Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Dragon Box Chinese Phone Tool |
| | #1561 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2009 Location: Inside Gsmserver Cafe
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks: 251
| Chip=MStar Action=ReadInfo FlashType=NOR boot=MSW8533C Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=115200 CPU_Type=MSW85xx CPU_ID=00408003 NOR_ID=002088C400000000 NOR_Size=16MB NOR_Name=NUMONYX_M58LR128KT NOR_DieCnt=0 NAND_ID=N/A NAND_Size=N/A NAND_Name=NAND: N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key D-=23 D+=22 Detecting USB device... USB mass storage device found[ H:] Loading bootloader... Done. Reading H/W Info... RamSize=0x00400000 BB: MSW85xx Flash: NUMONYX_M58LR128KT Read information has been completed. |
| | #1562 (permalink) |
| Chip=MStar Action=ReadFlash FlashType=NOR boot=MSW8533C Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=F:\GPG DRAGON\msa Comport=COM76 Baudrate=115200 CPU_Type=MSW85xx CPU_ID=00408003 NOR_ID=002088C400000000 NOR_Size=16MB NOR_Name=NUMONYX_M58LR128KT NOR_DieCnt=0 NAND_ID=N/A NAND_Size=N/A NAND_Name=NAND: N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key D-=23 D+=22 Detecting USB device... USB mass storage device found[ H:] Loading bootloader... Done. Reading H/W Info... RamSize=0x00400000 BB: MSW85xx Flash: NUMONYX_M58LR128KT Read information has been completed. Reading Flash... Saved file to: F:\GPG DRAGON\msa All Done. |
| | #1563 (permalink) |
| Chip=MStar Action=Unlock FlashType=NOR boot=MSW8533C Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=F:\GPG DRAGON\msa Comport=COM76 Baudrate=115200 Initializing... DA_LIB_VER_4.0.3.2 Searching SecCode from file... Security Code=0164 Security Code=00000000 Security Code=0000 Security Code=2004 Security Code=91486 Security Code=227566 Security Code=7544 All Done. |
| | #1564 (permalink) |
| + +++++++++++++++++++End at: 3/24/2012 4:47:17 PM+++++++++++++++++++ -------------------Created: 3/25/2012 10:05:21 AM------------------- Chip=SpreadTrum Action=Unlock FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=115200 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=23 D+=22 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM74 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000FE5A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 6598 PhoneLock: 6598 Done. |
| | #1565 (permalink) |
| Chip=MTK Action=ReadFlash FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=F:\GPG DRAGON\Huawei G3610 Comport=COM76 Baudrate=115200 CPU_Type=MT6223 CPU_ID=7025000C NOR_ID=002088C400000000 NOR_Size=16MB NOR_Name=[ST] M30L0T7000T0, M36L0T7050T0 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=18 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A08, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: G3610_V100R001B001C96SP00S Changing baudrate to 115200... Done. Reading full Flash... Saved file to: F:\GPG DRAGON\Huawei G3610 All Done. |
| | #1566 (permalink) |
| Chip=MTK Action=network unlock FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=F:\GPG DRAGON\Huawei G3610 Comport=COM76 Baudrate=115200 Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=18 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A08, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... checking network/sp/sim lock status... Unlock done |
| | #1567 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2011 Location: SoftWare
Member: 1680962 Status: Offline Thanks: 100
| Club Rocky SuccessFull Flash Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=17 D+=16 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM4 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_K5N6433ATB setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
| | #1568 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2007
Member: 472088 Status: Offline Thanks: 45
| hello GPG DRAGON team i don't know what go wrong with my gdg-dragon box i can not spy any phone with it over 3weeks ago i try to download the latest version which is v.2.12 still doing the same-thing can any one help out of this sheet ??? |
| | #1569 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: QAISAR TELECOM SAMUNDRI FSD PK
Member: 226457 Status: Offline Sonork: 100.1604561 Thanks: 1,081
| G,five N8 Successfully Format Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=8 D+=6 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM4 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000E25A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x003D8000, Size=0x00028000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
| The Following User Says Thank You to Qaisar Mahmood For This Useful Post: |
| | #1570 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 666362 Status: Offline Thanks: 390
| Chip=SpreadTrum Action=Format FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Enable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM5 Baudrate=115200 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=4 TXD=3 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000FE6A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x003D0000, Size=0x00030000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
| | #1571 (permalink) |
| G-tide G-12 SUCCESSFULL FORMATE Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=18 TXD=16 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0001227E22102201 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: G12-A-MUL1_M15B-SP-63v01.01b02 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00750000, size=0x000B0000 All Done |
| | #1572 (permalink) |
| Major Poster ![]() ![]() Join Date: Mar 2011
Member: 1539909 Status: Offline Thanks: 0
| i have lephone 4 sim phone when i try to connect its seems Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=19 D+=20 BOOT set failure, continue to scan... plz help me what its meen |
| | #1574 (permalink) |
| Chip=SpreadTrum Action=Unlock FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=115200 CPU_Type=SC6600L7 CPU_ID=66007009 NOR_ID=00C2227E220C2201 NOR_Size=8MB NOR_Name=NOR_SVME6432UTB_MX69GL640EAXGW NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=3 TXD=2 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700900006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_SVME6432UTB_MX69GL640EAXGW setting the Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 1234 PhoneLock: 6924 Done. |
| | #1575 (permalink) |
| Chip=MTK Action=Unlock FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=115200 Initializing... DA_LIB_VER_4.0.3.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=0015 Code=927443 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
