Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Dragon Box
Dragon Box Chinese Phone Tool
Old 04-14-2011, 07:34   #1 (permalink)
metals's Avatar
Member: 811779
Thanks Meter: 242
Error: Unsaft EFS Address, Please input the right format address and try again
Initializing...
DA_LIB_VER_3.2.1.3
It is sensing the pinout fast...
D-=4 D+=5
Searching commport...please wait...
Connecting...
Spd USB-to-Serial=COM4
Connected...sending boot...
FDL test...OK
ArmBootMode: 6600700100025A00_01
Wait for init Commzero Security Engine...
Done.
Loading bootloader...
Done.
Changing baudrate...
Set baudrate to 921600 ok
Reading phone HW info...
Read info is done.
CPU: SC6600L2 Flash: NOR_ST_M58WR064KT
setting the Flash Parameters...
Settings have been completed!
Reading FileSystem info...
FileSystem Version: 0A
Start=0x00010000, Size=0x00010000, Running NV=0xA01A7A00
Error: Unsaft EFS Address, Please input the right format address and try again.
Failed to auto format.
@Mods,
what should be next
Old 04-14-2011, 07:36   #2 (permalink)
Faheem Anjum's Avatar
Member: 399832
Thanks Meter: 23,734
next you need to check the sticky thread for this problem
okay get from here once
formatting not support for this chip now need to full flash the set to solved the problem
and about flash files r read from another same working phone r post in flash files sub forum about need to flash files and wait for team replay
Old 04-14-2011, 07:48   #3 (permalink)
metals's Avatar
Member: 811779
Thanks Meter: 242
after search not get flash file for this one
Waiting for ......................................
Old 04-14-2011, 07:57   #4 (permalink)
rotharo's Avatar
Member: 487420
Sonork: 1590016
Thanks Meter: 3,197
firend,if the SPD can't format,you can try reset function
and if you need Flash file,you need post your mobile name,your mobile cpu,flash size in here,if we have will post the line for download
if some user have also post the line download
Old 04-14-2011, 07:59   #5 (permalink)
rizwankhan8670's Avatar
Member: 1497980
Thanks Meter: 1,206
model name plz .............................................
Old 04-14-2011, 08:21   #6 (permalink)
metals's Avatar
Member: 811779
Thanks Meter: 242
here is complete log with info
Chip=SpreadTrum
Action=ReadFlash
FlashType=NOR
boot=6600L/WT6226-USB
Expert Mode=Disable
Range[start]=0x0
Range[size]=0x0
Interface=COM
FlashFile=C:\Documents and Settings\XX\Desktop\ Yamaar X3-i
Comport=COM3
Baudrate=921600
CPU_Type=SC6600L2
CPU_ID=66007001
NOR_ID=0020881000000000
NOR_Size=8MB
NOR_Name=NOR_ST_M58WR064KT
NOR_DieCnt=1
NAND_ID=
NAND_Size=
NAND_Name=
Initializing...
DA_LIB_VER_3.2.1.3
D-=4 D+=5
Connecting...
FDL test...OK
Done.
Done.
Read info is done.
Reading Flash...
Saved file to:
All Done.
Reading Project Version...
Platform Version: L6230A_HY_R1.04_20101214
Project Version: SC6600L_sp6601l_trisim
MMI Version: SC6600L_sp6601l_trisim
BASE Version: BASE_TRISIM_R1.0.2022
HW Version: SC6600L_sp6601l
Project Bulid Time: 12-14-2010 13:52:33
Old 04-14-2011, 08:23   #7 (permalink)
r-jcomm's Avatar
Member: 601913
Sonork: 100.1597350
Thanks Meter: 651
Originally Posted by metals View Post
Initializing...
DA_LIB_VER_3.2.1.3
D-=4 D+=5
Connecting...
FDL test...OK
Done.
Done.
Read info is done.
@Mods,
what should be next
flash your phone with ok tested file
Old 04-14-2011, 08:33   #8 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Sonork: 100.1674275
Thanks Meter: 12,362
bro this flash file on support area
also check my support area then flash it
Old 04-15-2011, 10:42   #9 (permalink)
metals's Avatar
Member: 811779
Thanks Meter: 242
Brother,
did not get required file in your support area
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 12:08
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.35033 seconds with 8 queries
