Dragon Box Chinese Phone Tool |
09-12-2012, 05:05 | #2116 (permalink) |
No Life Poster Join Date: Nov 2007 Location: karachi pakistan
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6225 CPU_ID=09030009 NOR_ID=0098000300000000 NOR_Size=16MB NOR_Name=[TOSHIBA] TC58FVM7TDD NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=1 TXD=10 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: E400-PK.MP.F2.V2.1 |
09-12-2012, 05:06 | #2117 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=1 TXD=10 Connecting...Please hold on the POWER key until the red gauge is going... Connecting, Please turn on the phone... Connected! Checking IMEI... Original IMEI 1= OK Failed to rebulid the IMEI 1. Original IMEI 2= 357830027998771 IMEI 2 rebuild has been implemented: 353056571383264 Need to restart the phone to verify new imei. |
09-12-2012, 05:07 | #2118 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CB02 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=358688000000158 IMEI=358688000000158 Rebulid IMEI1=353056767093690 Rebulid IMEI2=353056571383264 |
09-12-2012, 05:07 | #2119 (permalink) |
09-12-2012, 05:08 | #2120 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF006000170000 NOR_Size=8MB NOR_Name=SF_FM25Q32 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CB02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: Z101.WELCOME.V6.0-0728 |
09-12-2012, 05:09 | #2121 (permalink) |
09-12-2012, 05:09 | #2122 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\Z101.WELCOME.V6.0-0728 Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF006000170000 NOR_Size=8MB NOR_Name=SF_FM25Q32 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=11 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CB02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: Z101.WELCOME.V6.0-0728 Changing baudrate to 921600... Done. Reading full Flash... Saved file to: C:\Documents and Settings\SAEED\Desktop\Z101.WELCOME.V6.0-0728 All Done. |
09-12-2012, 05:10 | #2123 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Format FlashType=Nand boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6235 CPU_ID=00000003 NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=009800D100900015 NAND_Size=128MB NAND_Name=[TOSHIBA] TC58NVG0S3AFT Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=8 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 009800D100900015 Read Hardware Information is done. Get Project ID from phone... Project ID: TL_T7235U969_F41LI9A_00.22 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x05000000, size=0x03000000 All Done |
09-12-2012, 05:11 | #2124 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=IMEI FlashType=Nand boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=8 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Unable to locate LID, Force write... Lid=0x2_0x005D, Val=FFFFFFFFFFFFFF0F0000 Lid=0x1_0x005D, Val=FFFFFFFFFFFFFF0F0000 Lid=0x2_0x009C, Val=00000000000000000000 Lid=0x1_0x009C, Val=00000000000000000000 All done. |
09-12-2012, 05:11 | #2125 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=Nand boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6235 CPU_ID=00000003 NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=009800D100900015 NAND_Size=128MB NAND_Name=[TOSHIBA] TC58NVG0S3AFT Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=8 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 009800D100900015 Read Hardware Information is done. Get Project ID from phone... Project ID: TL_T7235U969_F41LI9A_00.22 |
09-12-2012, 05:12 | #2126 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=SC6600L7 CPU_ID=66007009 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM18 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=358776033951651 IMEI 2=358776033951677 ------Auto Format Address------- Start=0x007B0000 Size =0x00050000 Read FS info...done |
09-12-2012, 05:12 | #2127 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=WriteFlash FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=USB FlashFile=C:\Documents and Settings\SAEED\Desktop\1120 AM_GSM_CELL...AWAIS.AS Comport=COM2 Baudrate=921600 CPU_Type=SC6600L7 CPU_ID=66007009 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM18 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
09-12-2012, 05:13 | #2128 (permalink) |
09-12-2012, 05:14 | #2129 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=6 TXD=8 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A ------Auto Format Address------- Start=0x007B0000 Size =0x00050000 Read FS info...done |
09-12-2012, 05:14 | #2130 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=WriteFlash FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\2730 CPU SC6600L2 Flash NOR_ST_M58WR064KT Comport=COM2 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=6 TXD=8 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
