Dragon Box Chinese Phone Tool |
09-13-2012, 05:30 | #2251 (permalink) |
No Life Poster Join Date: Nov 2007 Location: karachi pakistan
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Action=Unlock FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=SC6600L7A CPU_ID=66007019 NOR_ID=00EC227A00010000 NOR_Size=8MB NOR_Name=NOR_K5N6433ATB NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=6 TXD=7 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600701900006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7A Flash: NOR_K5N6433ATB setting the Flash Parameters... Settings have been completed! Connect and search Security Code... Theft proof: 123456 Privacy protect: 1234 PhoneLock: 22334455 Done. |
09-13-2012, 05:30 | #2252 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=Unlock FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=SC6600L7A CPU_ID=66007019 NOR_ID=00EC227A00010000 NOR_Size=8MB NOR_Name=NOR_K5N6433ATB NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=6 TXD=7 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600701900006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7A Flash: NOR_K5N6433ATB setting the Flash Parameters... Settings have been completed! Connect and search Security Code... Theft proof: 123456 Privacy protect: 1234 PhoneLock: 22334455 Done. |
09-13-2012, 05:31 | #2253 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=Format FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile=C:\Documents and Settings\SAEED\Desktop\CPU SC661020 Flash SF_GD25Q32 Comport=COM3 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=8 D+=6 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM13 Connected...sending boot... FDL test...OK ArmBootMode: 66100000008A5A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x003B0000, Size=0x00050000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
09-13-2012, 05:31 | #2254 (permalink) |
09-13-2012, 05:32 | #2255 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=Format FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00400000 Interface=USB FlashFile=C:\Documents and Settings\SAEED\Desktop\kenxinda m2 CPU SC661020 Flash SF_GD25Q32 Comport=COM3 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=8 D+=6 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM13 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000EA5A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x003D8000, Size=0x00028000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
09-13-2012, 05:32 | #2256 (permalink) |
09-13-2012, 05:33 | #2257 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=MT6223 CPU_ID=8C00000C NOR_ID=002088BA00000000 NOR_Size=4MB NOR_Name=[NUMONYX] M36C0W5030T0 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088BA00000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: KABM7026DJWT_EAH_XL_2.02.1110 |
09-13-2012, 05:34 | #2258 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\KABM7026DJWT_EAH_XL_2.02.11 10 Comport=COM3 Baudrate=921600 CPU_Type=MT6223 CPU_ID=8C00000C NOR_ID=002088BA00000000 NOR_Size=4MB NOR_Name=[NUMONYX] M36C0W5030T0 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088BA00000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: KABM7026DJWT_EAH_XL_2.02.1110 Changing baudrate to 921600... Done. Reading full Flash... Saved file to: C:\Documents and Settings\SAEED\Desktop\KABM7026DJWT_EAH_XL_2.02.11 10 All Done. |
09-13-2012, 05:35 | #2259 (permalink) |
09-13-2012, 05:35 | #2260 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\KABM7026DJWT_EAH_XL_2.02.11 10 Comport=COM3 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Unable to locate LID, Force write... Lid=0x2_0x0056, Val=FFFFFFFFFFFFFF0F0000 Lid=0x1_0x0056, Val=FFFFFFFFFFFFFF0F0000 Lid=0x2_0x0095, Val=00000000000000000000 Lid=0x1_0x0095, Val=00000000000000000000 All done. |
09-13-2012, 05:36 | #2261 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Format FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=MT6225 CPU_ID=C4030008 NOR_ID=0098000300000000 NOR_Size=16MB NOR_Name=[TOSHIBA] TC58FVM7TDD NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: A310.V02.EnFrArPeTrSpInRuPtUr.Gf Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
09-13-2012, 05:37 | #2262 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=Format FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=USB FlashFile=C:\Documents and Settings\SAEED\Desktop\_20120716_175001_FullFlash. bin Comport=COM3 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=7 D+=10 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM27 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x00790000, Size=0x00070000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
09-13-2012, 05:38 | #2263 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=WriteFlash FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=USB FlashFile=C:\Documents and Settings\SAEED\Desktop\ZTC 6120c CPU SC6600L2 Flash NOR_ST_M58WR064KT Comport=COM3 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=7 D+=10 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM27 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
09-13-2012, 05:40 | #2264 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=1 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: D5211_DNT_J5000_S_BF_S01 |
09-13-2012, 05:40 | #2265 (permalink) |
