Dragon Box Chinese Phone Tool |
09-14-2012, 04:47 | #2311 (permalink) |
No Life Poster Join Date: Nov 2007 Location: karachi pakistan
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Action=Unlock FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=SC6600L7 CPU_ID=66007009 NOR_ID=00EC227A00010000 NOR_Size=8MB NOR_Name=NOR_K5N6433ATB NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM13 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_K5N6433ATB setting the Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 0 Privacy protect: 9 Privacy protect: 5566 Done. |
09-14-2012, 04:48 | #2312 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=1 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: D5211_DNT_J5000_DOUBLE_BF_S03 |
09-14-2012, 04:49 | #2313 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF004000170000 NOR_Size=8MB NOR_Name=SF_W25Q32BV NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=1 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: C102A2_KELS19_WEL.111221 |
09-14-2012, 04:49 | #2314 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\C102A2_KELS19_WEL.111221 Comport=COM3 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF004000170000 NOR_Size=8MB NOR_Name=SF_W25Q32BV NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=1 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: C102A2_KELS19_WEL.111221 Changing baudrate to 921600... Done. |
09-14-2012, 04:50 | #2315 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Format FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\C102A2_KELS19_WEL.111221 Comport=COM3 Chip=SpreadTrum Action=ReadFlash FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile=C:\Documents and Settings\SAEED\Desktop\CPU SC6600L3 Flash NOR_TV00570002xDGB Comport=COM3 Baudrate=921600 CPU_Type=SC6600L3 CPU_ID=66007005 NOR_ID=0098000300000001 NOR_Size=16MB NOR_Name=NOR_TV00570002xDGB NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=9 D+=8 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM27 Connected...sending boot... FDL test...OK ArmBootMode: 6600700500005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L3 Flash: NOR_TV00570002xDGB setting the Flash Parameters... Settings have been completed! Reading Flash... Saved file to: C:\Documents and Settings\SAEED\Desktop\CPU SC6600L3 Flash NOR_TV00570002xDGB All Done. Reading Project Version... Platform Version: MOCOR_09A.W09.37_P2.06_Debug Project Version: SC6600L_sp6601l MMI Version: 8801_GLOBAL_V027 BASE Version: BASE_W09.37_P2 HW Version: M10 Project Bulid Time: 2010/02/24 19:09 BUILD:SVN_13619 LAST:SVN_12094 |
09-14-2012, 04:50 | #2316 (permalink) |
09-14-2012, 04:51 | #2317 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=SpreadTrum Action=Reset FlashType=NOR boot=6600L/WT6226/6610/6620 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile=C:\Documents and Settings\SAEED\Desktop\CPU SC6600L3 Flash NOR_TV00570002xDGB Comport=COM3 Baudrate=921600 CPU_Type=SC6600L3 CPU_ID=66007005 NOR_ID=0098000300000001 NOR_Size=16MB NOR_Name=NOR_TV00570002xDGB NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... D-=9 D+=8 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM27 Connected...sending boot... FDL test...OK ArmBootMode: 6600700500005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L3 Flash: NOR_TV00570002xDGB setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Analyzing FileSystem... Done. Reset the user data area... Note: if user partition size is more than 4MB, The phone would may take 1 minute to rebuild FileSystem after Reset Action. All Done. |
09-14-2012, 05:00 | #2318 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF004000170000 NOR_Size=8MB NOR_Name=SF_W25Q32BV NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=11 TXD=16 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer000 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: C102A2_KELS19_WEL.111221 |
09-14-2012, 05:01 | #2319 (permalink) |
09-14-2012, 05:02 | #2320 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\C102A2_KELS19_WEL.111221 Comport=COM3 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF004000170000 NOR_Size=8MB NOR_Name=SF_W25Q32BV NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=11 TXD=16 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer000 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: C102A2_KELS19_WEL.111221 Changing baudrate to 921600... Done. Reading full Flash... Saved file to: C:\Documents and Settings\SAEED\Desktop\C102A2_KELS19_WEL.111221 All Done. |
09-14-2012, 05:02 | #2321 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 5220_CQX_V10 |
09-14-2012, 05:03 | #2322 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=Format FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 5220_CQX_V10 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00768000, size=0x00098000 All Done |
09-14-2012, 05:05 | #2323 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=WriteFlash FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\BUS X1 6252 5220_CQX_V10.bin Comport=COM3 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=Unknown Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C8006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 5220_CQX_V10 Changing baudrate to 921600... Done. |
09-14-2012, 05:05 | #2324 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Chip=MTK Action=WriteFlash FlashType=NOR boot=InternalRamBoot Expert Mode=Disable Range[start]=0x0 Range[size]=0x00800000 Interface=COM FlashFile=C:\Documents and Settings\SAEED\Desktop\BUS X1 6252 5220_CQX_V10.bin Comport=COM3 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=SF_GD27Q64 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... Boot init completed. Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading phone HW info... Read info is done. BB: MT6252 Flash: SF_GD27Q64 setting the Flash Parameters... Settings have been completed! Changing baudrate... Set baudrate to 921600 ...ok Analysis the file, Some file may need a long time... The file has not been encrypted. Unlocking all blocks before program/erase... Unlock Done. |
09-14-2012, 05:05 | #2325 (permalink) |
