goma, Democratic Rep. Congo
Member: 1859060 Status: Offline Sonork: 100.1651029 Thanks Meter: 170 | Why gpg dragon reduced the .exe setup size after V3.47 it was about 7MB but 3.51 only 2MB.... What's the problem? and why This? |
06-12-2014, 10:21 | #53 (permalink) |
No Life Poster Join Date: Jul 2013 Location: uganda
Member: 1976974 Status: Offline Sonork: 100.1641825 Thanks Meter: 92 | GPGDRAGON KILLED TECNO P3 AFTER FOMART. Please upload flash file !!!!! >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM32 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:0000ADBC Flash Size:20000000->512M Flash Name:NAND_HYNIXH8BCS0UN0MCR CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
06-12-2014, 10:24 | #54 (permalink) |
Member: 1976974 Status: Offline Sonork: 100.1641825 Thanks Meter: 92 | Gpgdragon killed tecno p3 after fomart Please upload flash file !!!!! >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM32 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:0000ADBC Flash Size:20000000->512M Flash Name:NAND_HYNIXH8BCS0UN0MCR CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
06-13-2014, 17:51 | #58 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Quote:
