Dragon Box Chinese Phone Tool |
08-06-2014, 06:35 | #3136 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Tanzania
Member: 161280 Status: Offline Sonork: 100.1616990 Thanks Meter: 82 | successfully unlock huawei g3621l by gpg dragon 1.download file https://drive.google.com/file/d/0B9Y...it?usp=sharing 2.flash with this file 3.formart all done >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM14 Driver Name->>>USB Single Port Mobile Connection Success... CPU_ID:MT625A Hardware Version:CA01 Software Version:0001 >>> Downloading First Boot... Verifying First Boot... >>> Downloading Second Boot... >>> Authenticating BOOT... BOOT Validation Success... ================NOR Flash Info================= Flash Size:0x00300000 -> 3M Flash ID:0x00EF004000160000 Flash Name:SF_W25Q32BV ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWNUNKNOWN >>> Switching Baud Rate... Baud Rate is Switched To:115200 >>> Erasing Flash Now.... >>> Writing Flash File... |
The Following User Says Thank You to ::Evari77:: For This Useful Post: |
08-19-2014, 11:02 | #3139 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | i9500 copy format done >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM29 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 >>> Mobile Info Flash ID:0x00C8006000000000 Flash Name:SF_GD25LQ128 Flash Size:0x01000000 -> 16M CPU Name:6531 Baud Rate is Switched To:921600 Analyzing Mobile File System Info... Formatting Start Adress(Hex): 0x00E28000 Size(Hex): 0x001D8000 All Done... |
08-19-2014, 11:03 | #3140 (permalink) |
Member: 328688 Status: Offline Thanks Meter: 2,282 | i9500 copy formate done >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM29 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 >>> Mobile Info Flash ID:0x00C8006000000000 Flash Name:SF_GD25LQ128 Flash Size:0x01000000 -> 16M CPU Name:6531 Baud Rate is Switched To:921600 Analyzing Mobile File System Info... Formatting Start Adress(Hex): 0x00E28000 Size(Hex): 0x001D8000 All Done... |
08-22-2014, 21:04 | #3141 (permalink) |
No Life Poster Join Date: May 2010 Location: South America Age: 41
Member: 1308889 Status: Offline Sonork: 100.1608156 Thanks Meter: 266 | SUCCESSFULLY format verykool i601 >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM105 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:Spreadtrum Boot Block version 2.0 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 Baud Rate is Switched To:921600 Analyzing Mobile File System Info... Formatting Start Adress(Hex): 0x007B0000 Size(Hex): 0x00850000 All Done... |
09-05-2014, 20:44 | #3144 (permalink) |
10-05-2014, 09:20 | #3145 (permalink) |
No Life Poster Join Date: Oct 2010 Location: .::: Madina :::.
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | Q Mobile E775 Write IMEI DOne >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM159 Mobile Connection Success... CPU_ID:MT625A Hardware Version:CA01 Software Version:0001 "IMEI "options color to yellow then you can ReWrite IMEI... >>> Reading Mobile (IMEI)... IMEI 1:135790246811220 IMEI 2:358688000000158 >>> Writeing (IMEI) to Mobile... Write (IMEI_1) to Mobile Doe.. Write (IMEI_2) to Mobile Done.. >>> Reading Mobile (IMEI)... IMEI 1:353625144152637 IMEI 2:353625144152638 |
11-03-2014, 09:11 | #3147 (permalink) |
Freak Poster Join Date: Oct 2014 Location: India
Member: 2282226 Status: Offline Thanks Meter: 52 | >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:0E_8D PID:00_03 This is a MTK chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM31 Driver Name->>>MTK USB Port Mobile Connection Success... CPU_ID:MT6575 Hardware Version:CB00 Software Version:E201 >>> Downloading First Boot... >>> Authenticating BOOT... BOOT Validation Success... ================NOR Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWN ================NAND Flash Info================= Flash Size:0x20000000 -> 512M Flash ID:0x00EC00BC0000006A Flash Name:NAND_SamSungK9K4G16Q0M >>> Formatting... Formatting Start Adress(Hex): 0x16440000 Size(Hex): 0x08BC0000 All Done... |
11-25-2014, 08:33 | #3150 (permalink) |
Member: 1308889 Status: Offline Sonork: 100.1608156 Thanks Meter: 266 | Bmobile C450 read user code OK >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, 9, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:4 RXD:3 >>> Please Hold the Power key... >>> Connecting Mobile... CPU_ID:MT6260 Tip:This Mobile Support USB Flash... Hardware Version:8000 Software Version:CA00 >>> Trying to Connect Mobile with Tracker Mode... Mobile is in TRACKER MODE , you can release Power key now ... Password:3756 All Done... Some Set After Read Code,Mobile reset to Factory... |
