Dragon Box Chinese Phone Tool |
04-26-2015, 11:56 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Shibgonj6340
Member: 844312 Status: Offline Sonork: 100.1640471 Thanks Meter: 257 | symphony L25 flash file boot keu batton midile >>> Getting Mobile Connection Info... VCC Pin: GND Pin:7, Signal Pin:1, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:4 D-:3 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM17 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 >>> Mobile Info Flash ID:0x00C8006000000000 Flash Name:SF_GD25LQ32 Flash Size:0x00400000 -> 4M CPU Name:6531 All Done... >>> Getting Mobile Connection Info... VCC Pin: GND Pin:7, Signal Pin:1, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:4 D-:3 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM17 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 >>> Mobile Info Flash ID:0x00C8006000000000 Flash Name:SF_GD25LQ32 Flash Size:0x00400000 -> 4M CPU Name:6531 Baud Rate is Switched To:921600 >>> Reading Flash... Reality Flash Size£º0x00400000 -> 4M All Done... 100% read gpg file unloc done boot keu batton midile >>> Getting Mobile Connection Info... VCC Pin: GND Pin:7, Signal Pin:1, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:4 D-:3 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM17 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 >>> Mobile Info Flash ID:0x00C8006000000000 Flash Name:SF_GD25LQ32 Flash Size:0x00400000 -> 4M CPU Name:6531 All Done... >>> Getting Mobile Connection Info... VCC Pin: GND Pin:7, Signal Pin:1, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:4 D-:3 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM17 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 >>> Mobile Info Flash ID:0x00C8006000000000 Flash Name:SF_GD25LQ32 Flash Size:0x00400000 -> 4M CPU Name:6531 Baud Rate is Switched To:921600 >>> Reading Flash... Reality Flash Size£º0x00400000 -> 4M All Done... 100% read gpg file unloc done boot keu batton midile >>> Getting Mobile Connection Info... VCC Pin: GND Pin:7, Signal Pin:1, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:4 D-:3 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM17 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 >>> Mobile Info Flash ID:0x00C8006000000000 Flash Name:SF_GD25LQ32 Flash Size:0x00400000 -> 4M CPU Name:6531 All Done... >>> Getting Mobile Connection Info... VCC Pin: GND Pin:7, Signal Pin:1, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:4 D-:3 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM17 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 >>> Mobile Info Flash ID:0x00C8006000000000 Flash Name:SF_GD25LQ32 Flash Size:0x00400000 -> 4M CPU Name:6531 Baud Rate is Switched To:921600 >>> Reading Flash... Reality Flash Size£º0x00400000 -> 4M All Done... Download link SF_GD25LQ32 l25 |
The Following 3 Users Say Thank You to sohidul For This Useful Post: |
01-24-2019, 18:26 | #3 (permalink) |
Freak Poster Join Date: Oct 2018
Member: 2872145 Status: Offline Thanks Meter: 26 | Symphony L25 Spd 6531e Flash File pass 111111222222 http://https://firmwarefile25.******...lash-file.html |
The Following User Says Thank You to flash file pat For This Useful Post: |
