Dragon Box Chinese Phone Tool |
04-05-2013, 16:16 | #1 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 71603 Status: Offline Thanks Meter: 31 | GPG write backup file -> phone dead Read backup flash Code: >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 >>> Searching Mstar Driver... For Mstar 853XB CPU;You need Hold Down the Power KEY. Find Mstar DriverI:\ --> GCREADER CPU_ID:0x00408003 CPU Name:MSW8533C Connecting Mstar CPU of the Mobile.... >>> Downloading First Boot... >>> Downloading Second Boot... BOOT version: 0x050618 Mobile RAM: 0x02000000 Flash Name:NAND_HYNIX_H8BCS0PG0MBP Flash ID:0x0000ADA1 Flash Size:0x08000000 -> 128M >>> Initializing Boots... >>> Reading Flash... Reading Flash Done... Code: >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 >>> Searching Mstar Driver... For Mstar 853XB CPU;You need Hold Down the Power KEY. Find Mstar DriverI:\ --> GCREADER CPU_ID:0x00408003 CPU Name:MSW8533C Connecting Mstar CPU of the Mobile.... >>> Downloading First Boot... >>> Downloading Second Boot... BOOT version: 0x050618 Mobile RAM: 0x02000000 Flash Name:NAND_HYNIX_H8BCS0PG0MBP Flash ID:0x0000ADA1 Flash Size:0x08000000 -> 128M >>> Erasing Flash Now.... >>> Writing Flash File... Flashing ...Adress: 0x00021000 Size(Hex): 0x00001080 Flashing ...Adress: 0x00000000 Size(Hex): 0x00001080 Flashing ...Adress: 0x00021000 Size(Hex): 0x00001080 Flashing ...Adress: 0x00108000 Size(Hex): 0x000039C0 Flashing ...Adress: 0x00129000 Size(Hex): 0x000039C0 Flashing ...Adress: 0x0014A000 Size(Hex): 0x00004A40 Flashing ...Adress: 0x001AD000 Size(Hex): 0x00004A40 Flashing ...Adress: 0x00210000 Size(Hex): 0x01290000 Flashing ...Adress: 0x01566000 Size(Hex): 0x0083F7C0 Flashing ...Adress: 0x02373000 Size(Hex): 0x00000000 Flashing ...Adress: 0x02394000 Size(Hex): 0x00000000 Flashing ...Adress: 0x023B47C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x023D57C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x023F67C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x024177C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x024387C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x024597C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0247A7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0249B7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x024BC7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x024DD7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x024FE7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0251F7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x025407C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x025617C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x025827C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x025A37C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x025C47C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x025E57C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x026067C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x026277C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x026487C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x026697C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0268A7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x026AB7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x026CC7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x026ED7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0270E7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0272F7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x027507C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x027717C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x027927C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x027B37C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x027D47C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x027F57C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x028167C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x028377C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x028587C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x028797C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0289A7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x028BB7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x028DC7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x028FD7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0291E7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0293F7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x029607C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x029817C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x029A27C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x029C37C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x029E47C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x02A057C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x02A267C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x02A477C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x02A687C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x02A897C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x02AAA7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x02ACB7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x02AEC7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x02B0D7C0 Size(Hex): 0x00000000 Flashing ...Adress: 0x02B2F000 Size(Hex): 0x0002A480 Flashing ...Adress: 0x02C16000 Size(Hex): 0x00000000 Flashing ...Adress: 0x02C367C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x02C577C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x02C787C0 Size(Hex): 0x00004A40 Flashing ...Adress: 0x02CBB000 Size(Hex): 0x0001CE00 Flashing ...Adress: 0x02CDC000 Size(Hex): 0x00008C40 Flashing ...Adress: 0x02CFD000 Size(Hex): 0x00008C40 Flashing ...Adress: 0x02D1E000 Size(Hex): 0x0062F7C0 Flashing ...Adress: 0x03390000 Size(Hex): 0x000207C0 Flashing ...Adress: 0x033D2000 Size(Hex): 0x000207C0 Flashing ...Adress: 0x03414000 Size(Hex): 0x0000AD40 Flashing ...Adress: 0x03435000 Size(Hex): 0x00008C40 Flashing ...Adress: 