Dragon Box Chinese Phone Tool |
03-02-2012, 09:33 | #1411 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=4 TXD=3 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600701900006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 230400 is ok Reading phone HW info... Read info is done. CPU: SC6600L7A Flash: NOR_S29GL064A_T setting the Flash Parameters... Settings have been completed! Connect and search Security Code... PhoneLock: 1985 Privacy protect: 1998 Done. |
03-02-2012, 09:59 | #1412 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 236743 Status: Offline Thanks Meter: 113 | forme d555 unlocked succesfuiiy -------------------Created: 3/2/2012 2:14:45 PM------------------- Chip=SpreadTrum Action=Unlock FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=115200 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000E26A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 1234 PhoneLock: 9335 Done. +++++++++++++++++++End at: 3/2/2012 2:15:04 PM+++++++++++++++++++ |
03-02-2012, 12:05 | #1413 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | microx x263 unlock done... read info.. Code: Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=8 TXD=6 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CB02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C2002500370000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 1511A_0101_V0914 Code: Initializing... DA_LIB_VER_4.0.3.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=8 TXD=6 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CB02 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=0001 Code=6606 |
03-02-2012, 14:39 | #1414 (permalink) |
Freak Poster Join Date: Apr 2007 Location: india
Member: 482019 Status: Offline Thanks Meter: 100 | Chip=MTK Action=Format FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM26 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00C2002500370000 NOR_Size=8MB NOR_Name=SF_MX25U6435E NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=18 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C2002500370000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: Celkon_C20_W220_S05_110609 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00730000, size=0x000D0000 All Done |
03-04-2012, 08:23 | #1415 (permalink) |
No Life Poster Join Date: Jan 2011 Location: in your Heart
Member: 1484062 Status: Offline Sonork: 1610135 Thanks Meter: 218 | Jaga Mobile imei change done. Initializing... DA_LIB_VER_3.9.0.0 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=012345678910234 IMEI=012345678910234 Rebulid IMEI1=353056296800911 Rebulid IMEI2=353056767970563 |
03-05-2012, 22:04 | #1416 (permalink) |
No Life Poster Join Date: May 2007 Location: MOROCCO
Member: 510826 Status: Offline Thanks Meter: 183 | Unlock BB 8520 IMEI: 355931036117981 MEP: MEP-07723-005 ******************************************* MEP Codes: MEP1 :9725470587944790 MEP2 :0581467820632994 MEP3 :3700276754247530 MEP4 :0996623539844215 MEP5 :2824338541773260 ******************************************* |
03-06-2012, 08:13 | #1417 (permalink) |
Member: 482019 Status: Offline Thanks Meter: 100 | celkon c770m mstar Chip=MStar Action=ReadInfo FlashType=NOR boot=MSW8533C Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM26 Baudrate=115200 CPU_Type=MSW85xx CPU_ID=00408003 NOR_ID=0020882E00000000 NOR_Size=16MB NOR_Name=NUMONYX_M58LR128KC NOR_DieCnt=0 NAND_ID=N/A NAND_Size=N/A NAND_Name=NAND: N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key D-=23 D+=22 Detecting USB device... USB mass storage device found[ I:] Loading bootloader... Done. Reading H/W Info... RamSize=0x00400000 BB: MSW85xx Flash: NUMONYX_M58LR128KC Read information has been completed. |
03-06-2012, 08:14 | #1418 (permalink) |
Member: 482019 Status: Offline Thanks Meter: 100 | celkon c770m mstar Chip=MStar Action=ReadFlash FlashType=NOR boot=MSW8533C Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=F:\china flash files\celkon c770m\c770m Comport=COM26 Baudrate=115200 CPU_Type=MSW85xx CPU_ID=00408003 NOR_ID=0020882E00000000 NOR_Size=16MB NOR_Name=NUMONYX_M58LR128KC NOR_DieCnt=0 NAND_ID=N/A NAND_Size=N/A NAND_Name=NAND: N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key D-=23 D+=22 Detecting USB device... USB mass storage device found[ I:] Loading bootloader... Done. Reading H/W Info... RamSize=0x00400000 BB: MSW85xx Flash: NUMONYX_M58LR128KC Read information has been completed. Reading Flash... Saved file to: F:\china flash files\celkon c770m\c770m All Done. |
