gpgdragon problem when i connecting set in dragon it show most of the sets follow- Initializing... DA_LIB_VER_3.6.7.1 It is sensing the pinout fast,please hold on the phone Power key RXD=19 TXD=21 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 what is this problem ? |
here it should show like this in your dragon tool when you connect the box Checking box, wait... Box Firmware version: 1.59 Device: GPGDragon - The Ultimate Box verify complete. here it should show like this in your dragon tool when you try to connect any mobile Initializing... DA_LIB_VER_3.6.8.5 It is sensing the pinout fast,please hold on the phone Power key regards, pawan |
Programming... Compare Image: Enable Error: Erase Flash rehot flash chip and check again software not help you Initializing... DA_LIB_VER_3.2.0.7 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 Most if time problem comes from bad connection r Bad Flash chip (low Power ) So must check fst cable If Still Same Then Check With hardware |
when not work then check with hardware. |
