Dragon Box Chinese Phone Tool |
07-15-2012, 15:54 | #1607 (permalink) |
Major Poster Join Date: May 2008 Location: pune
Member: 777637 Status: Offline Thanks Meter: 8 | Aircel wynncom unlocked with gpgdragon initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... checking network/sp/sim lock status... Unlock done. |
07-16-2012, 03:19 | #1608 (permalink) |
Insane Poster Join Date: May 2011
Member: 1577206 Status: Offline Sonork: amila123 Thanks Meter: 6 | Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM7 Connected...sending boot... FDL test...OK ArmBootMode: 6600701900025A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7A Flash: NOR_ST_M58WR064HU setting the Flash Parameters... Settings have been completed! Reading FileSystem info... Error: unknow. Failed to auto format. I cant format spreadtrum with gpgdragonn v2.13.help me.how i solve this big problam |
07-16-2012, 04:03 | #1609 (permalink) | |
Freak Poster Join Date: Jun 2011 Location: at my home
Member: 1602338 Status: Offline Thanks Meter: 22 | Quote:
try with reset menu | |
07-16-2012, 21:56 | #1610 (permalink) |
Freak Poster Join Date: Oct 2006 Location: United States
Member: 376302 Status: Offline Thanks Meter: 30 | Verykool I310 Tigo OK Initializing... DA_LIB_VER_4.3.6.8 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... checking network/sp/sim lock status... Unlock done. |
07-17-2012, 16:17 | #1611 (permalink) |
No Life Poster Join Date: Oct 2011 Location: milano.itlay Age: 34
Member: 1680962 Status: Offline Thanks Meter: 334 | CHINA NASAKI M22 UNLOCK DONE Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=8 D+=6 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM12 Connected...sending boot... FDL test...OK ArmBootMode: 6600700500005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6600L3 Flash: NOR_TV00570002xDGB setting the Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 1234 Privacy protect: 1111 Done. |
The Following User Says Thank You to M.SAQIB HUSSAIN For This Useful Post: |
07-17-2012, 17:03 | #1612 (permalink) |
Member: 376302 Status: Offline Thanks Meter: 30 | ZTE-G S226 Unlocked OK Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=18 TXD=17 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... checking network/sp/sim lock status... Unlock done. |
07-19-2012, 09:53 | #1614 (permalink) |
Member: 1680962 Status: Offline Thanks Meter: 334 | QMOBILE e785 UNLOCK DONE Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=18 TXD=16 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=00780 Code=0000 |
07-19-2012, 14:35 | #1615 (permalink) |
Member: 1680962 Status: Offline Thanks Meter: 334 | g-FIVE c2 SUCCESSFULL FORMATE Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C2002500370000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: L7AMM01.11.08.1.1T11M0506_MC06 Changing baudrate to 115200... Done. Formatting Flash... AutoFormat address: start=0x00738000, size=0x000C8000 All Done |
07-26-2012, 10:46 | #1617 (permalink) |
Member: 1680962 Status: Offline Thanks Meter: 334 | CHINA iPHONE SUCCESSFULL UNLOCK Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=18 TXD=19 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A03, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=7432 |
07-30-2012, 15:47 | #1620 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Basirhat
Member: 1134419 Status: Offline Sonork: 100.1621725 Thanks Meter: 452 | KARBONN K9 sucessfully flash with Dragon V3 >>> Get Mobile Connect Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scan Mobile Pinout... USB Pinout: D+:3 D-:2 >>> Searching Mstar Driver... Get Mstar Driver J:\ --> GCREADER CPU_ID:0x00408003 CPU Name:MSW8533C Connect Mstar CPU Mobile.... >>> Downloading First Boot... >>> Downloading Second Boot... BOOT version: 0x050618 Mobile RAM: 0x00400000 Flash Name:NUMONYX_M58LR128KCv Flash ID:0x0020882E Flash Size:0x01000000 -> 16M >>> Erase Flash Now.... Tip: Use Page Erase Mode,Progress bar not standard... >>> Wrtieing Flash ... All Done... |
