Dragon Box Chinese Phone Tool |
07-20-2013, 15:12 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: iran-rafsanjan Age: 39
Member: 883516 Status: Offline Sonork: 100.1589551 Thanks Meter: 75 | error flash china phon cpu spread 6803h gpg dragon team pls solved this bug gpg dragon read in phon but for write the end show error and phone don't power on >>> Getting Mobile Connection Info... VCC Pin:9, GND Pin: Signal Pin:5, 7, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:7 RXD:5 >>> Please Hold the Power key... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 >>> Mobile Info CPU Name:6803H Flash ID:0000AD36 Flash Size:04000000->64M Flash Name:NAND_HYNIXH8BCS0CG0MBR >>> -Analyzing Flash File... Get Flash Format: User Read Full Flash... >>> -Analyzing Flash File... Flash Size:0X04200000->66M Detecting Flash File Format : Full Flash File... Document processing success... c:\temp.bin >>> Decompressing file... NV_ADD :0x01494000 SIZE: 0x00010000 BOOT_ADD :0x00008000 SIZE: 0x00018000 KERNEL_ADD :0x00020000 SIZE: 0x001DE4B0 USER_ADD :0x00284020 SIZE: 0x01141DF0 MMIRES_ADD :0x014B0000 SIZE: 0x017778F0 UDISK_IMG_ADD:0x034C8200 SIZE: 0x000D8000 PRELOAD_ADD :0x035A0200 SIZE: 0x00947E40 Waiting For Your Confirmation... >>> Writing Flash File... Write_NV... Write_BOOT... Write_KERNEL... Write_USER... Write_MMIRES... Write_UDISK_IMG... Write_PRELOAD... >>> Return DATA Error!!! Terminated... |
The Following User Says Thank You to hossein_mobile For This Useful Post: |
07-22-2013, 15:58 | #4 (permalink) |
Member: 883516 Status: Offline Sonork: 100.1589551 Thanks Meter: 75 | tnx for answer >>> Downloading Second Boot... Baud Rate is Switched To:921600 >>> Mobile Info CPU Name:6803H Flash ID:0000AD36 Flash Size:04000000->64M Flash Name:NAND_HYNIXH8BCS0CG0MBR >>> -Analyzing Flash File... Get Flash Format: User Read Full Flash... >>> -Analyzing Flash File... Flash Size:0X04200000->66M Detecting Flash File Format : Full Flash File... Document processing success... c:\temp.bin >>> Decompressing file... NV_ADD :0x01494000 SIZE: 0x00010000 BOOT_ADD :0x00008000 SIZE: 0x00018000 KERNEL_ADD :0x00020000 SIZE: 0x001DE4B0 USER_ADD :0x00284020 SIZE: 0x01141DF0 MMIRES_ADD :0x014B0000 SIZE: 0x017778F0 UDISK_IMG_ADD:0x034C8200 SIZE: 0x000D8000 PRELOAD_ADD :0x035A0200 SIZE: 0x00947E40 Waiting For Your Confirmation... >>> Writing Flash File... Write_NV... Write_BOOT... Write_KERNEL... Write_USER... Write_MMIRES... All Done... but dont turn on phon this file is Read the file from the phone and its good i read the phon and format it phon is off pls help |
