Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Dragon Box
Dragon Box Chinese Phone Tool
Old 03-17-2012, 14:56   #1 (permalink)
Member: 1587904
Thanks Meter: 59
Exclamation Failed to read hard Code Error
any solution
problem from last four months
Old 03-17-2012, 16:58   #2 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
Try to connect rx tx & post result .
Old 03-17-2012, 18:06   #3 (permalink)
Member: 77002
Sonork: 100.1657194
Thanks Meter: 79
Support I have a same problem.
I cant work any phone because if I connected direct to pcb and/or connect via pinfinder its the same.
Can help please ???
Old 03-18-2012, 07:26   #4 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,308
post here the chip details will be good if you make a clear pic of pcb and upload here
Old 03-18-2012, 15:38   #5 (permalink)
Member: 77002
Sonork: 100.1657194
Thanks Meter: 79
Hi,
Its MTK chip.
Here I attach pic of the pcb.
The problem is present in 3 MTK phones what not connected. The same error
Old 03-18-2012, 15:47   #6 (permalink)
GSM SKILS's Avatar
Member: 368697
Thanks Meter: 223
Originally Posted by Dany View Post
Hi,
Its MTK chip.
use old gpg 2.11 will work
Old 03-19-2012, 04:42   #7 (permalink)
Member: 1587904
Thanks Meter: 59
ok i will try with old 2.11 version
and post the results soon
Old 03-19-2012, 07:12   #8 (permalink)
GPGDragon Help's Avatar
Member: 1428349
Sonork: 100.1597111
Thanks Meter: 13,139
first,check Box VCC and GND is normal or not?
how to check?
when you connect box to Computer
and short Box Red and Black connect (vcc and gnd)short Box speak or not?
if speak so working fine,if can't speak,so please change the new power cable first
The Following User Says Thank You to GPGDragon Help For This Useful Post:
Old 03-19-2012, 08:12   #9 (permalink)
Member: 1587904
Thanks Meter: 59
thanks sir
my gnd supply is broken
now its ok now
i also flash the phone kenxinda f6 spd
thanks a lot sir
Old 03-19-2012, 08:45   #10 (permalink)
Member: 77002
Sonork: 100.1657194
Thanks Meter: 79
I check with old version 2.11 and no get the error, only the red line not run and my notebook is stuck and I need to turn off manually
I test as you told GPGDragon Help, and when connect the box the speak is well.
Many thanks,
Old 03-19-2012, 09:17   #11 (permalink)
Member: 77002
Sonork: 100.1657194
Thanks Meter: 79
Many thanks,
I forget comment...
Also is strange that when I used the pwr ( + & -) from the box the pinfinder no work, but if I use the battery yes. I test the wires + & - and get 4.xV
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 14:52
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.22225 seconds with 10 queries
