Error: Unsaft EFS Address, Please input the right format address and try again Initializing... DA_LIB_VER_3.2.1.3 It is sensing the pinout fast... D-=4 D+=5 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM4 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x00010000, Size=0x00010000, Running NV=0xA01A7A00 Error: Unsaft EFS Address, Please input the right format address and try again. Failed to auto format. @Mods, what should be next |
next you need to check the sticky thread for this problem okay get from here once formatting not support for this chip now need to full flash the set to solved the problem and about flash files r read from another same working phone r post in flash files sub forum about need to flash files and wait for team replay |
after search not get flash file for this one Waiting for ...................................... |
firend,if the SPD can't format,you can try reset function and if you need Flash file,you need post your mobile name,your mobile cpu,flash size in here,if we have will post the line for download if some user have also post the line download |
model name plz ............................................. |
here is complete log with info Chip=SpreadTrum Action=ReadFlash FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\XX\Desktop\ Yamaar X3-i Comport=COM3 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000000000 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_3.2.1.3 It is sensing the pinout fast... D-=4 D+=5 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM4 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Reading Flash... Saved file to: C:\Documents and Settings\XX\Desktop\ Yamaar X3-i All Done. Reading Project Version... Platform Version: L6230A_HY_R1.04_20101214 Project Version: SC6600L_sp6601l_trisim MMI Version: SC6600L_sp6601l_trisim BASE Version: BASE_TRISIM_R1.0.2022 HW Version: SC6600L_sp6601l Project Bulid Time: 12-14-2010 13:52:33 |
bro this flash file on support area Quote:
did not get required file in your support area |
