gpg team plz help a200 double light spd cpu flash write ok but not power on i have no orignanal backup sets on before formate or flash write log here Initializing... DA_LIB_VER_3.2.0.1 It is sensing the pinout fast... D-=22 D+=19 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM4 Connected...sending boot... FDL test...OK ArmBootMode: 6600700500005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L/WT6226A Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. plz urgent reply for that |
plz give detail more , its Nktel A200 |
check that ur flashfile should be correct or not which version ur using if u flashed it on latest version of gpg-dragon than try 1 more time at 1.12 and post results regards... |
the flash files you can get from support area |
contact me i have this file |
..::Here is your flash file A200 SPD ::.. |
2.1 Quote:
now that positiuon write flash not power on set.......log here with 1.12 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L/WT6226A Flash: NOR_TV00560002EDGB Set FLASH Parameters... Settings have been completed! Reading FileSystem info... Error: Get Flash die baseaddress |
Error: Get Flash die baseaddress.... what can ido for that error |
be sure you are using the latest ver of dragon box and u r box firmware to latest fw keep the * button for whole time and try again |
* mobile * buten whole time i dnt understand plz deatailme thnakls |
Connect the set with cable and keep the Star button * Button for whole time when flashing not complete if Still same Problem then post here |
thanks faheem anjumproblem solved |
thanks alot.............................................. ... |
here is u r code Privacy Protect Code=2552 |
