Dragon Box Chinese Phone Tool |
05-16-2012, 23:15 | #1546 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Online Sonork: 100.1607001 Thanks Meter: 220 | Action=Unlock FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=0004 Code=39090 |
05-16-2012, 23:16 | #1547 (permalink) |
Member: 975275 Status: Online Sonork: 100.1607001 Thanks Meter: 220 | Chip=MTK Action=Unlock FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CC01 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=0035 |
05-16-2012, 23:16 | #1548 (permalink) |
Member: 975275 Status: Online Sonork: 100.1607001 Thanks Meter: 220 | Chip=MTK Action=Unlock FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=22 TXD=23 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A08, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=1234 |
05-16-2012, 23:18 | #1549 (permalink) |
Member: 975275 Status: Online Sonork: 100.1607001 Thanks Meter: 220 | Action=Unlock FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile=F:\GPG DRAGON\Q7 H11 Comport=COM76 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C2002500370000 NOR_Size=8MB NOR_Name=SF_MX25U6435E NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=23 D+=22 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM74 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000105A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_MX25U6435E setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 8 Privacy protect: 1234 Theft proof: 514142 PhoneLock: 1024 Done. |
05-16-2012, 23:19 | #1550 (permalink) |
Member: 975275 Status: Online Sonork: 100.1607001 Thanks Meter: 220 | Chip=MTK Action=Unlock FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A08, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=1234 Code=112752 |
05-16-2012, 23:21 | #1551 (permalink) |
Member: 975275 Status: Online Sonork: 100.1607001 Thanks Meter: 220 | Chip=MTK Action=Unlock FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CC01 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=0002 |
05-16-2012, 23:23 | #1552 (permalink) |
Member: 975275 Status: Online Sonork: 100.1607001 Thanks Meter: 220 | Chip=MTK Action=Unlock FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=0017 Code=000000 Code=196200 |
05-16-2012, 23:23 | #1553 (permalink) |
Member: 975275 Status: Online Sonork: 100.1607001 Thanks Meter: 220 | Chip=SpreadTrum Action=Unlock FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=921600 CPU_Type=SC6600L7 CPU_ID=66007009 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=3 TXD=2 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700900006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Connect and search Security Code... Theft proof: 627926 Privacy protect: 1234 PhoneLock: 627926 Done. |
05-17-2012, 11:07 | #1554 (permalink) | |
Junior Member Join Date: May 2012
Member: 1760539 Status: Offline Thanks Meter: 0 | Quote:
05-17-2012, 12:38 | #1555 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,278 | NOKIA G60 USER CODE DONE Code: Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CF00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=0002 Code=1122 Code=00113 |
05-21-2012, 12:25 | #1556 (permalink) |
Member: 975275 Status: Online Sonork: 100.1607001 Thanks Meter: 220 | Chip=MTK Action=Unlock FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CB02 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=0028 Code=37194568 |
05-21-2012, 12:37 | #1557 (permalink) |
Member: 975275 Status: Online Sonork: 100.1607001 Thanks Meter: 220 | Chip=SpreadTrum Action=Unlock FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=921600 CPU_Type=SC6600L7 CPU_ID=66007009 NOR_ID=0020884800208848 NOR_Size=8MB NOR_Name=NOR_M36C0W6050T0 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=9 TXD=7 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700900026A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_M36C0W6050T0 setting the Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 201112 PhoneLock: 201112 Done. |
05-21-2012, 12:38 | #1558 (permalink) |
Member: 975275 Status: Online Sonork: 100.1607001 Thanks Meter: 220 | Chip=MStar Action=ReadInfo FlashType=NOR boot=MSW8533C Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=921600 CPU_Type=MSW85xx CPU_ID=00408003 NOR_ID=002088C400000000 NOR_Size=16MB NOR_Name=NUMONYX_M58LR128KT NOR_DieCnt=0 NAND_ID=N/A NAND_Size=N/A NAND_Name=NAND: N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key D-=23 D+=22 Detecting USB device... USB mass storage device found[ H:] Loading bootloader... Done. Reading H/W Info... RamSize=0x00400000 BB: MSW85xx Flash: NUMONYX_M58LR128KT Read information has been completed. |
05-21-2012, 12:38 | #1559 (permalink) |
Member: 975275 Status: Online Sonork: 100.1607001 Thanks Meter: 220 | Chip=MStar Action=ReadFlash FlashType=NOR boot=MSW8533C Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=F:\GPG DRAGON\m Comport=COM76 Baudrate=921600 CPU_Type=MSW85xx CPU_ID=00408003 NOR_ID=002088C400000000 NOR_Size=16MB NOR_Name=NUMONYX_M58LR128KT NOR_DieCnt=0 NAND_ID=N/A NAND_Size=N/A NAND_Name=NAND: N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key D-=23 D+=22 Detecting USB device... USB mass storage device found[ H:] Loading bootloader... Done. Reading H/W Info... RamSize=0x00400000 BB: MSW85xx Flash: NUMONYX_M58LR128KT Read information has been completed. Reading Flash... Saved file to: F:\GPG DRAGON\m All Done. |
05-21-2012, 12:38 | #1560 (permalink) |
Member: 975275 Status: Online Sonork: 100.1607001 Thanks Meter: 220 | Chip=MStar Action=Unlock FlashType=NOR boot=MSW8533C Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=F:\GPG DRAGON\m Comport=COM76 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Searching SecCode from file... Security Code=0164 Security Code=00000000 Security Code=0000 Security Code=6277 Security Code=7777 Security Code=1133 All Done. |
