Unlock Server
Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Dragon Box
Dragon Box Chinese Phone Tool
Old 03-02-2011, 07:46   #16 (permalink)
Faisal_Computer's Avatar
Member: 151871
how to work on gpgdragon with Avast !!
Faisal_Computer
The Following User Says Thank You to Faisal_Computer For This Useful Post:
Old 03-07-2011, 08:57   #17 (permalink)
RIZWANJAT's Avatar
Member: 1050335
Sonork: 100.1602801
<<How to work on Gpgdragon with AVG>>
Open AVG internet security
RIZWANJAT
The Following 7 Users Say Thank You to RIZWANJAT For This Useful Post:
Old 03-09-2011, 04:06   #18 (permalink)
rotharo's Avatar
Member: 487420
Sonork: 1590016
Mstar Driver Download
in some computer,Mstar after pinfind
computer tell you need install the driver
I-run the GPGDragon,
II-select Mstar and click the Start
III-after pinfind computer tip Install Driver
IV-Download the Mstar Driver and install(Like Spd Driver)
Click Download Mstar Driver:
The Following 2 Users Say Thank You to rotharo For This Useful Post:
Old 03-10-2011, 11:21   #19 (permalink)
Faheem Anjum's Avatar
Member: 399832
problem :
Formatting Flash...
AutoFormat address: start=0x00E00000, size=0x00200000
Failed to format Flash...
Try With Diffrents BootsFrom list If Still Same Then Check With Hardware (rehot CPU,FlashChip)
The Following 2 Users Say Thank You to Faheem Anjum For This Useful Post:
Old 03-13-2011, 08:30   #20 (permalink)
Member: 151871
Initializing...
DA_LIB_VER_3.2.0.7
It is sensing the pinout fast...
D-=19 D+=15
BOOT set failure, continue to scan...
its seems mobile have rx tx on board so check it and connect from rx tx points from board
also try to find out the boot key you can use # button 0 button etc
Faisal_Computer
Old 03-15-2011, 08:49   #21 (permalink)
RIZWANJAT's Avatar
Member: 1050335
Sonork: 100.1602801
<<How to work on GPG DRAGON with Norton AntiVirus>>
Open Norton AntiVirus
RIZWAN JAT
The Following 6 Users Say Thank You to RIZWANJAT For This Useful Post:
Old 03-16-2011, 06:56   #22 (permalink)
Member: 399832
Programming...
Compare Image: Enable
Error: Erase Flash
rehot flash chip and check again software not help you
Initializing...
DA_LIB_VER_3.2.0.7
It is sensing the pinout fast,please hold on the phone Power key
RXD=6 TXD=7
Connecting...Please hold on the POWER key until the red gauge is going...
Failed to read HardCode, REG=0x80000008
Error: Failed to read REG=0x80010008
Error: Failed to read REG=0x84010008
Error: Failed to read REG=0x80001008
Most if time problem comes from bad connection r Bad Flash chip (low Power ) So must check fst cable If Still Same Then Check With hardware
The Following User Says Thank You to Faheem Anjum For This Useful Post:
Old 03-20-2011, 08:23   #23 (permalink)
Member: 399832
problem : dragon box start the flashing and stop in 10% again i start flashing and now stop in 40% step by step i am trying but flashing stop in lead some % ?
now what i do this is software problem r hardware ?
Ans : this is software problem and you can solved it just by full erase the whole flash chip
how to erase whole chip flash ?
here is the whole flash chip erase address
for 8MB : 0x00800000
for 16MB: 0x01000000
for 32MB: 0x0200000
for 64MB: 0x0400000
after erase again flash the set and you will be happy to see , in this time flashing not stop to any % complete 100%
NOTE: i Test this method many times and when conform then i post here in forum !
i am sure this method will help a lot of use who face same problem using dragon
The Following 4 Users Say Thank You to Faheem Anjum For This Useful Post:
Old 03-22-2011, 06:40   #24 (permalink)
rotharo's Avatar
Member: 487420
Sonork: 1590016
GPGDragon help you slove your Mobile For MTK Chip
this time,have many many customers have a promble
like one MTK mobile,can boot,but can't flash,format,read flash(maybe can)
after will post,why the dragon box no support this mobile
we can say:mobile hardware
why i can say this
when we run the dragon,and boot select inram
we can see the flash is no support
why tip this
when the mobile cpu and flash Communication is not normal
software will tip this
so please try hardware and post the success in the forum
Old 03-22-2011, 09:12   #25 (permalink)
Member: 151871
Disable RTC IRQ failed, REG=0x80210008
Connecter problem !!
clean / change / repair will solve it
Faisal_Computer
Old 03-25-2011, 06:38   #26 (permalink)
Member: 399832
for 6217 flash chip must select ver 3.848 from boot list other boots work not Good ,
So if you have any 6217 flash chip phone and face any problem with other boot then must choose 3.484 Boot From List Must work TESTED!
Old 04-07-2011, 09:00   #27 (permalink)
Member: 399832
another simple track to solved the problem
problem : Config EMI...
H/W detection ok.
Get Project ID from phone...
Project ID: A560.SW.V00.02.YIDALONG
Changing baudrate to 921600...
the dragon box just show these info nothing more , i try with all boot but same problem Same
Ans : A simple track Can solved This problem and Sure its is software problem ( not hardware ) Need to change Baudrate to 115200 and Check will be okay
Old 04-16-2011, 15:44   #28 (permalink)
RIZWANJAT's Avatar
Member: 1050335
Sonork: 100.1602801
Problem:- Initializing...
DA_LIB_VER_3.2.1.3
D-=3 D+=0
Sense failure
Solution:-Press and hold 0+power / 0&8 button on your handset for until process
here is video(PROVE)
http://www.youtube.com/watch?v=JlRXuuACJls
And I use this method on CHINA NOKIA B200(3 sim)
RIZWAN JAT
The Following 30 Users Say Thank You to RIZWANJAT For This Useful Post:
Old 04-18-2011, 10:44   #29 (permalink)
Member: 399832
problem :
Error: Failed to read ACK, Please select or cancel the ¡°Buff PGM¡±option in the global settings.
Note : If after mark Software Show the Error again Then its mean You need To check The Phone With hardware method
problem :
Reading FileSystem info...
Error: Get Flash die baseaddress
Ans : Need to Full Flash the Set , Formatting unlocking Not Support , for phone code power on code need to read full flash and read the code from flash files for more info check sticky thread
Old 05-01-2011, 07:19   #30 (permalink)
Member: 399832
Problem : dragon box just show log
like this
Initializing...
DA_LIB_VER_3.2.2.7
BB:6225, HardwareVer:8A05, SoftwareVer:8A00
Loading boot...
INT_SYSRAM_BOOT test completed.
Loading boot...
Boot2 test completed.
Nor Flash ID: 00EC240200000000
Nand Flash ID: 0000000000000000
Read Hardware Information is done.
Project ID: LBBKY27.8.12.1.2T04M0125_M571
ans : select low baudrate from list 115200 and once again try to format the set , working set format Done !
Page generated in 0.50559 seconds with 10 queries
