Dragon Box Chinese Phone Tool |
08-25-2012, 04:15 | #1 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | With New Version With Old Version[/B] Thanks to Dulu Bhai http://forum.gsmhosting.com/vbb/member.php?u=1736341 BR DIPENDRA PATHAK . Last edited by Dipendra Pathak; 12-02-2013 at 06:31. |
The Following 2 Users Say Thank You to Dipendra Pathak For This Useful Post: |
08-25-2012, 04:33 | #2 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | GPG Dragon Pin Finder with RX and TX GPG DRAGON Pin Finder with RX and TX Thanks to Faisal Compuer BR Dipendra Pathak |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
08-25-2012, 04:41 | #3 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | GPG Dragon Read File 6225 Dragon Read File MTK 6225 BR DIPENDRA PATHAK |
08-25-2012, 04:53 | #4 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Making Dragon as USB Pin Finder for Origional Nokia C-5 Making Dragon as USB Pin Finder for Origional Nokia (Here Nokia C-5) BR Dipendra Pathak |
08-25-2012, 05:07 | #5 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | How to change 2 IMEI Using GPG Dragon How to Change 2 IMEI using GPG Dragon BR Dipendra Pathak |
08-25-2012, 05:27 | #6 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | How to set Manually pinout for Coolsand (an Example) with GPG Dragon Last edited by Dipendra Pathak; 09-29-2013 at 15:32. |
08-25-2012, 05:48 | #8 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Read-Write 6252 CPU by Dragon Old Version - 2.08 READ - Write 6252 CPU by DRAGON Old Version - 2.08 BR Dipendra Pathak |
08-25-2012, 06:07 | #9 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | How to Use GPG Freeware Software with SPD How to Use GPG Freeware Software with SPD Thanks to Faheem Anjum BR Dipendra Pathak |
08-25-2012, 06:13 | #10 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | How to upgrade Dragon Box Firmware How to upgrade Dragon Box Firmware [YOUTUBE]3RwTOPmpPxk[/YOUTUB[B]E] BR Dipendra Pathak |
07-19-2013, 06:47 | #11 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | 24 hours Ambulance services for mobiles in DRAGON MOBILE HOSPITAL Receive Data 0x7E Error... - Android CPU Solution We want to provide the solution through some hints/tips because this is not software problem but this is driver problem. we are starting this thread, so that the we also could be confirm by our valuable customer. So, try to connect our supporter if you are stuck in any point Check this post http://forum.gsmhosting.com/vbb/f646...-help-1687278/ Also if you find the problem like this: In such a case, open the "DEVICE MANAGER" we can see the driver name as "SPRD U2S Diag" "SPRD U2S Diag" driver not for SPD chip Device. So, when you try each and every time, it shows error. we need uninstall it and instll to sci (spd flash driver). open the c:\windows\system32 And search all "sprd" and "spd" name files Delete all after del,you need use dragon software pinfind again after pinfind,in the driver manager will tell you install the new driver install the driver <7-Select SCI Driver> after install the driver, we can read flash file. Now, dragon successfully reads. Good Luck Dragon Users BR Dipendra Pathak Last edited by Dipendra Pathak; 04-17-2014 at 14:06. |
The Following 14 Users Say Thank You to Dipendra Pathak For This Useful Post: |
08-08-2013, 04:17 | #13 (permalink) |
No Life Poster Join Date: Oct 2010 Location: china Age: 35
Member: 1428349 Status: Offline Sonork: 100.1597111 Thanks Meter: 13,139 | how to Made the MTK driver support your MTK Phone en..at this time,I face some problem for the MTK stuep the driver I sure the Mobile is MTK CPU,and in the driver install I has select the MTK Driver but still error,and can't install it how to solve??? read this!!!! sample with windows XP(x86) system first,we open the mtk driver inf file"usb2ser_2kXP.inf" The device manager show you the driver name! now we can add the new driver info support the mtk phone hardware add the driver pid and vid to the info file after save the inf file,and install the driver again,finish |
The Following 2 Users Say Thank You to GPGDragon Help For This Useful Post: |
08-08-2013, 04:19 | #14 (permalink) |
Member: 1428349 Status: Offline Sonork: 100.1597111 Thanks Meter: 13,139 | also for the mtk imei driver you can edit it and support your phone |
The Following 3 Users Say Thank You to GPGDragon Help For This Useful Post: |
08-15-2013, 10:00 | #15 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | How to change SPD 6820 / 8810 Andorid 4 IMEI Without Root and few Click (Mobile PHone N9300) Read Info Format User Data How to change SPD 6820/8810 Andorid 4 IMEI Without Root and few Clicks 1. Open SPD Tab. 2. Connect the mobile with Dragon Main Cable and + and - power cable with it (No Battery) 3. Tick "Scan Pinout" 4.Choose "Write IMEI" 5. Choose "6820 Android" Boot 6. Choose "USB" 7.Start 8. Wait Yellow line when it becomes 100% and IMEI Box becomes Green and opens for IMEI write 9. Fill the Correct IMEI that is printed on the Mobile Housing 10. Click On "Write IMEI" and Wait 11. Wait for message "Write (IMEI) to Mobile Done" 12. Restart Your mobile and check the IMEI using keys *#06# 13. Done We do not believe in Faith, Miracle etc, We believe in Work and we believe in GPG Dragon BR Dipendra Pathak Last edited by Dipendra Pathak; 08-17-2013 at 08:51. |
The Following 19 Users Say Thank You to Dipendra Pathak For This Useful Post: |
