Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Dragon Box Chinese Phone Tool |
| | #31 (permalink) | ||
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: (United States Of Islam) Age: 26
Member: 399832 Status: Online Sonork: 100.1584728 Thanks: 1,773
| simple Method for 6225 flash chips phones (imei changing ) in (META option) Face Problem check log Quote:
Ans : simple method to solved the problem just select AT mode From imei tab list and try once again here is the log tested some models and working good Quote:
| The Following 2 Users Say Thank You to Faheem Anjum For This Useful Post: |
| | #32 (permalink) |
| gpgdragon Support Ufone huawei G5500 Unlocking 1 make backup reading full flash 2 format the set using boot ver 2.1016 from boot list 3 rebuilt the imei using AT option From imei tab 4 DOne ! note : have a poor chip inside the phone [called mtk 6253 flash chip] so must make backup before here is the flash files link for user click here |
| | #34 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Jun 2009 Location: PAKISTAN
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks: 42
| Problem Programming... Compare Image: Enable Error: Erase Flash Solution You need remove tick from auto format option and format your handset and then try again flash Quote:
| The Following 17 Users Say Thank You to RIZWANJAT For This Useful Post: |
| | #35 (permalink) | |
| problem , i am trying to changed the imei of handset but get this problem so now what i do ? Quote:
simple method to solved this problem using dragon box , step 1 , connect the power supply + and - to phone (phone + and - ) step 2 , connect the main cable - wire to GND of phone step 3 , again try to changed the imei using tracker ( r Imei At option ) both working good already check many times , | |
| The Following 4 Users Say Thank You to Faheem Anjum For This Useful Post: |
| | #36 (permalink) |
| bitdefender anti vius,. how can i add to exclusion ![]() ![]() ![]() ![]() ![]() Thanks goes to atskie for this hard work |
| | #37 (permalink) |
| Problem:- Checking box, wait... Box Firmware version: 1.56 Device not found Solution:-You need go to http://www.gpgdragonsupport.com/download.php Download the Repair GPGDragon Driver no found.rar ![]() BR RIZWAN JAT ...WE CAN'T SEE OUR USERS IN PROBLEM..... Last edited by GPGDragon Help; 07-11-2011 at 04:08. |
| The Following 18 Users Say Thank You to RIZWANJAT For This Useful Post: |
| | #38 (permalink) |
| Error: Your software has been restricted Problem:-Error: Your software has been restricted Solution:-Just download and use this version http://www.ziddu.com/download/159722...n2.08.exe.html your problem 90% solved( and plz not say we already use this version just download and use) Br RIZWAN JAT Last edited by RIZWANJAT; 08-08-2011 at 11:06. |
| The Following 25 Users Say Thank You to RIZWANJAT For This Useful Post: |
| | #39 (permalink) |
| problem , Test ver is Over date , please get a offical Ver when i open any option from phone i get this Error (Test ver is Over date , please get a offical Ver ) how to Solved It Ans : Yes you can Solved this Error with Dragon Box ! Just make backup Flash , Format the set , and Repair imei , Phone Will be Fully repair and Back To work |
| The Following 19 Users Say Thank You to Faheem Anjum For This Useful Post: |
| | #41 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2012 Location: <attock>
Member: 1851480 Status: Offline Sonork: waiting ..<<<<>>> Thanks: 34
| 1.when we recive dead phone .we thinking how to solve the matter now .1st step chek the phone pwr suppley if he take 3 to 5ml amp 2nd now open dragon flashing tool connect the phone dragon box .3rd step ..press phone's power key when start red line then relaze the phone's power key if the red line stop with relazeing the power key now this is hardware prob so dont flash the phone now.if the phone give her deta info then u save beckup . |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