03-06-2012, 08:15 | #1419 (permalink) |
Member: 482019 Status: Offline Thanks Meter: 100 | Chip=MStar Action=Unlock FlashType=NOR boot=MSW8533C Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=F:\china flash files\celkon c770m\c770m Comport=COM26 Baudrate=115200 Initializing... DA_LIB_VER_4.0.3.2 Searching SecCode from file... Security Code=00000000 Security Code=0000 All Done. |
03-06-2012, 08:15 | #1420 (permalink) |
Member: 482019 Status: Offline Thanks Meter: 100 | Chip=MStar Action=WriteFlash FlashType=NOR boot=MSW8533C Expert Mode=Disable Range[start]=0x0 Range[size]=0x01000000 Interface=COM FlashFile=F:\china flash files\celkon c770m\c770m Comport=COM26 Baudrate=115200 CPU_Type=MSW85xx CPU_ID=00408003 NOR_ID=0020882E00000000 NOR_Size=16MB NOR_Name=NUMONYX_M58LR128KC NOR_DieCnt=0 NAND_ID=N/A NAND_Size=N/A NAND_Name=NAND: N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key D-=23 D+=22 Detecting USB device... USB mass storage device found[ I:] Loading bootloader... Done. Reading H/W Info... RamSize=0x00400000 BB: MSW85xx Flash: NUMONYX_M58LR128KC Read information has been completed. Erasing Flash... Done. Programming... All Done. |
03-12-2012, 14:54 | #1421 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | M5130 SC6610/20 PRIVACY CODE READ: Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM12 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000A05A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 7897 PhoneLock: 0088 Done. |
03-13-2012, 13:35 | #1422 (permalink) |
No Life Poster Join Date: Jul 2007 Location: https://www.facebook.com/group
Member: 556396 Status: Offline Sonork: 100.1609417 Thanks Meter: 363 | lefone u 505 write falash don with dragon Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=10 TXD=11 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100026A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
03-14-2012, 13:16 | #1423 (permalink) |
No Life Poster Join Date: Sep 2009 Location: I-N-D-I-A Age: 33
Member: 1119248 Status: Offline Sonork: 000000000000000000000000 Thanks Meter: 139 | 83xx unlock done Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key D-=23 D+=22 Detecting USB device... USB mass storage device found[ I:] Auto FlashType changed: Nor->Nand Loading bootloader... Done. Reading H/W Info... RamSize=0x02000000 BB: MSW85xx Flash: NAND_TC58NVG0S3AFT_3 Read information has been completed read flash Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key D-=23 D+=22 Detecting USB device... USB mass storage device found[ I:] Auto FlashType changed: Nor->Nand Loading bootloader... Done. Reading H/W Info... RamSize=0x02000000 BB: MSW85xx Flash: NAND_TC58NVG0S3AFT_3 Read information has been completed. Reading Flash... Saved file to: C:\Documents and Settings\satpal\My Documents\china unlock Initializing... DA_LIB_VER_4.0.3.2 Searching SecCode from file... Security Code=0954 Security Code=0164 Security Code=00000000 Security Code=0000 Security Code=2138 Security Code=7412 Security Code=2132 All Done. All Done. |
03-14-2012, 15:28 | #1424 (permalink) |
Freak Poster Join Date: Oct 2006 Location: United States
Member: 376302 Status: Offline Thanks Meter: 30 | Verykool I705 Unlock OK Thanks GPGDragon Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... checking network/sp/sim lock status... Unlock done. |
03-14-2012, 21:58 | #1425 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Nokia F888 Code: Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=22 TXD=21 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000EE6A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_MX25U6435E setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Connect and search Security Code... PhoneLock: 1989 Privacy protect: 1234 Done. |
