Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Dragon Box Chinese Phone Tool |
| | #1 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2005 Location: Been lonely since that day Age: 27
Member: 151871 Status: Online Thanks: 42
| Dragon School<<< Problems and Solutions >>> Last edited by rotharo; 02-28-2011 at 09:29. Reason: updated |
| The Following 52 Users Say Thank You to Faisal_Computer For This Useful Post: |
| | #2 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2010
Member: 1428349 Status: Offline Sonork: 100.1597111 Thanks: 354
| ![]() ![]() ![]() Last edited by GPGIndustries; 01-07-2011 at 05:40. Reason: post updated |
| The Following 26 Users Say Thank You to GPGDragon Help For This Useful Post: |
| | #3 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Apr 2007 Location: gpgindustries
Member: 487420 Status: Offline Sonork: 1590016 Thanks: 739
| Q: i connect the gpgdragon to computer,and install the dirver ,computer have give me the new com port,but i can't connect mobile and all no working you need use the computer behind USB port if you use the computer In front of USB port,the Power supply insufficient Last edited by Faheem Anjum; 12-20-2010 at 05:15. |
| The Following 6 Users Say Thank You to rotharo For This Useful Post: |
| | #4 (permalink) |
| how to do work with GPGdragon when Norton Antivirus Installed Double-click the Norton Antivirus software in your system tray. This opens your configuration window where you have several options. Click the "Scan" button on the left side of the window. Click "Custom Scan" and click "Options." This displays a list of options for the scanning process when Norton Antivirus detects viruses. Click "Security Risks." Click "Exceptions" and click "Add." This opens a configuration window where you add exceptions to any antivirus scan rule. Select a GPGDRAGON on your list of software exceptions. Norton lists each program installed on your computer, so you can eliminate the scanning process for your programs each time they load on your computer. Click "OK" to save your changes. After you create the exception, you can either re-scan your computer for viruses or leave the exception for the next time you do a system scan. Br Faisal_Computer |
| The Following 3 Users Say Thank You to Faisal_Computer For This Useful Post: |
| | #5 (permalink) |
| China mobile P-08A(mini 8P) after pinfind stop example Initializing... DA_LIB_VER_2.4.4.7 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=5 Connecting...Please hold on the POWER key until the red run the gpgdragon freeware setting pinout 1:H-level 6:rx 5:tx working Q:why need do this?? A: any china mobile need setting the "charge pin" like mini 8P the charge is 1 pin or 2 pin and zte cdma mobile is 8P you need give the charge H-level and rx\tx same like the pinfind Last edited by Faheem Anjum; 01-10-2011 at 08:41. |
| The Following 5 Users Say Thank You to GPGDragon Help For This Useful Post: |
| | #6 (permalink) |
| how can i change the SPD imei Spreadtrum imei change 100% form gpgdragon team all worker thanks ayaz ali post this one |
| The Following 9 Users Say Thank You to GPGDragon Help For This Useful Post: |
| | #7 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: (United States Of Islam) Age: 26
Member: 399832 Status: Online Sonork: 100.1584728 Thanks: 1,769
| problem :Error: Unsaft EFS Address, Please input the right format address and try again. Failed to auto format. solution :formatting not support in this moments you need to full flash the set from working files file can be read from other same working phone |
| The Following 12 Users Say Thank You to Faheem Anjum For This Useful Post: |
| | #8 (permalink) |
| how to slove the gpgdragon software only SPD only can read info(can't format \flash\unlock) download the last ver gpgdragon ver 1.12(if you use the gpgdragon 1.10 now is stop no working with SPD mobile) if you use the gpgdragon ver 1.12 same promber i think you have change the computer time before you need change the time same like now after run the install the new windows system and download the new gpgdragon ver 1.12 again now will working |
| The Following 7 Users Say Thank You to GPGDragon Help For This Useful Post: |
| | #9 (permalink) |
| Error: Failed to RX buffer, Please close all other program or change baudrate and try again. or you got error analyze file error while changing Imei of spd please check success solve the problem reported by our nice user !! : "some crazy error" in gpg dragon Last edited by Faisal_Computer; 01-11-2011 at 14:52. Reason: update |
| | #10 (permalink) |
| The Following 35 Users Say Thank You to GPGDragon Help For This Useful Post: |
| | #11 (permalink) |
| RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Unsupport CPU, Please select another boot and retry again! just change the boot ver to 3.952 |
| The Following 6 Users Say Thank You to Faheem Anjum For This Useful Post: |
| | #12 (permalink) |
| about the DM DP in the SPD 6600L PCB Today have one gpgdragon user connect my msn talk with me, this mobile is SPD WT6228,is New CPU,use the P-08A(mini USB) i run the gpgdragon software,select 6600L-COM and 6600L-USB but can't working,can't pinfind he is very good and help me open the mobile check the mobile have 5 connect pin have DM and DP,what is it is same like USB+ and USB- use the RJ45 connect to mobile PCB and connect to BOX rj45 working 100% but have one i can't sure,is WT6228 or no? the CPU can check it,if who have WT6228 CPU if you can help me check can it run in the gpgdragon is very good for gpgdragon user thanks |
| The Following 14 Users Say Thank You to GPGDragon Help For This Useful Post: |
| | #13 (permalink) |
| if software only read info and did not do any thing else please read it Strange problem.....( solved ) Br Faisal_Computer |
| | #14 (permalink) |
| Code: Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 Nor Flash not found. Bad Flash Chip ,just rehot or change this problem solved Code: Initializing... DA_LIB_VER_2.5.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=19 TXD=20 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Set RTC Alarm Mask failed, REG=0x802100100 Code: Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: M.RK3230436.M28202.V1.1.0.0M1226 Changing baudrate to 921600... Done. Reading full Flash... CRC error: CRC=4C92, CheckSum16=4C8A Code: Read info is done. CPU: SC6600R Flash: NAND_H8BCS0PG0MBP Set FLASH Parameters... Settings have been completed! Reading FileSystem info... Failed to read FS info. Checking box, wait... Box Firmware version: 1.43 Warning: requires firmware version 1.52, or higher... Device not found Need to update the box fimware To latest one v1.52 updater of firmware you can find on v2.01 folder Last edited by Faheem Anjum; 02-24-2011 at 05:02. |
| The Following 7 Users Say Thank You to Faheem Anjum For This Useful Post: |
| | #15 (permalink) |
| Error: Your software has been restricted. http://forum.gsmhosting.com/vbb/f646...-week-1212208/ Advice : do not change your date , when ever you try to update your box firmware must check date and time , once you install your box and its working fine PLEASE make restore point , if you want to change date and time of your pc you can do but do not turn on GPGDRAGON software , when you want to use gpgdragon software set date and time back to normal then open it , also check your computer's mother board ( mainboard) cell inside , it must be good strongly recommend to use <<<< Error: Your software has been restricted. problem solved >>>> Br Faisal_Computer Last edited by Faisal_Computer; 03-02-2011 at 07:43. |
| The Following 10 Users Say Thank You to Faisal_Computer For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
