Dragon Box Chinese Phone Tool |
10-20-2012, 14:55 | #1 (permalink) |
Banned Join Date: Jul 2012
Member: 1780950 Status: Offline Sonork: fmfahim66 Thanks Meter: 21 | gpg dragon 3.11v flash daed china samsung r5830 ...pls help?? VCC Pin:18, GND Pin:23, Signal Pin:15, 16, 17, 19, 20, 21, 22, 24, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:19 D-:17 >>> Scanning SCI Port... Detecting SCI Port :COM8 Mobile Connection Success... >>> Downloading First "boot1.bin" Success... Reading the First Boots: Spreadtrum Boot Block version 1.1 >>> Downloading Second "boot2.bin" Success... >>> Mobile Info CPU Name:6800H Flash ID:0000AD36 Flash Size:04000000->64M Flash Name:H8BCS0CG0MBR Factory Flash:NAND_HYNIX All Done... pls help urgent......pls pls pls....need flash file |
10-22-2012, 03:52 | #4 (permalink) | ||
Junior Member Join Date: Nov 2011
Member: 1689531 Status: Offline Thanks Meter: 2 | Gpg dragon 3.o6 working efficiently Gpg dragon 3.08 efficently working software Quote:
10-22-2012, 05:13 | #5 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Philippines
Member: 1325931 Status: Offline Sonork: 100.1606274 Thanks Meter: 38 | not the version of software is the problem......the first thing you do need before any operation is readflash.......if you do backed up your phone then rewrite it again,,if you don't have backup......use 128mb flash file...your phone will be alive but there's one problem....touchscreen function is reverse.... i had this problem before,until now im waiting for gpgteam to add touch screen calibration...... |
The Following User Says Thank You to wolves™ For This Useful Post: |
10-22-2012, 07:42 | #7 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Quote:
already noted working on it | |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
