Dragon Box Chinese Phone Tool |
09-14-2012, 04:39 | #2296 (permalink) |
No Life Poster Join Date: Nov 2007 Location: karachi pakistan
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=MT6225 CPU_ID=8103000D NOR_ID=002088C400000000 NOR_Size=16MB NOR_Name=[ST] M30L0T7000T0, M36L0T7050T0 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=11 TXD=16 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: TL_T670P2U360_F08LO1_00.42 |
09-14-2012, 04:39 | #2297 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Format FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=MT6225 CPU_ID=8103000D NOR_ID=002088C400000000 NOR_Size=16MB NOR_Name=[ST] M30L0T7000T0, M36L0T7050T0 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=11 TXD=16 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: TL_T670P2U360_F08LO1_00.42 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
09-14-2012, 04:40 | #2298 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM3 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=11 TXD=14 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=135790246811220 IMEI=135790246811220 Rebulid IMEI1=353056189389900 Rebulid IMEI2=353056234326893 |
09-14-2012, 04:41 | #2299 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=MT6225 CPU_ID=8103000D NOR_ID=002088C400000000 NOR_Size=16MB NOR_Name=[ST] M30L0T7000T0, M36L0T7050T0 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=14 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: TL_T670P2U360_F08LO1_00.42 |
09-14-2012, 04:41 | #2300 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\TL_T670P2U360_F08LO1_00.42 Comport=COM3 Baudrate=921600 CPU_Type=MT6225 CPU_ID=8103000D NOR_ID=002088C400000000 NOR_Size=16MB NOR_Name=[ST] M30L0T7000T0, M36L0T7050T0 NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=14 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: TL_T670P2U360_F08LO1_00.42 Changing baudrate to 921600... Done. Reading full Flash... Saved file to: C:\Documents and Settings\SAEED\Desktop\TL_T670P2U360_F08LO1_00.42 All Done. |
09-14-2012, 04:42 | #2301 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=WriteFlash FlashType=NOR boot=InternalRamBoot Expert Mode=Disable Range[start]=0x0 Range[size]=0x01000000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\6700 TL_T670P2U360_F08LO1_00.42 Comport=COM3 Baudrate=921600 CPU_Type=MT6225 CPU_ID=8103000D NOR_ID=002088C400000000 NOR_Size=16MB NOR_Name=NOR_ST_M30L0T7000T0 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=14 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... Boot init completed. Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading phone HW info... Read info is done. BB: MT6225 Flash: NOR_ST_M30L0T7000T0 setting the Flash Parameters... Settings have been completed! Changing baudrate... Set baudrate to 921600 ...ok Analysis the file, Some file may need a long time... The file has not been encrypted. Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
09-14-2012, 04:43 | #2302 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=MT6253 CPU_ID=0000000F NOR_ID=0098009E00000000 NOR_Size=16MB NOR_Name=[TOSHIBA] TC58FYM7T8C NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098009E00000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: C100A3P.KCC100B.02.110618.01 |
09-14-2012, 04:43 | #2303 (permalink) |
09-14-2012, 04:44 | #2304 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Format FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=MT6253 CPU_ID=0000000F NOR_ID=0098009E00000000 NOR_Size=16MB NOR_Name=[TOSHIBA] TC58FYM7T8C NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098009E00000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: C100A3P.KCC100B.02.110618.01 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
09-14-2012, 04:44 | #2305 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A04 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=355050020984513 IMEI=355050020984513 Rebulid IMEI1=353056139813382 Rebulid IMEI2=353056063437472 |
09-14-2012, 04:45 | #2306 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=1 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=000000100010000 Rebulid IMEI1=353056346176679 |
09-14-2012, 04:45 | #2307 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=1 Connecting...Please hold on the POWER key until the red gauge is going... Connecting, Please turn on the phone... Connected! Checking IMEI... Original IMEI 1= +EGMR: "" OK IMEI 1 rebuild has been implemented: 353056346176679 Original IMEI 2= +EGMR: "" OK IMEI 2 rebuild has been implemented: 353056956137628 Need to restart the phone to verify new imei. |
09-14-2012, 04:46 | #2308 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=IMEI FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Connecting, Please turn on the phone... Connected! Checking IMEI... Original IMEI 1= +EGMR: "" OK IMEI 1 rebuild has been implemented: 353056346176679 Original IMEI 2= +EGMR: "" OK IMEI 2 rebuild has been implemented: 353056956137628 Need to restart the phone to verify new imei. |
09-14-2012, 04:46 | #2309 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Unlock FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=5 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=1122 Code=1234 Code=14759 |
09-14-2012, 04:47 | #2310 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=Format FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C2002500360000 NOR_Size=4MB NOR_Name=SF_MX25U3235E NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=8 D+=6 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM13 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000A05A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_MX25U3235E setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x003D8000, Size=0x00028000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
