Dragon Box Chinese Phone Tool |
03-31-2015, 05:06 | #3166 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Shibgonj6340
Member: 844312 Status: Offline Sonork: 100.1640471 Thanks Meter: 257 | Symphony FT-36I flash file 1005 work >>> Getting Mobile Connection Info... VCC Pin: GND Pin:12, 14, 16, 18, Signal Pin:20, 21, 22, 24, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:21 D-:22 HardWare:VID:0E_8D PID:00_03 This is a MTK chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM27 Mobile Connection Success... CPU_ID:MT6260 Hardware Version:8000 Software Version:CB00 >>> Downloading First Boot... Verifying First Boot... >>> Downloading Second Boot... >>> Authenticating BOOT... BOOT Validation Success... ================NOR Flash Info================= Flash Size:0x01000000 -> 16M Flash ID:0x002C00CB00180000 Flash Name:SF_N25W128 ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWNUNKNOWN All Done... >>> Getting Mobile Connection Info... VCC Pin: GND Pin:12, 14, 16, 18, Signal Pin:20, 21, 22, 24, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:21 D-:22 HardWare:VID:0E_8D PID:00_03 This is a MTK chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM27 Driver Name->>>MTK USB Port Mobile Connection Success... CPU_ID:MT6260 Hardware Version:8000 Software Version:CB00 >>> Downloading First Boot... Verifying First Boot... >>> Downloading Second Boot... >>> Authenticating BOOT... BOOT Validation Success... ================NOR Flash Info================= Flash Size:0x01000000 -> 16M Flash ID:0x002C00CB00180000 Flash Name:SF_N25W128 ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWNUNKNOWN >>> Switching Baud Rate... Baud Rate is Switched To:921600 >>> Reading Flash... Reading Flash Done... >>> Getting Mobile Connection Info... VCC Pin: GND Pin:12, 14, 16, 18, Signal Pin:20, 21, 22, 24, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:21 D-:22 HardWare:VID:0E_8D PID:00_03 This is a MTK chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM27 Driver Name->>>MTK USB Port Mobile Connection Success... CPU_ID:MT6260 Hardware Version:8000 Software Version:CB00 >>> Trying to Connect Mobile with Tracker Mode... Mobile is in TRACKER MODE , you can release Power key now ... All Done... Some Set After Read Code,Mobile reset to Factory...SHIBGONJ MOBILE CARE Symphony FT-36I |
05-17-2015, 00:03 | #3167 (permalink) |
Freak Poster Join Date: May 2011 Location: Mexico
Member: 1572892 Status: Offline Sonork: 100.1655043 Thanks Meter: 25 | Read Code Code: >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM34 Driver Name->>>MTK USB Port Mobile Connection Success... CPU_ID:MT6260 Hardware Version:8000 Software Version:CA00 >>> Trying to Connect Mobile with Tracker Mode... Mobile is in TRACKER MODE , you can release Power key now ... Password:2170 All Done... Some Set After Read Code,Mobile reset to Factory.. |
07-02-2015, 16:34 | #3168 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: GT
Member: 44659 Status: Offline Thanks Meter: 363 | Mobo Sigma (SPD) hard reset Quote:
09-06-2015, 14:43 | #3174 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Qmobile E8 Blank IMEI Repaired Code: >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM4 Mobile Connection Success... CPU_ID:MT625A Hardware Version:CA01 Software Version:0001 "IMEI "options color to yellow then you can ReWrite IMEI... >>> Reading Mobile (IMEI)... IMEI 1:" OK IMEI 2:" OK >>> Writeing (IMEI) to Mobile... Write (IMEI_1) to Mobile Doe.. Write (IMEI_2) to Mobile Done.. >>> Reading Mobile (IMEI)... IMEI 1:357080057890XXX IMEI 2:357081057890XXX |
09-13-2015, 19:47 | #3175 (permalink) |
No Life Poster Join Date: May 2010 Location: South America Age: 41
Member: 1308889 Status: Offline Sonork: 100.1608156 Thanks Meter: 266 | successfully flashed Azumi A50c+ Software Working in the USB Mode... Pleae use USB Cable Connect mobile to computer... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM10 Driver Name->>>PreLoader USB VCOM Port Mobile Connection Success... CPU_ID:MT6582 Hardware Version:8A00 Software Version:CA01 Flash Size:0X70000000->1792M >>> Decompressing file... PERLOADER Adress£º00000800 Size:0001C4AC MBR Adress£º00C00000 Size:00000200 EBR1 Adress£º00C80000 Size:00000200 UBOOT Adress£º02920000 Size:0003E2BC BOTTING Adress£º02980000 Size:00564000 RECOVERY Adress£º03980000 Size:005C0000 SEC_RO Adress£º04980000 Size:00021000 LOGO Adress£º05000000 Size:0004076E EBR2 Address£º05300000 Size:00000200 ANDROID Adress£º05D80000 Size:38253000 CACHE Adress£º3E180000 Size:07B03000 USRDATA Adress£º45F80000 Size:00110000 >>> Downloading First Boot... >>> Authenticating BOOT... ================NOR Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWN ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWNUNKNOWN ================EMMC Flash Info================= Flash ID:0x1501004B3758564D42014740DE75B1D1 Flash Name:0x4B0001154D565837 Get Mobile Flash Size:0xD2000000 >>>>Init Mobile Perloader Data... >>>>Writeing Mobile The First Perloader Data ... >>>>Writeing Mobile The Second Perloader Data ... Wirteing MRB... Wirteing EBR... Wirteing UBOOT... Wirteing BootIMG... Wirteing RECOVERY... Wirteing SEC_RO... Wirteing LOGO... Writeing...EBR2.... Wirteing SYSTEM... Wirteing CACHE... Wirteing USERDATA... After Flash Verifying Flash File System... Verify Done!!!... All Done... |
09-28-2015, 16:16 | #3176 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | KEKAI K26 REad password miracle box read wrong code Code: Scanning USB Serial port... SU2Serial Port: COM99 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot9... CPU type: 6531A Flash type: NOR Flash ID: 00C80060(00160000) Flash Model: GD27LQ32 Flash Size: 0x400000(4.0M) Being analyzed,Wait... IMEI1 :355641060501550 IMEI2 :355641060562552 IMEI3 :358570010103893 IMEI4 :910575601400468 Screen lock: 3111 Unlock Code: 5 Unlock Code: 1234 If try all code and wrong, please read whole flash and then analyzed Search password,Wait.. Screen lock: 3111 Unlock Code: 5 >>Unlock Code: 1234 Code: >>> Analyzing Code...Please Wait... IMEI 1:355641060501550 IMEI 2:355641060562552 IMEI 3:358570010103893 IMEI 4:910575601400468 Password1: 52287 All Done... |
10-24-2015, 08:20 | #3177 (permalink) |
Member: 1308889 Status: Offline Sonork: 100.1608156 Thanks Meter: 266 | IMEI OK ZTE-G R238 >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:0E_8D PID:00_03 This is a MTK chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM25 Mobile Connection Success... CPU_ID:MT6250 Hardware Version:8B00 Software Version100 "IMEI "options color to yellow then you can ReWrite IMEI... >>> Reading Mobile (IMEI)... IMEI 1:865643010983840 IMEI 2:865643010983840 >>> Writeing (IMEI) to Mobile... Write (IMEI_1) to Mobile Doe.. Write (IMEI_2) to Mobile Done.. >>> Reading Mobile (IMEI)... IMEI 1:864128020983840 IMEI 2:865643010983840 |
