Dragon Box Chinese Phone Tool |
05-31-2012, 06:08 | #1576 (permalink) |
Freak Poster Join Date: Aug 2007 Location: jamaica
Member: 565786 Status: Offline Thanks Meter: 11 | DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... x991 without charging port done by rx tx n grnd with infinity pinout |
05-31-2012, 15:38 | #1577 (permalink) |
No Life Poster Join Date: Oct 2007 Location: VIZAG,A.P, INDIA
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | we love forever gpgdragon its roking for unlocking spreadtrum like rox r9 By prasadak2811 at 2012-05-31 |
06-03-2012, 20:42 | #1579 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 220 | Chip=SpreadTrum Action=Unlock FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=921600 CPU_Type=SC6600L7A CPU_ID=66007019 NOR_ID=0001227E22102201 NOR_Size=8MB NOR_Name=NOR_S29GL064A_T NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=3 TXD=2 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600701900006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7A Flash: NOR_S29GL064A_T setting the Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 9 Privacy protect: 0 Privacy protect: 1983 Theft proof: 281268 PhoneLock: 1983 Done. |
06-03-2012, 20:43 | #1580 (permalink) |
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 220 | Chip=SpreadTrum Action=Unlock FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=921600 CPU_Type=SC6600L7 CPU_ID=66007009 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=18 TXD=16 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700900006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 1234 PhoneLock: 3426663 Done. |
06-03-2012, 20:44 | #1581 (permalink) |
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 220 | Chip=SpreadTrum Action=Unlock FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM76 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM74 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000145A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 1234 PhoneLock: 858542 Done. |
06-03-2012, 20:44 | #1582 (permalink) |
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 220 | Chip=SpreadTrum Action=Unlock FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM76 Baudrate=921600 CPU_Type=SC6600L7 CPU_ID=66007009 NOR_ID=0020884800208848 NOR_Size=8MB NOR_Name=NOR_M36C0W6050T0 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=9 TXD=7 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700900026A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_M36C0W6050T0 setting the Flash Parameters... Settings have been completed! Connect and search Security Code... PhoneLock: 8888 PhoneLock: 4000 PhoneLock: 0000040 Privacy protect: 24680 PhoneLock: 1994 PhoneLock: 69794 Done. |
06-05-2012, 07:38 | #1583 (permalink) |
No Life Poster Join Date: May 2007
Member: 503911 Status: Offline Thanks Meter: 195 | Lemon it717 flashed successfully after a long hard work Lemon it717 was blinking and flashed successfully after a long hard work here are logs Chip=MTK Action=Format FlashType=Nand boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM4 Baudrate=115200 CPU_Type=MT6235 CPU_ID=00000003 NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=00AD007600AD0076 NAND_Size=64MB NAND_Name=[HYNIX] HY27XS08121M Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=12 TXD=13 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 00AD007600AD0076 Read Hardware Information is done. Get Project ID from phone... Project ID: M3090_IT717_V1.1.1 Changing baudrate to 115200... Done. Formatting Flash... AutoFormat address: start=0x02000000, size=0x02000000 All Done |
06-16-2012, 15:40 | #1585 (permalink) |
No Life Poster Join Date: Oct 2011 Location: milano.itlay Age: 34
Member: 1680962 Status: Offline Thanks Meter: 334 | china l228 full flash done Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=18 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000150000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 6252D_C112BT_JLH_ML_C_SIC320A_V05 Changing baudrate to 115200... Done. Analysis the file, Some file may need a long time... The file has not been encrypted. Downloading Flash file... Pre format progress ... Done, downloading... All Done. |
06-18-2012, 15:45 | #1587 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 36
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Iball gracia mstar cpu done by dragon IBALL GRACIA MSTAR CPU DONE BY DRAG ON iball mstar cpu8533c flash id samsung_k5n2833 here file------http://www.2shared.com/file/sUkCQPyA/iball_gracia_mstar_8533c_samsu.html |
06-19-2012, 11:38 | #1588 (permalink) |
Freak Poster Join Date: Aug 2009 Location: algeria
Member: 1108432 Status: Offline Thanks Meter: 59 | sfr 116 unlock ok unlock sfr116 done by GPG Dragon. pinout for this device unlock |
The Following User Says Thank You to wissaserpent For This Useful Post: |
06-21-2012, 14:10 | #1589 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Cambodia,Battambang Province
Member: 1370639 Status: Offline Thanks Meter: 41 | Unlock code Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=4 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=1258 Code=85512 |