0x03456000 Size(Hex): 0x000627C0 Flashing ...Adress: 0x034DA000 Size(Hex): 0x000207C0 Flashing ...Adress: 0x0351C000 Size(Hex): 0x00000000 Flashing ...Adress: 0x0353C7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0355D7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0357E7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0359F7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x035C07C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x035E17C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x036027C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x036237C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x036447C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x036657C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x036867C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x036A77C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x036C87C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x036E97C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0370A7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0372B7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0374C7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0376D7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0378E7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x037AF7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x037D07C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x037F17C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x038127C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x038337C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x038547C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x038757C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x038967C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x038B77C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x038D87C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x038F97C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0391A7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0393B7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0395C7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0397D7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x0399E7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x039BF7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x039E07C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03A017C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03A227C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03A437C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03A647C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03A857C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03AA67C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03AC77C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03AE87C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03B097C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03B2A7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03B4B7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03B6C7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03B8D7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03BAE7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03BCF7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03BF07C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03C117C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03C327C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03C537C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03C747C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03C957C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03CB67C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03CD77C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03CF87C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03D197C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03D3A7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03D5B7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03D7C7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03D9D7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03DBE7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03DDF7C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03E007C0 Size(Hex): 0x00000840 Flashing ...Adress: 0x03E43000 Size(Hex): 0x00030FC0 Flashing ...Adress: 0x03E85000 Size(Hex): 0x0000FFC0 Flashing ...Adress: 0x03EA6000 Size(Hex): 0x0000FFC0 Flashing ...Adress: 0x03EC7000 Size(Hex): 0x0000FFC0 Flashing ...Adress: 0x03EE8000 Size(Hex): 0x0000FFC0 Flashing ...Adress: 0x03F09000 Size(Hex): 0x0000D680 Flashing ...Adress: 0x03F2A000 Size(Hex): 0x0001A4C0 Flashing ...Adress: 0x03F6C000 Size(Hex): 0x00007BC0 Flashing ...Adress: 0x03F8D000 Size(Hex): 0x00007BC0 Flashing ...Adress: 0x03FAE000 Size(Hex): 0x00007BC0 Flashing ...Adress: 0x03FCF000 Size(Hex): 0x00007BC0 Flashing ...Adress: 0x03FF0000 Size(Hex): 0x00007BC0 Flashing ...Adress: 0x04011000 Size(Hex): 0x00007BC0 Flashing ...Adress: 0x04032000 Size(Hex): 0x001B7500 Flashing ...Adress: 0x041E4280 Size(Hex): 0x0001B540 All Done... |
04-05-2013, 16:35 | #2 (permalink) |
Member: 71603 Status: Offline Thanks Meter: 31 | file Backup here............ Mobel M970 - Download - 4shared - GSM Mobile |
04-06-2013, 07:20 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | First try to write another good working file. If problem remains same dig hardware as phone already had restart problem which sometimes is due to hardware. Br. |
04-06-2013, 07:35 | #4 (permalink) | |
Product Manager Join Date: Jul 2009 Location: GsmGenesis
Member: 1084080 Status: Offline Thanks Meter: 8,118 | Quote:
Brother Its may be Flash Chip Ic Problam Rehot Than Check | |
04-06-2013, 07:54 | #6 (permalink) |
No Life Poster Join Date: Jan 2010 Location: ANKLESHWAR,GUJARAT,INDIA Age: 41
Member: 1212231 Status: Offline Sonork: 100.1611130 Thanks Meter: 164 | no this is not hardware problem if u have gpg & volcano so contect me i will solvad u r problem with u r becup file no need new file insha allah |
