Dragon Box Chinese Phone Tool |
06-12-2013, 19:08 | #5 (permalink) |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | i cant beleve i arrage ok set a27 then i read full flash after read full flash then set is dead gpg team replay plz is it bug |
06-12-2013, 20:08 | #7 (permalink) |
No Life Poster Join Date: Jan 2010 Location: ANKLESHWAR,GUJARAT,INDIA Age: 41
Member: 1212231 Status: Offline Sonork: 100.1611130 Thanks Meter: 164 | yes dregon support 4 write but sistem file not write complet becouse phone condition same so u can use spd factory fleshtool it s 100% tested |
06-13-2013, 08:24 | #9 (permalink) |
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | but why my set dead after read full flash file >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM222 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 >>> Reading Flash... |
06-13-2013, 08:50 | #10 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Quote:
Reading flash not damaged anything inside the firmware are phone check u r phone with other battery | |
06-14-2013, 08:39 | #14 (permalink) |
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | flash complete but set not on >>> Getting Mobile Connection Info... VCC Pin:4, GND Pin:5, Signal Pin:1, 2, 3, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM21 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 >>> -Analyzing Flash File... Get Flash Format: User Read Full Flash... Flash Size:0X1FFC0000->511M >>> Decompressing file... NV_ADD :0x00000000 SIZE: 0x00008000 SPL_ADD :0x00000000 SIZE: 0x00042000 UBOOT_ADD :0x00000000 SIZE: 0x00060000 VMG_ADD :0x000C0000 SIZE: 0x00040000 MODEM_ADD :0x00140000 SIZE: 0x00300000 DSP_ADD :0x012C0000 SIZE: 0x00200000 BOOT_IMG_ADD:0x01B80000 SIZE: 0x00600000 REC_IMG_ADD :0x01B80000 SIZE: 0x0060B000 SYSTEM_ADD :0x0F220000 SIZE: 0x0A4775C0 USER_ADD :0x02F80000 SIZE: 0x00F89040 BOOTLOGO_ADD:0x00000000 SIZE: 0x01000000 Waiting For Your Confirmation... >>> Writing Flash File... Write_VMG... Write_MODEM... Write_DSP... Write_BOOT_IMG... Write_REC_IMG... Write_SYSTEM... Write_USER... All Done... |
