Dragon Box Chinese Phone Tool |
09-24-2011, 05:02 | #811 (permalink) |
Cheater -Don't Deal with him- Join Date: Sep 2010
Member: 1390802 Status: Offline Thanks Meter: 1,101 | DA_LIB_VER_3.6.0.2 It is sensing the pinout fast,please hold on the phone Power key RXD=5 TXD=8 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: U20_BENGAL__09A.W09.36__H0006 Changing baudrate to 921600... Done. Analysis the file, Some file may need a long time... The file has not been encrypted. Downloading Flash file... All Done. |
09-24-2011, 05:04 | #812 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Initializing... DA_LIB_VER_3.6.0.2 It is sensing the pinout fast... RXD=16 TXD=18 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700500006A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L3 Flash: NOR_K5L2731CAM setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x00F00000, Size=0x000E0000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
09-24-2011, 05:08 | #813 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Initializing... DA_LIB_VER_3.6.0.0 It is sensing the pinout fast... D-=21 D+=19 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM19 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 460800 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_M36C0W5030T0 setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
09-24-2011, 05:08 | #814 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Initializing... DA_LIB_VER_3.6.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C2002500370000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: E205_PP_F3_BE_14 Changing baudrate to 460800... Done. Formatting Flash... AutoFormat address: start=0x00710000, size=0x000F0000 All Done |
09-24-2011, 05:09 | #815 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Initializing... DA_LIB_VER_3.6.0.0 It is sensing the pinout fast... RXD=6 TXD=7 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064HU setting the Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 9 Privacy protect: 0 Privacy protect: 01681663 PhoneLock: 01677065 Done. |
09-24-2011, 05:09 | #816 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Initializing... DA_LIB_VER_3.6.0.0 Connecting...Please hold on the POWER key until the red gauge is going... BB:6253, HardwareVer:8A00, SoftwareVer:8A04 Loading boot... Boot init completed. Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading phone HW info... Read info is done. BB: MT6253T Flash: NOR_S29VS128R_T setting the Flash Parameters... Settings have been completed! Changing baudrate... Set baudrate to 460800 ...ok Analysis the file, Some file may need a long time... The file has not been encrypted. Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
09-24-2011, 05:09 | #817 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Initializing... DA_LIB_VER_3.6.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=18 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C2002500370000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: KAAU2011P_BGE_En_Be_1.00.713 Changing baudrate to 460800... Done. Reading full Flash... Saved file to: C:\Documents and Settings\GOLDEN A H SHARIF\Desktop\jjjjjjjjjjjjjjjjjjjjjjjllllllllllll llllllllllll All Done. |
09-24-2011, 05:10 | #818 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Initializing... Connected...sending boot... DA_LIB_VER_3.5.0.2 Auto reset and search the USB-to-Serial... FDL test...OK ArmBootMode: 6600700100025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M36LOR7050U3ZS setting the Flash Parameters... Settings have been completed! Reading FileSystem info... Connecting... Spd USB-to-Serial=COM6 |
09-24-2011, 05:10 | #819 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Initializing... DA_LIB_VER_3.5.0.2 It is sensing the pinout fast... D-=10 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM16 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M36LOR7050U3ZS setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Analyzing FileSystem... Done. Reset the user data area... Note: if user partition size is more than 4MB, The phone would may take 1 minute to rebuild FileSystem after Reset Action. All Done. |
09-24-2011, 05:10 | #820 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Initializing... DA_LIB_VER_3.5.0.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=12 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=0006 Code=3647 |
09-24-2011, 05:11 | #821 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Initializing... DA_LIB_VER_3.5.0.2 It is sensing the pinout fast,please hold on the phone Power key RXD=19 TXD=18 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098009E00000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: P5302_CY_ATV_5701_FN_V6.5 |
09-24-2011, 05:11 | #822 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Initializing... DA_LIB_VER_3.6.0.0 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=1122 |
09-24-2011, 05:11 | #823 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Initializing... DA_LIB_VER_3.6.0.0 It is sensing the pinout fast,please hold on the phone Power key D-=4 D+=3 Detecting USB device... USB mass storage device found[ I:] Loading bootloader... Done. Reading H/W Info... RamSize=0x00400000 BB: MSW85xx Flash: NUMONYX_M58LR128KC Read information has been completed. Reading Flash... Saved file to: C:\Documents and Settings\OMUR_Faruk\My Documents\smart All Done. |
09-24-2011, 05:12 | #824 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Initializing... DA_LIB_VER_3.6.0.0 Auto analyzing... IMEI has been detected in rom-image. count=2 Rebulid IMEI: [357866030699741] to [123456789012340] Create out file: G:\CHINA READ FILE\CHINA-NOKIA_X-1\CHINA-NOKIA_X-1\Rebulid_IMEI_CHINA_X1 All Done. |
09-24-2011, 05:24 | #825 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Initializing... DA_LIB_VER_3.6.0.2 It is sensing the pinout fast,please hold on the phone Power key RXD=5 TXD=8 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: U20_BENGAL__09A.W09.36__H0006 Changing baudrate to 921600... Done. Analysis the file, Some file may need a long time... The file has not been encrypted. Downloading Flash file... All Done. |
