Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Dragon Box Chinese Phone Tool |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2005
Member: 211017 Status: Offline Thanks: 1,451
| Error read SC6610/20 (Solved) Pone power on, but have password, I need read user code Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM22 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000F45A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_UNKNOWN setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... Error: Get Flash die baseaddress I use expert mode other error Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM22 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000F45A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_UNKNOWN setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! CPU: SC6610/20 Flash: User-defined Reading FileSystem info... Error: Get Flash die baseaddress |
| | #5 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Thanks: 18
| Quote:
Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM79 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000845A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=867**************** IMEI 2=910**************** ------Auto Format Address------- Start=0x003D8000 Size =0x00028000 Read FS info...done FORMATTING Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM79 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000845A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x003D8000, Size=0x00028000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. | |
| | #8 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Apr 2008 Location: Kathmandu, Nepal
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks: 135
| Just post your flash file over here, I will try to solve your Security Code. BR DIPENDRA PATHAK |
| | #9 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2009 Location: PlashBari Age: 30
Member: 1076772 Status: Offline Sonork: 100.1601881 Thanks: 1,532
| Try to reset and check if it solves your problem. its happen sometimes with spd cpu . first at all check your ***** have good quality, check properly that device taking earth from somewhere etc.. , check is it really SPD cpu , then try to read full flash and flash your phone again. i hope your problem would be solved 100% |
| | #10 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2010
Member: 1356561 Status: Offline Thanks: 4
| GPG dragon 2.13 nokia 110L speadtrum raed info mode expert done ok Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=15 D+=16 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM34 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100025A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 230400 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_EON_EN29PL032 setting the Flash Parameters... Settings have been completed! setting the Flash Parameters... Settings have been completed! CPU: SC6600L2 Flash: User-defined Setting Register... Register=0x00000000, Val=0x000000E5 Reading FileSystem info... File System Ver: 0A IMEI 1=355020406808844 (CRC Error) IMEI 2=355020406808845 (CRC Error) ------Auto Format Address------- Start=0x003B0000 Size =0x00050000 Read FS info...done |
| | #11 (permalink) |
| GPG dragon 2.13 nokia 110L speadtrum raed flahs mode expert done ok Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=15 D+=16 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM34 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100025A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_EON_EN29PL032 setting the Flash Parameters... Settings have been completed! setting the Flash Parameters... Settings have been completed! CPU: SC6600L2 Flash: User-defined Setting Register... Register=0x00000000, Val=0x000000E5 Reading Flash... Saved file to: NOKIA 110L SPD 66007 4MB All Done. Reading Project Version... Platform Version: Z118_3216_M1_V2.02 Project Version: SC6600L_sp6601l MMI Version: SC6600L_sp6601l BASE Version: BASE_W09.20_P38.3 HW Version: SC6600L_sp6601l Project Bulid Time: 1-8-2011 14:33:19 |
| | #12 (permalink) |
| GPG dragon 2.13 nokia 110L speadtrum raed code unlock in mode expert done ok Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=15 D+=16 Searching commport...please wait... Connecting... Connected...sending boot... Spd USB-to-Serial=COM34 FDL test...OK ArmBootMode: 6600700100025A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_EON_EN29PL032 setting the Flash Parameters... Settings have been completed! setting the Flash Parameters... Settings have been completed! CPU: SC6600L2 Flash: User-defined Setting Register... Register=0x00000000, Val=0x000000E5 Connect and search Security Code... Privacy protect: 171943 Theft proof: 171943 Done. |
| | #13 (permalink) |
| GPG dragon 2.13 nokia 110L speadtrum reset in mode expert done ok Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=15 D+=16 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM34 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100025A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_EON_EN29PL032 setting the Flash Parameters... Settings have been completed! setting the Flash Parameters... Settings have been completed! CPU: SC6600L2 Flash: User-defined Setting Register... Register=0x00000000, Val=0x000000E5 Unlocking all blocks before program/erase... Unlock Done. Analyzing FileSystem... Done. Reset the user data area... done |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 12-12-2012 12:26 |
| Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 09-22-2011 15:55 |
| How unlock new nokia5110 version 5.20 ? | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 01-21-2011 06:45 |
| How unlock Nokia version 5.20 | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 07-17-1999 17:35 |
