Dragon Box Chinese Phone Tool |
09-12-2011, 11:44 | #766 (permalink) |
No Life Poster Join Date: May 2007 Location: Islamic city of Marawi
Member: 502507 Status: Offline Sonork: 100.1648947 Thanks Meter: 154 | Initializing... DA_LIB_VER_3.6.0.0 It is sensing the pinout fast... RXD=3 TXD=5 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_S29GL064A_T setting the Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 327 Done. |
09-12-2011, 13:04 | #767 (permalink) | |
No Life Poster Join Date: May 2004 Location: GaZiPuR,BaNgLaDeSh Age: 38
Member: 66430 Status: Offline Sonork: 100.1601372(iN YoUr mInD) Thanks Meter: 1,987 | UBEST_D650L WRITE Successfully Quote:
09-12-2011, 13:07 | #768 (permalink) | |
Member: 66430 Status: Offline Sonork: 100.1601372(iN YoUr mInD) Thanks Meter: 1,987 | Quote:
09-12-2011, 14:18 | #769 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Gright 1130 Read user code done Initializing... DA_LIB_VER_3.6.0.2 It is sensing the pinout fast... RXD=18 TXD=16 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700900026A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_MX29GL640E_H_L setting the Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 3 Privacy protect: 5 Done. |
09-12-2011, 14:20 | #770 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: Bangladesh
Member: 1076772 Status: Offline Sonork: 100.1601881 Thanks Meter: 2,847 | Quote:
09-12-2011, 15:02 | #771 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Pakistan Age: 41
Member: 616556 Status: Offline Thanks Meter: 112 | Lawow F800 phone Code Initializing... DA_LIB_VER_3.6.0.0 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM10 Connected...sending boot... FDL test...OK ArmBootMode: 6600700500005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L3 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Connect and search Security Code... PhoneLock: 0553 PhoneLock: 0554 PhoneLock: 0531 PhoneLock: 0911 PhoneLock: 0891 PhoneLock: 0033 Privacy protect: 1122 Done. |
09-13-2011, 10:44 | #772 (permalink) |
Member: 616556 Status: Offline Thanks Meter: 112 | G3610 Ufone Unlock Done Initializing... DA_LIB_VER_3.6.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: G3610_V100R001B001C19SP03S Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
09-13-2011, 11:24 | #773 (permalink) | |
Member: 1076772 Status: Offline Sonork: 100.1601881 Thanks Meter: 2,847 | SPRINT_M5 Quote:
09-13-2011, 11:58 | #774 (permalink) |
Crazy Poster Join Date: Jul 2010 Location: guwahati (Assam) Age: 35
Member: 1344831 Status: Offline Sonork: 123 Thanks Meter: 10 | gpg dragon Initializing... DA_LIB_VER_3.6.0.0 It is sensing the pinout fast... D-=17 D+=19 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM9 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_S29GL128N_T setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x00000000, Size=0x00000200, Running NV=0x00007800 Error: Unsaft EFS Address, Please input the right format address and try again. Failed to auto format. plz solution................... |
09-13-2011, 12:37 | #775 (permalink) | |
Member: 66430 Status: Offline Sonork: 100.1601372(iN YoUr mInD) Thanks Meter: 1,987 | MAXIMUS= M15i read successfully MAXIMUS= M15i read successfully Quote:
09-13-2011, 12:53 | #776 (permalink) |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | Bleu 475x sucessfully recovered Initializing... DA_LIB_VER_3.6.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=1 TXD=10 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6226, HardwareVer:8A02, SoftwareVer:8A01 Loading boot... INT_SYSRAM_BOOT test completed. Nor Flash ID: 0001227E22202200 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: TR630V028_080922IN0_0000000 |
09-14-2011, 10:53 | #777 (permalink) |
Member: 616556 Status: Offline Thanks Meter: 112 | Q9 Nokia Format Initializing... DA_LIB_VER_3.6.0.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098009E00000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: C100A3PLUS.Q9.06.110425.01 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
09-14-2011, 10:55 | #778 (permalink) |
Member: 616556 Status: Offline Thanks Meter: 112 | G88 G MobileFormat Initializing... DA_LIB_VER_3.6.0.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EC240400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: C100A3PLUS.JHZ.G8801.110322.01 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
09-15-2011, 10:45 | #779 (permalink) |
Member: 616556 Status: Offline Thanks Meter: 112 | G9 Nasaki Formate Done Initializing... DA_LIB_VER_3.6.0.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098009E00000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: Z100.FET-C5.NASAKI-V3-0525 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
09-15-2011, 11:06 | #780 (permalink) |
Member: 616556 Status: Offline Thanks Meter: 112 | F800 Basoon Format Done Initializing... DA_LIB_VER_3.6.0.2 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM10 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x007A0000, Size=0x00050000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
