Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Dragon Box Chinese Phone Tool |
| | #2266 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Nov 2007 Location: karachi pakistan
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks: 251
| Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=6 TXD=8 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A ------Auto Format Address------- Start=0x007B0000 Size =0x00050000 Read FS info...done |
| | #2267 (permalink) |
| Chip=SpreadTrum Action=WriteFlash FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\2730 CPU SC6600L2 Flash NOR_ST_M58WR064KT Comport=COM2 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=6 TXD=8 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
| | #2268 (permalink) |
| Chip=SpreadTrum Action=WriteFlash FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\Karbonn K2 SPD CPU SC6600L2 Flash NOR_ST_M58WR064KT Comport=COM2 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=6 TXD=8 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
| | #2269 (permalink) |
| Chip=MTK Action=Format FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00200000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\CARRIES_M333_6252_2MB_C363K 1_KELS01_M3_WEL.120309 Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C2002500350000 NOR_Size=2MB NOR_Name=SF_MX25U3235E NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=8 TXD=6 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C2002500350000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: C363K1_KELS01_M3_WEL.120309 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x001E4000, size=0x0001C000 All Done |
| | #2270 (permalink) |
| | #2271 (permalink) |
| Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00200000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\CARRIES_M333_6252_2MB_C363K 1_KELS01_M3_WEL.120309 Comport=COM2 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=8 TXD=6 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Unable to locate LID, Force write... Lid=0x2_0x0088, Val=FFFFFFFFFFFFFFFFFFFF Lid=0x1_0x0088, Val=FFFFFFFFFFFFFFFFFFFF All done. |
| | #2272 (permalink) |
| Chip=MTK Action=WriteFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\Model A6 MTK CPU 6252 (8MB)L_2035A_V7.2.0530.P8.ML Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF006000170000 NOR_Size=8MB NOR_Name=SF_FM25Q32 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=5 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: ZM369B_61A0_V1_0_1 Changing baudrate to 921600... Done. Analysis the file, Some file may need a long time... The file has not been encrypted. Downloading Flash file... Pre format progress ... Done, downloading... All Done. |
| | #2273 (permalink) |
| Chip=MTK Action=Format FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\Model A6 MTK CPU 6252 (8MB)L_2035A_V7.2.0530.P8.ML Comport=COM2 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF006000170000 NOR_Size=8MB NOR_Name=SF_FM25Q32 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=5 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: L_2035A_V7.2.0530.P8.ML Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00768000, size=0x00098000 All Done |
| | #2274 (permalink) |
| Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\Model A6 MTK CPU 6252 (8MB)L_2035A_V7.2.0530.P8.ML Comport=COM2 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=5 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=135790246811220 IMEI=135790246811220 Rebulid IMEI1=353056343841057 Rebulid IMEI2=353056224900539 |
| | #2275 (permalink) |
| | #2276 (permalink) |
| Chip=MTK Action=Format FlashType=Nand boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6236 CPU_ID=00000000 NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=00AD00B100800055 NAND_Size=128MB NAND_Name=[HYNIX] H8BCS0PG0MBP Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key All Done |
| | #2277 (permalink) |
| Chip=MTK Action=IMEI FlashType=Nand boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=4 TXD=8 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6236, HardwareVer:8A03, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Unable to locate LID, Force write... Lid=0x2_0x0073, Val=FFFFFFFFFFFFFF0F0000 Lid=0x1_0x0073, Val=FFFFFFFFFFFFFF0F0000 Lid=0x2_0x00B1, Val=00000000000000000000 Lid=0x1_0x00B1, Val=00000000000000000000 All done. |
| | #2278 (permalink) |
| Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM2 Baudrate=921600 CPU_Type=MT6253 CPU_ID=0000000F NOR_ID=00EC240400000000 NOR_Size=16MB NOR_Name=[SAMSUNG] K5N2833ATB NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EC240400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: K2_JJK_EFARP_V2.0.1 |
| | #2279 (permalink) |
| Chip=MTK Action=ReadFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\K2_JJK_EFARP_V2.0.1 Comport=COM2 Baudrate=921600 CPU_Type=MT6253 CPU_ID=0000000F NOR_ID=00EC240400000000 NOR_Size=16MB NOR_Name=[SAMSUNG] K5N2833ATB NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EC240400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: K2_JJK_EFARP_V2.0.1 Changing baudrate to 921600... Done. Reading full Flash... User abort, freeing Download Agent, please wait... |
| | #2280 (permalink) |
| Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\K2_JJK_EFARP_V2.0.1 Comport=COM2 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A04 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=135790246811220 IMEI=135790246811220 Rebulid IMEI1=353056803146354 Rebulid IMEI2=353056137512931 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
