Dragon Box Chinese Phone Tool |
06-28-2012, 05:52 | #1592 (permalink) |
No Life Poster Join Date: Oct 2011 Location: milano.itlay Age: 34
Member: 1680962 Status: Offline Thanks Meter: 334 | CHINA SPD A MOBILE FULL FLASH DONE Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=17 D+=19 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM6 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900025A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_M36C0W6050T0 setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
The Following User Says Thank You to M.SAQIB HUSSAIN For This Useful Post: |
06-30-2012, 12:52 | #1593 (permalink) |
Member: 1680962 Status: Offline Thanks Meter: 334 | CHINA 1120 SUCCESSFULL FORMATE Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CB02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C2002500370000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: GFIVE_E1823_FOB_6252_10A_V16.4 Changing baudrate to 115200... Done. Formatting Flash... AutoFormat address: start=0x00738000, size=0x000C8000 All Done |
07-01-2012, 10:55 | #1594 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1049819 Status: Offline Sonork: kgm Thanks Meter: 20 | HUAWEI G6600 READ CODE BY GPGDRAGON: HERE ARE LOGS- DA_LIB_VER_3.9.0.0 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=060110 Code=2588 Code=4256 |
07-05-2012, 02:31 | #1598 (permalink) |
Banned Join Date: Sep 2007
Member: 583468 Status: Offline Sonork: 100.1592004 Thanks Meter: 106 | Yxtel sucessfully repair by dragon V3 info read >>> Scan Mobile Pinout... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, USB Pinout: D+:3 D-:2 >>> Searching Mstar Driver... Get Mstar Driver H:\ --> GCREADER CPU_ID:0x00508003 CPU Name:MSW8533D Connect Mstar CPU Mobile.... >>> Downloading First Boot... >>> Downloading Second Boot... BOOT version: 0x050618 Mobile RAM: 0x00400000 Flash Name:GIGA_GD25LQ64A Flash ID:0x00C86017 Flash Size:0x00800000 -> 8M All Done... read flash >>> Searching Mstar Driver... Get Mstar Driver H:\ --> GCREADER CPU_ID:0x00508003 CPU Name:MSW8533D Connect Mstar CPU Mobile.... >>> Downloading First Boot... >>> Downloading Second Boot... BOOT version: 0x050618 Mobile RAM: 0x00400000 Flash Name:GIGA_GD25LQ64A Flash ID:0x00C86017 Flash Size:0x00800000 -> 8M >>> Reading Flash... Read Flash Done... write flash >>> Searching Mstar Driver... Get Mstar Driver H:\ --> GCREADER CPU_ID:0x00508003 CPU Name:MSW8533D Connect Mstar CPU Mobile.... >>> Downloading First Boot... >>> Downloading Second Boot... BOOT version: 0x050618 Mobile RAM: 0x00400000 Flash Name:GIGA_GD25LQ64A Flash ID:0x00C86017 Flash Size:0x00800000 -> 8M >>> Erase Flash Now.... Tip: Use Page Erase Mode,Progress bar not standard... >>> Wrtieing Flash ... All Done... |
07-06-2012, 10:23 | #1600 (permalink) |
Member: 1680962 Status: Offline Thanks Meter: 334 | CHINA j5000 SUCCESSFULL FORMATE Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000150000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: T219_14K_YF_J5000_N_SC_L27_V08 Changing baudrate to 115200... Done. Formatting Flash... AutoFormat address: start=0x001DD000, size=0x00023000 All Done |
07-06-2012, 16:01 | #1601 (permalink) |
Member: 1680962 Status: Offline Thanks Meter: 334 | MTK d616 SUCCESSFULL FORMTE Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=1 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C2002500370000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: D5211_NHX_T500_4_DUAL8_S01 Changing baudrate to 115200... Done. Formatting Flash... AutoFormat address: start=0x00768000, size=0x00098000 All Done |
07-06-2012, 18:18 | #1602 (permalink) |
No Life Poster Join Date: Oct 2005 Location: pakistan
Member: 188374 Status: Offline Sonork: 1000.2 Thanks Meter: 203 | Yxtel C6 Don With V3 >>> Scan Mobile Pinout... USB Pinout: D+:3 D-:2 >>> Searching Mstar Driver... Get Mstar Driver K:\ --> GCREADER CPU_ID:0x00508003 CPU Name:MSW8533D Connect Mstar CPU Mobile.... >>> Downloading First Boot... >>> Downloading Second Boot... BOOT version: 0x050618 Mobile RAM: 0x00400000 Flash Name:GIGA_GD25LQ64A Flash ID:0x00C86017 Flash Size:0x00800000 -> 8M >>> Erase Flash Now.... Tip: Use Page Erase Mode,Progress bar not standard... >>> Wrtieing Flash ... All Done... |
07-08-2012, 14:18 | #1603 (permalink) |
Member: 1680962 Status: Offline Thanks Meter: 334 | CHINA l228 SUCCESSFULL FORMATE Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=8 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CB02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C2002500370000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: GFIVE_E1823_FOB_6252_10A_V16.4 Changing baudrate to 115200... Done. Formatting Flash... AutoFormat address: start=0x00738000, size=0x000C8000 All Done |
07-11-2012, 15:38 | #1604 (permalink) |
Member: 1680962 Status: Offline Thanks Meter: 334 | CHINA Q9 SUCCESSFULL FORMATE Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=20 TXD=18 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C2002500350000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: C103A0.XKT01.Q9B.NORL.111105 Changing baudrate to 115200... Done. Formatting Flash... AutoFormat address: start=0x001E5000, size=0x0001B000 All Done |
07-15-2012, 12:44 | #1605 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | viva g2800s unlock done with dragen box Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C2002500350000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: G2800D_V100R002B002C343SP04 Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... checking network/sp/sim lock status... Unlock done. |
